Author Topic: Make engine rev faster.  (Read 6206 times)
March 22, 2013, 07:25:00 pm
jaed_43725
« on: March 22, 2013, 07:25:00 pm »
So how do I do it. I want my engine to spin up a bit faster than it does. I am just not feeling the acceleration ya know. It will spin up to 5K (I dont do it) easy enough, but its how long it takes to get there. I have the pump worked already, 2.5" exhaust (need dp still), boost up to 15lbs. And yet the only gear that revs fast enough is 1st, and its so short it wont even build boost. So any help is appreciated. Thanks.
Reply #1March 22, 2013, 07:31:01 pm
Re: Make engine rev faster.
« Reply #1 on: March 22, 2013, 07:31:01 pm »
You need more horsepower.. Its the only way to do it. lol. You can't spin something faster and quicker without the power/force to do so.
At least... nothing easier short of adding more power. I am guessing the turbo is a T3 or the kkk24 and they are slower to build boost when near stock power levels.
Also, spinning to 5000rpm (if the engine is in good working order) will not harm anything. I used to rev my 1.6 NA out to higher than that every shift.. hah
Reply #2March 22, 2013, 07:36:24 pm
jaed_43725
« Reply #2 on: March 22, 2013, 07:36:24 pm »
Mo Power huh? I need an intercooler for that. I will check into the BatMoWheel for my turbo then. Stock its capable of pushing as much air as I need (20ish psi). Are there any lightweight single mass flywheels? How about roller rockers?
Reply #3March 22, 2013, 07:49:28 pm
« Reply #3 on: March 22, 2013, 07:49:28 pm »
Can't he just shave some weight off his existing flywheel?  Or do we really need that much weight to keep things smooth against the heavy smack down at ignition on every cylinder?
Reply #4March 22, 2013, 07:49:52 pm
« Reply #4 on: March 22, 2013, 07:49:52 pm »
Ohhhhh, You're a V8 gasoline guy ;).....
Rockers? These are OHC not OHV engines ;D No rockers. Cam lobe is directly on the lifters. Yes an inter cooled 20psi will be a good power spot. Any hotter and you are really just ingesting hot air, hurting performance.
The 1.6 flywheel is already pretty light in terms of flywheels.. I think it is like 11lbs?? Not to mention from what I have read light weight flywheels and diesel do not mix. I am running a 1.9 210mm flywheel on my m-tdi and it revs up fine ;). YA NEED POWAH!
Reply #5March 22, 2013, 07:50:16 pm
« Reply #5 on: March 22, 2013, 07:50:16 pm »
For money spent and effort exerted.. I feel like it would be 100% wasted lol.
Reply #6March 22, 2013, 08:00:48 pm
jaed_43725
« Reply #6 on: March 22, 2013, 08:00:48 pm »
11lbs is light. On note of that, for ORCoaster: The IDI engines dont have the same internal jolts as DI engines. That is why they are so much smoother at higher RPM's. So much for that. I started in V8's, that is true. Went Japanese (Subaru) and then VW because its diesel. OHC huh? That is awesome. I guess VW has gone a little backwards as earlier TDI's were pushrods.
So the short answer here is, better DP, IC, BatMoWheel and more boost w/ more fuel. Too easy.
Reply #7March 22, 2013, 08:09:44 pm
« Reply #7 on: March 22, 2013, 08:09:44 pm »
Too easy.
Ain't it though? You can up the power another 50% with free power mods.. lol
Reply #8March 22, 2013, 10:23:37 pm
mystery3
  • 774
« Reply #8 on: March 22, 2013, 10:23:37 pm »
The stock flywheel is nowhere near 11lbs.
I think you can shave a few pounds of the stocker with a positive effect on performance but if you get too light you're drivability will suffer greatly.
Would it be worth the cost? I can't answer that for you.
Reply #9March 22, 2013, 10:59:31 pm
wolf_walker
  • 1205
Re: Re: Make engine rev faster.
« Reply #9 on: March 22, 2013, 10:59:31 pm »
Wait, TDI pushrods? Backwards?
Sent from my Xoom using Tapatalk 2
Mentat Text Two
Reply #10March 23, 2013, 04:56:53 am
carrizog60
  • 978
« Reply #10 on: March 23, 2013, 04:56:53 am »
tdi are same design as old IDI.
newer are twin cam 16v
Portugal
Reply #11March 23, 2013, 06:27:01 am
« Reply #11 on: March 23, 2013, 06:27:01 am »
The stock AAZ 210mm flywheel wieghs 12.6lbs the 200mm should be a tad heavier, but I would say somewhere in the 13 range. TDI never has had pushrods. The downpipe will allow the turbo to flow better and spool faster. I could make 10psi in nuetral with my k24 and 3" all the way. It sounds like you need to add some fuel and read the FAQ section on how to make your "x" car faster.
Reply #12March 23, 2013, 08:38:50 am
  • 5104
« Reply #12 on: March 23, 2013, 08:38:50 am »
A lot of ohc engines still have rockers like Hondas and dodge
Reply #13March 23, 2013, 09:01:12 am
« Reply #13 on: March 23, 2013, 09:01:12 am »
The first TDI was in a 1989 Audi 100, and it was the 2.5 R5 and made about 115hp. Volkswagen owns the term TDI. No other DI diesel engine is referred to as TDI just for future references ;).
I'm sorry, I thought we were talking about car engines no scooters. ?? ;D
Reply #14March 23, 2013, 09:30:22 am
kaneb
  • 164
    • www.dasdubbers.org
« Reply #14 on: March 23, 2013, 09:30:22 am »
Hahaha.
I have the 8v flywheel on my 1.6TD.  lts revs up and down a little quicker when free reving, but not much compared to the old NA with stock FW.  I don't know if it has done anything for any substantial power gains though.
Also a intercooler makes that boost make your ass hit the seat a little harder.  A downpipe made my turbo spool quicker for sure.
2004 Tdi sport-daily
1983 Rabbit TD-go kart
www.dasdubbers.org
