For Sale/Looking For
Parts for Sale/Wanted
parting 85 1.6 TD engine
Topic: parting 85 1.6 TD engine (Read 5721 times)
March 19, 2013, 04:13:09 am
ilikevwdiesel
March 19, 2013, 04:13:09 am »
parting an MF 1.6 with solid lifers. keeping the turbo and associated parts, everything else must go. pm with needs.
My Bio
March 20, 2013, 05:23:49 pm
ilikevwdiesel
Re: parting 85 1.6 TD engine
March 20, 2013, 05:23:49 pm »
cylinder head sold. still have the pump, going to install it on my rabbit truck to test it. looking for 150 for that if it tests good.
My Bio
March 20, 2013, 08:31:48 pm
Rising
March 20, 2013, 08:31:48 pm »
how much for the oil pan shipped to 22554? or is that going with the turbo set up?
'84 Rabbit Diesel- 1.6D Stock
March 21, 2013, 11:18:04 am
DRP67207
March 21, 2013, 11:18:04 am »
PM Sent
March 21, 2013, 12:52:19 pm
ilikevwdiesel
March 21, 2013, 12:52:19 pm »
regarding the injection pump, it's been sitting plugged up and full of fuel for like 5yrs. I pulled the cover off the advance piston and didn't see anything like water or rust in there. will mount it on my rabbit and use a primer bulb to force some diesel purge thru it and try and start it. it should run, there's no obvious reason why it shouldn't, but this pump will most certainly need a reseal. I can do that but that would add 100 to the price. hope this helps any interested buyers.
My Bio
March 21, 2013, 02:58:43 pm
rabbid79
March 21, 2013, 02:58:43 pm »
How much for the rods?
'15 WRX
March 21, 2013, 03:07:22 pm
ilikevwdiesel
March 21, 2013, 03:07:22 pm »
someone is interested in the shortblock, so i can't part it like that right now. probably would hold onto it anyways cause the bores aren't that bad really.
My Bio
March 25, 2013, 03:37:09 pm
ilikevwdiesel
March 25, 2013, 03:37:09 pm »
short block sold.
My Bio
March 28, 2013, 10:02:13 am
rudygetz
Newbie
March 28, 2013, 10:02:13 am »
Do you have an A/C compressor? Or the non-A/C bracket on the alternator?
I'm trying to convert my rabbit to non-A/C setup...do you have what I need to accomplish that?
March 28, 2013, 10:06:11 am
ilikevwdiesel
March 28, 2013, 10:06:11 am »
yes I do. pm sent
Last Edit: March 28, 2013, 10:08:33 am by ilikevwdiesel
My Bio
March 28, 2013, 12:34:06 pm
shwak23
Re: Re: parting 85 1.6 TD engine
March 28, 2013, 12:34:06 pm »
Do you have a glow plug bus bar and an oil cooler and all related hoses?
Sent from Outer Space!
Reply #11
March 30, 2013, 09:48:25 pm
Luckypabst
Reply #11 on:
March 30, 2013, 09:48:25 pm »
Lower timing belt cover?
Chris
'82 TD Westy
'81 NA Caddy
Reply #12
March 30, 2013, 10:07:39 pm
Reply #12 on:
March 30, 2013, 10:07:39 pm »
How much for the pump good sir?
Reply #13
March 31, 2013, 03:17:57 am
ilikevwdiesel
Reply #13 on:
March 31, 2013, 03:17:57 am »
the lower timing belt cover fell to bits when it was removed
not sure what I"m doing with the pump right now. mounted it on my na motor just to try it out but it's all gummed up inside, would only run when fuel was being forced thru it. looking for offers on it I guess. don't think there's any rust inside but maybe the head should be removed to see if there is any in there.
My Bio
