Author Topic: FS 1997 TDI part out and a bit of random garage junk  (Read 4467 times)
September 02, 2013, 07:27:28 pm
« on: September 02, 2013, 07:27:28 pm »
Up on the chopping block this time is a 97 Jetta TDI. It was running fine but the clutch was messed up so I had to start it in gear. I really only tested it in 1st gear. I did not get the codes off of it. I'm pretty sure that this car had 480k on it. Cylinder walls looked great, head is in good shape, very little oil in the IC but the exhaust was very wet with oil. I'm assuming it's the turbo exhaust side.
Click on the pictures for full res
We'll start with some random junk
2x T3 One is seized solid (I haven't tried very hard) and the other has too much in and out and up and down play. $50 each or both for $80. The up and down one is missing a downpipe stud, otherwise everything is in good shape.
1.6 TD timing cover $10
1.6TD/AAZ/AHU/1Z oil piston squirters. I have quite a few sets of these - $20 for 4 with hardware
MK3 AAZ k14/T2 downpipe piece. It will work on a mk1/2 with a T3 or K24 as well. $20 sold
1.5/1.6 vacuum pump - $10 Keyway has quite a bit of wear. Best used for parts.
TDI injectors - $85 SOLD
Intercooler piping - $25 SOLD
Intercooler - $40 SOLD
TDI Injection lines - $50
ECU - $100
Airbox - $20
Cleaned Intake - $65 sold
Cylinder head - I measure 0.002" warpage. max spec is 0.004" Comes as pictured - $400
TDI pump - Didn't appear to be leaking - $225 sold
AHU/1Z injector hold down clamps $15
Motor mount 1H0 199 273D - $20
If you need something that's not mentioned just ask, I probably have it.
« Last Edit: September 26, 2013, 01:23:55 pm by burn_your_money »
Reply #1September 02, 2013, 07:47:35 pm
Re: FS 1997 TDI part out and a bit of random garage junk
« Reply #1 on: September 02, 2013, 07:47:35 pm »
What of the block and rotating assembly?
Reply #2September 02, 2013, 07:50:47 pm
« Reply #2 on: September 02, 2013, 07:50:47 pm »
Rods are sold. Pistons still need a wash and the crank is $100. If you drive down you can have the block for $5. It's bare and you'd have to go searching the scrap bin for the main caps.
Reply #3September 03, 2013, 07:46:01 am
  • 1739
« Reply #3 on: September 03, 2013, 07:46:01 am »
I may be interested in the pump, Don't care if it's leaking,but how was it running before pulled/
Reply #4September 03, 2013, 08:12:08 am
« Reply #4 on: September 03, 2013, 08:12:08 am »
It ran just fine in first gear. That's all I know though.
Reply #5September 03, 2013, 10:54:55 am
« Reply #5 on: September 03, 2013, 10:54:55 am »
PM sent..  :)
Reply #6September 13, 2013, 11:54:47 am
« Reply #6 on: September 13, 2013, 11:54:47 am »
Regarding the TDI intake:
My friend says her 2003 Jetta TDI can't get above 75mph and is sluggish. The car has ~190,000mi and I suspect the intake is clogging/clogged.
1) Does the OBD show a specific code when the intake is clogged?
2) Will the intake above fit her engine (I don't have the block ID).
Thanx,
TD
Reply #7September 13, 2013, 07:12:29 pm
Blocksmith
  • 261
    Wrench Lurker
« Reply #7 on: September 13, 2013, 07:12:29 pm »
From what I've read (and what happened on my dad's 2002 wagon), a clogged intake / runners will not throw a code, generally speaking. The performance will just be awful, for no apparent reason. If the intake has not been cleaned before, I would bet money it's clogged--they ALL clog at some point. And no the intake will not fit, as a 2003 motor  should be an ALH, which has the intake facing the other way.
Green 83 Rabbit 4dr, 5 speed ACH trans swap, ported 1.6D mech lifter w/ vnt15, na pump w/ gov mod, gasser intake mani, 2.5" exhaust, bilstein sports and cut mk2 springs, ss brake lines, 14" vw bottlecaps
Reply #8September 13, 2013, 08:06:15 pm
« Reply #8 on: September 13, 2013, 08:06:15 pm »
Thanks for the info.
I'm 3hrs away from the car, but that's what I seem to recall about the intake.
