Author Topic: mk2 alternator pivot bolt size?  (Read 8218 times)
June 12, 2013, 02:46:38 pm
damac
  • 531
« on: June 12, 2013, 02:46:38 pm »
seems like a dumb question i guess.  i can't find mention of it by searching firums.
i am kind of stuck at the moment and would appreciate a size thread and length?
thanks!
1985 turbo diesel jetta
Reply #1June 12, 2013, 03:59:54 pm
bbob203
  • 1789
Re: mk2 alternator pivot bolt size?
« Reply #1 on: June 12, 2013, 03:59:54 pm »
i think its a shouldered bolt id go get one from the dealer...
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #2June 12, 2013, 04:25:34 pm
« Reply #2 on: June 12, 2013, 04:25:34 pm »
yup, its a special bolt...
dealer only item i imagine, or you machine one yourself..
Reply #3June 12, 2013, 04:30:13 pm
« Reply #3 on: June 12, 2013, 04:30:13 pm »
Is it special? I thought it was an M12 hex washer head? Maybe it depends on which alt you have ac or non ac?
Post a pic of what you are looking for, I maybe able to help.
Reply #4June 12, 2013, 04:31:48 pm
« Reply #4 on: June 12, 2013, 04:31:48 pm »
gasser uses a normal socket head bolt..
diesel uses something different i believe..
couldnt use a gasser bolt on a diesel, because i tried..
Reply #5June 12, 2013, 04:33:45 pm
« Reply #5 on: June 12, 2013, 04:33:45 pm »
Right I have a gas alt on my diesel. IIRC it was an 11mm bolt on the gasser as I had to drill it to fit the diesel to 12mm.
Post a pic as it may just be a 12mm that is pretty long, but I should be able to get.
Reply #6June 12, 2013, 04:37:27 pm
« Reply #6 on: June 12, 2013, 04:37:27 pm »
Pretty sure its a M6 bolt, not a M12..
M12 is the same size as our head bolts!!
Reply #7June 12, 2013, 04:43:33 pm
« Reply #7 on: June 12, 2013, 04:43:33 pm »
Maybe, it has been a while. That is why I need a pic to see if his is like mine, then I can measure :D
Reply #8June 12, 2013, 08:47:16 pm
« Reply #8 on: June 12, 2013, 08:47:16 pm »
IIRC, it's something like  10 x 1.5 x 110..
The one on the right.
the others are 140mm
I have one somewhere in the shed, but it's raining like hell out there now... tomorrow I can get the length.
Reply #9June 12, 2013, 11:26:37 pm
damac
  • 531
« Reply #9 on: June 12, 2013, 11:26:37 pm »
i am stuck as far as a picture because i don't have anything that fits in the bin, old one is gone.
i have no idea what is stock but the 85 with no ac had just a typical bolt with part shoulder that feeds through drivers side and threads on passenger side of alternator mount.
also i tried to ask a vw dealer that i got some other parts from to pull up a picture and get me a new bolt and they said not made anymore?
Reply #10June 13, 2013, 05:04:41 am
« Reply #10 on: June 13, 2013, 05:04:41 am »
Looks to me a regular old hex washer head. Could be replaced with a hex head and washer of appropriate length.
Reply #11June 13, 2013, 09:12:47 am
« Reply #11 on: June 13, 2013, 09:12:47 am »
All mine are w/AC: 10 x 95 (1.5 pitch)
