Author Topic: parting 85 1.6 TD engine  (Read 5730 times)
March 19, 2013, 04:13:09 am
ilikevwdiesel
  • 1202
    • Erupt into a BEVRAGE this summer with Glug!
« on: March 19, 2013, 04:13:09 am »
parting an MF 1.6 with solid lifers. keeping the turbo and associated parts, everything else must go. pm with needs.
Look, if corn and kudzu fall in love and have a baby in a lab under the supervision of scientists working in my employ, WHO AM I TO STOP THAT other than the CEO responsible for stopping it???
My Bio
Reply #1March 20, 2013, 05:23:49 pm
ilikevwdiesel
  • 1202
Re: parting 85 1.6 TD engine
« Reply #1 on: March 20, 2013, 05:23:49 pm »
cylinder head sold. still have the pump, going to install it on my rabbit truck to test it. looking for 150 for that if it tests good.
My Bio
Reply #2March 20, 2013, 08:31:48 pm
Rising
  • 385
« Reply #2 on: March 20, 2013, 08:31:48 pm »
how much for the oil pan shipped to 22554? or is that going with the turbo set up?
'84 Rabbit Diesel- 1.6D Stock
Reply #3March 21, 2013, 11:18:04 am
DRP67207
  • 50
« Reply #3 on: March 21, 2013, 11:18:04 am »
PM Sent
Reply #4March 21, 2013, 12:52:19 pm
ilikevwdiesel
  • 1202
« Reply #4 on: March 21, 2013, 12:52:19 pm »
regarding the injection pump, it's been sitting plugged up and full of fuel for like 5yrs. I pulled the cover off the advance piston and didn't see anything like water or rust in there. will mount it on my rabbit and use a primer bulb to force some diesel purge thru it and try and start it. it should run, there's no obvious reason why it shouldn't, but this pump will most certainly need a reseal. I can do that but that would add 100 to the price. hope this helps any interested buyers.
My Bio
Reply #5March 21, 2013, 02:58:43 pm
rabbid79
  • 684
« Reply #5 on: March 21, 2013, 02:58:43 pm »
How much for the rods?
'15 WRX
Reply #6March 21, 2013, 03:07:22 pm
ilikevwdiesel
  • 1202
« Reply #6 on: March 21, 2013, 03:07:22 pm »
someone is interested in the shortblock, so i can't part it like that right now. probably would hold onto it anyways cause the bores aren't that bad really.
My Bio
Reply #7March 25, 2013, 03:37:09 pm
ilikevwdiesel
  • 1202
« Reply #7 on: March 25, 2013, 03:37:09 pm »
short block sold.
My Bio
Reply #8March 28, 2013, 10:02:13 am
rudygetz
  • 13
« Reply #8 on: March 28, 2013, 10:02:13 am »
Do you have an A/C compressor? Or the non-A/C bracket on the alternator?
I'm trying to convert my rabbit to non-A/C setup...do you have what I need to accomplish that?
Reply #9March 28, 2013, 10:06:11 am
ilikevwdiesel
  • 1202
« Reply #9 on: March 28, 2013, 10:06:11 am »
yes I do. pm sent
« Last Edit: March 28, 2013, 10:08:33 am by ilikevwdiesel »
My Bio
Reply #10March 28, 2013, 12:34:06 pm
shwak23
  • 417
    1990 VW Golf TD. Engine Code CY
    • Blackdog Junkyard
Re: Re: parting 85 1.6 TD engine
« Reply #10 on: March 28, 2013, 12:34:06 pm »
Do you have a glow plug bus bar and an oil cooler and all related hoses?
Sent from Outer Space!
Reply #11March 30, 2013, 09:48:25 pm
Luckypabst
  • 502
« Reply #11 on: March 30, 2013, 09:48:25 pm »
Lower timing belt cover?
Chris
'82 TD Westy
'81 NA Caddy
Reply #12March 30, 2013, 10:07:39 pm
« Reply #12 on: March 30, 2013, 10:07:39 pm »
How much for the pump good sir?
Reply #13March 31, 2013, 03:17:57 am
ilikevwdiesel
  • 1202
« Reply #13 on: March 31, 2013, 03:17:57 am »
the lower timing belt cover fell to bits when it was removed  :(
not sure what I"m doing with the pump right now. mounted it on my na motor just to try it out but it's all gummed up inside, would only run when fuel was being forced thru it. looking for offers on it I guess. don't think there's any rust inside but maybe the head should be removed to see if there is any in there.
My Bio
