Author Topic: UPDATE na-td motor swap Timed correctly atf in now engine no crank  (Read 39483 times)
Reply #90October 08, 2012, 05:52:46 pm
srgtlord
  • 797
Re: UPDATE na-td motor swap Timed correctly atf in now engine no crank
« Reply #90 on: October 08, 2012, 05:52:46 pm »
My bet is on a crankshaft that moved when the the belt was tensioned and the pistons hit valves.... I would double check the valve timing.
« Last Edit: October 08, 2012, 05:56:13 pm by srgtlord »
Reply #91October 08, 2012, 06:00:10 pm
bbob203
  • 1789
« Reply #91 on: October 08, 2012, 06:00:10 pm »
I made sure that didn't happen when i tensioned the belt as i tensioned before tightening camshaft pulley(though i did have the mishap mentioned the other day with belt slipping). last guy that had this motor before me did it the other way around and the cam was slightly off making it run like poop esp at idle though the car was driven about 2000 miles that way then i pulled the motor. It did make this same noise when starting at times before i pulled the motor i assumed it was a lack of fuel.
« Last Edit: October 08, 2012, 06:13:22 pm by bbob203 »
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #92October 08, 2012, 08:23:51 pm
« Reply #92 on: October 08, 2012, 08:23:51 pm »
[soapbox]The crank WILL NOT move when you tighten the tensioner unless you have done the timing belt process wrong.  You need to preload the belt by turning the crank CCW a little and then CW back to TDC without passing TDC so that all of the slack of the belt is in the tensioner area.  If that is done, then the crank will NOT move when tensioning the belt.  If that is not done, then then crank will move and the cam timing will be retarded.[/soapbox]
Reply #93October 11, 2012, 02:04:42 pm
« Reply #93 on: October 11, 2012, 02:04:42 pm »
what andrew just said, is 100% accurate..
there is a right and wrong way to set the belt on these engines..
if you set it wrong, you kill the engine..
Reply #94October 11, 2012, 04:18:07 pm
bbob203
  • 1789
« Reply #94 on: October 11, 2012, 04:18:07 pm »
if valves are bent even a little bit will engine still run?
03 Jetta wagon TDi
Reply #95October 11, 2012, 04:18:47 pm
« Reply #95 on: October 11, 2012, 04:18:47 pm »
Turn it over by hand first, don't risk it! lol
Reply #96October 11, 2012, 04:39:01 pm
bbob203
  • 1789
« Reply #96 on: October 11, 2012, 04:39:01 pm »
oh no I always do the 2 rotations to check it. what I'm think is dude before me may have slighly bent the valves and it still ran wondering if it possible? I thought issue before was fueling but maybe its bent valves causing it to run poorly at idle.
03 Jetta wagon TDi
Reply #97October 11, 2012, 04:58:52 pm
« Reply #97 on: October 11, 2012, 04:58:52 pm »
even valves that are out of adjustment will not seal all the way, but still allow it to run..
its completely possible to have a few slightly bent valves, but still run.
Reply #98October 11, 2012, 05:36:07 pm
« Reply #98 on: October 11, 2012, 05:36:07 pm »
Yes.
They will even straighten out a bit over time, but then one or more valves will probably drop a head into the motor.
Reply #99October 12, 2012, 06:14:34 am
bbob203
  • 1789
« Reply #99 on: October 12, 2012, 06:14:34 am »
called up some place called diesel injection services to see if they would test my pump.. i made the mistake of telling them someone opened it up they said they wont touch it now.  ::)
called location in another city 350 to bench test...  :o :o
« Last Edit: October 12, 2012, 06:25:27 am by bbob203 »
03 Jetta wagon TDi
Reply #100October 12, 2012, 07:11:37 am
« Reply #100 on: October 12, 2012, 07:11:37 am »
What the hell? Clearly with all of these pumps being 20+ years old theyve been opened by someone at some point.. Idiots!
Reply #101October 12, 2012, 08:34:41 am
bbob203
  • 1789
« Reply #101 on: October 12, 2012, 08:34:41 am »
I sort of want to dynamite this dang car!
03 Jetta wagon TDi
Reply #102October 15, 2012, 08:24:07 am
bbob203
  • 1789
« Reply #102 on: October 15, 2012, 08:24:07 am »
after much debate Im going ahead and giving up and putting my original pump back in the car.
03 Jetta wagon TDi
Reply #103October 17, 2012, 09:16:19 am
bbob203
  • 1789
« Reply #103 on: October 17, 2012, 09:16:19 am »
fresh battery and the stock pump and its running. ;D
03 Jetta wagon TDi
Reply #104October 17, 2012, 09:42:09 am
« Reply #104 on: October 17, 2012, 09:42:09 am »
Did you also install a new battery?? Was the old battery really pooched??
