Time to start assembling 1.5 TD / 1.9L Franken Diesel.
Pages:
6
7
8
9
10
11
12
13
25
Topic: Time to start assembling 1.5 TD / 1.9L Franken Diesel. (Read 110179 times)
Reply #120
March 13, 2013, 07:55:11 am
Alcaid
Re: Time to start assembling 1.5 TD / 1.9L Franken Diesel.
Reply #120 on:
March 13, 2013, 07:55:11 am »
If you are at the point of more fuel than air, then add more air :p
Regarding the girdle:
http://www.vwdiesel.net/forum/index.php?topic=27133.0
'03 VW Golf PD130 4Motion Highline
'10 VW Passat 1.6TDI Highline
'83 VW Jetta 1.6TD, 11mm pump, H-beam rods, girdle, fully reworked AAZ head +++ Going Compound
Reply #121
March 13, 2013, 09:22:57 pm
JamesT
Reply #121 on:
March 13, 2013, 09:22:57 pm »
I would say somewhere around 16cc per cylinder would hydrolock. Of course that would be theoretical. There would have to be some room for air.
93 Golf - AAZ with some fueling
78 Rabbit - 1.5 DIESEL (finally)
[(+)===o===(+)]
(++\==o==/++)
Reply #122
March 14, 2013, 07:00:07 pm
Reply #122 on:
March 14, 2013, 07:00:07 pm »
the pump is rated @ 90cc/min i believe.. not 90cc/stroke..
think of it, the pump plunger would need to be the size of a honda 90 piston to put out 90cc/stroke!
Reply #123
March 14, 2013, 07:53:50 pm
Jetmugg
Reply #123 on:
March 14, 2013, 07:53:50 pm »
That's good thinking right there. I got a little carried away.
Steve.
Reply #124
March 14, 2013, 11:47:36 pm
Alcaid
Reply #124 on:
March 14, 2013, 11:47:36 pm »
Actually pumps are rated in cc / 1000 strokes
Reply #125
March 15, 2013, 05:47:18 am
Jetmugg
Reply #125 on:
March 15, 2013, 05:47:18 am »
Quote from: Alcaid on March 14, 2013, 11:47:36 pm
That's even better thinking.
Reply #126
March 15, 2013, 12:20:52 pm
Reply #126 on:
March 15, 2013, 12:20:52 pm »
thank you.. wasnt sure if it was a timed reading like gasser fuel injector flow, or something else..
90cc/stroke sounded out of the question..
90cc/min sounded more plausible..
but 90cc/1000strokes, that makes ALOT more sense..
Reply #127
March 28, 2013, 08:11:04 am
Reply #127 on:
March 28, 2013, 08:11:04 am »
looks like just what you need, although they are really really light.
http://forums.vwvortex.com/showthread.php?5998497-BFI-020-Clutch-Kits-amp-Billet-Flywheels
Reply #128
March 28, 2013, 12:55:09 pm
Jetmugg
Reply #128 on:
March 28, 2013, 12:55:09 pm »
I will probably end up with one of the BFI flywheels. I already have a 210mm pressure plate & clutch setup.
Steve.
Reply #129
March 28, 2013, 04:03:23 pm
Reply #129 on:
March 28, 2013, 04:03:23 pm »
i had no idea they had those billet wheels, im thinking they just now came out?
Reply #130
July 27, 2013, 09:21:50 am
Reply #130 on:
July 27, 2013, 09:21:50 am »
Where are you at with this mr jetmugg
Round 2
Reply #131
August 01, 2013, 12:27:55 pm
Jetmugg
Reply #131 on:
August 01, 2013, 12:27:55 pm »
World Of Speed is Sept 7-10. I am working on this deal every day. It WILL be done, and will run at World of Speed, I just don't have a lot of time to spare between now and then.
Engine and trans are in the truck. Yesterday, I got the throttle linkage and clutch cable worked out and adjusted. Tonight I will fab up the radiator mounts. Intercooler is mounted and plumbed. The 2" tubing shown in the photo was replaced by 2.5" tubing over the last week.
There's still plenty to do, but it's within sight.
Reply #132
August 01, 2013, 12:31:40 pm
Jetmugg
Reply #132 on:
August 01, 2013, 12:31:40 pm »
A few more pics - need to upload more...
Reply #133
August 01, 2013, 02:19:23 pm
carrizog60
Reply #133 on:
August 01, 2013, 02:19:23 pm »
i think 0.95 wouldnt be enough advance...
Portugal
Reply #134
August 01, 2013, 06:35:47 pm
Reply #134 on:
August 01, 2013, 06:35:47 pm »
On a performance pump like mine and his .95 maybe too much for the high rpm, but not too too much that it is horribly bad. Giles told me between .90 and .95, his pump builder probably did the same. The only thing I would do different is take that red line at 5500 rpm and move it to 6,000
Last Edit: August 01, 2013, 06:52:30 pm by theman53
Round 2
Pages:
6
7
8
9
10
11
12
13
25
