Author Topic: UPDATE na-td motor swap Timed correctly atf in now engine no crank  (Read 39398 times)
September 24, 2012, 08:05:46 pm
bbob203
  • 1789
« on: September 24, 2012, 08:05:46 pm »
Months in the making im finally buttoning this project up. Last final questions i have is
1. I have a spin filter and housing from a rabbit i want to use but cannot manage to find a good spot to put it...
2. Do cone filters flow as good as a the stock airbox this thing is a big bulky pain in the ass to remove and install..
« Last Edit: October 03, 2012, 08:32:13 am by bbob203 »
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #1September 25, 2012, 09:53:04 am
Re: Finishing up na-td motor swap few questions airbox and fuel filter...
« Reply #1 on: September 25, 2012, 09:53:04 am »
1.) make a bracket, it fits nicely in the same spot the rabbit filter fits..
2.) sure they flow as good, but you have to clean them 3x as often, being that there is no protection around them AKA AIRBOX..
my GLI has the charcoal canister taken out of the pass side fenderwell, and my intake piping runs thru that hole, and my air cleaner is down in the fender, kinda down by the power steering pump.. actually, the end of the filter is only about 1" away from the p/s pulley.
and uh, mk2 air boxes are CAKE to remove and install.. try removing the air box out of an audi 4k/quattro, then ell me the mk2 is hard?
if you have a TD air box, i would run it.. ive been looking for AGES to get a real mk2 TD air box.. would love to get rid of my intake system..
Reply #2September 25, 2012, 12:11:55 pm
« Reply #2 on: September 25, 2012, 12:11:55 pm »
TD airboxes are awesome. Kev i have two.. Text me.
Filter should mount up easy peasy.
Reply #3September 25, 2012, 05:40:07 pm
bbob203
  • 1789
« Reply #3 on: September 25, 2012, 05:40:07 pm »
 same spot the rabbit filter fits..  looked up pics on google couldn't come up with where this is vie never worked on a rabbit. i have found a few pics of na mounting location but none for td.
« Last Edit: September 25, 2012, 05:48:13 pm by bbob203 »
03 Jetta wagon TDi
Reply #4September 25, 2012, 06:26:01 pm
« Reply #4 on: September 25, 2012, 06:26:01 pm »
stock mk1 TD mounting spot
Reply #5September 25, 2012, 06:31:46 pm
bbob203
  • 1789
« Reply #5 on: September 25, 2012, 06:31:46 pm »
AH ha. Your google fu skill very good my son. Thanks!!
03 Jetta wagon TDi
Reply #6September 25, 2012, 06:32:46 pm
« Reply #6 on: September 25, 2012, 06:32:46 pm »
looks like a total PITA to change though.. lol
Reply #7September 26, 2012, 04:42:16 am
  • 2931
« Reply #7 on: September 26, 2012, 04:42:16 am »
That's a MK1 engine bay isn't it?
 Are we talking about MK2 fuel filter placement?
 Because i think mine fits right behind the stock TD airbox, on the strut tower.
Reply #8September 26, 2012, 05:07:10 am
bbob203
  • 1789
« Reply #8 on: September 26, 2012, 05:07:10 am »
yes mk2. i thought about using stock location but seemed it sticks up to high to close the hood.
03 Jetta wagon TDi
Reply #9September 26, 2012, 05:38:22 am
« Reply #9 on: September 26, 2012, 05:38:22 am »
If you have: a drill, a piece of sheet metal, MK1 filter, MK1 bracket, an imagination, and just a bit of intelligence it is possible.
Reply #10September 26, 2012, 06:18:40 am
bbob203
  • 1789
« Reply #10 on: September 26, 2012, 06:18:40 am »
sometimes my ocd gets the best of me.
03 Jetta wagon TDi
Reply #11September 26, 2012, 11:24:25 am
« Reply #11 on: September 26, 2012, 11:24:25 am »
this is what i was talking about..
mounting it in the same spot as a n/a rabbit..
Reply #12September 26, 2012, 12:08:01 pm
bbob203
  • 1789
« Reply #12 on: September 26, 2012, 12:08:01 pm »
a hammer and some finagling i used the stock mk2 filter holder didn't thing it would clear the hood but alas it did.
03 Jetta wagon TDi
Reply #13September 26, 2012, 08:23:10 pm
bbob203
  • 1789
Re: UPDATE na-td motor swap few questions cranking but no fuel at injectors..
« Reply #13 on: September 26, 2012, 08:23:10 pm »
Got it cranking over tonite wouldn't start though cracked and injector while cranking it and its dry as a bone. Resealed ip from jeremy swapped out delivery valves the ip definitely has fuel in i primed it and have it bottle fed.  ???
03 Jetta wagon TDi
Reply #14September 26, 2012, 08:30:56 pm
« Reply #14 on: September 26, 2012, 08:30:56 pm »
Is the stop solenoid getting power? There should be very little fuel actually coming out of the injector lines, it needs a few cycles to produce even a small drop of fuel out of the delivery valves.
