Author Topic: UPDATE na-td motor swap Timed correctly atf in now engine no crank  (Read 39440 times)
Reply #45October 02, 2012, 12:11:50 pm
Re: UPDATE na-td motor swap few questions cranking but no fuel at injectors..
« Reply #45 on: October 02, 2012, 12:11:50 pm »
But with vaseline on everything. Alot on the vane pump
maybe its the vaseline keeping the vane pump from pulling fuel..
they may be stuck still
Reply #46October 02, 2012, 12:41:26 pm
bbob203
  • 1789
« Reply #46 on: October 02, 2012, 12:41:26 pm »
so maybe it sitting with fuel in it will free it up? or something more viscous like atf might free it up?
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #47October 02, 2012, 12:43:06 pm
« Reply #47 on: October 02, 2012, 12:43:06 pm »
Very possible. Andrew did say it needed extended cranking to get stuff moving. I would tty an ATF soak for the hell of it.
Reply #48October 03, 2012, 08:34:12 am
bbob203
  • 1789
Re: UPDATE na-td motor swap Timed correctly atf in now engine no crank
« Reply #48 on: October 03, 2012, 08:34:12 am »
I got some atf and fresh battery in this morning. timed it to. .039" and now it wont turnover not even by hand it like stuck but nothing is impeding it.
03 Jetta wagon TDi
Reply #49October 03, 2012, 09:09:21 am
bbob203
  • 1789
« Reply #49 on: October 03, 2012, 09:09:21 am »
could I have an airlock that wont let it crank over?
03 Jetta wagon TDi
Reply #50October 03, 2012, 09:16:12 am
« Reply #50 on: October 03, 2012, 09:16:12 am »
starter is sticking, turn the engine backwards a rotation or 2, that should free everything up..
Reply #51October 03, 2012, 09:39:46 am
bbob203
  • 1789
« Reply #51 on: October 03, 2012, 09:39:46 am »
I think I royally screwed myself... I acidentally turned the key with ip lock pin in that's when this problem surfaced I discovered after taking the key out it wouldn't fully turn over. I think it caused my cam timing to be off and I'm hitting a valve...  :'(  NOW IM CLUELESS. My ip is lined upwith the mark and my cam lobes on 1 are up and slot it aligned but the tdc mark is no longer visible on flywheel. I know for a fat everything was lined up before because I was cranking.
03 Jetta wagon TDi
Reply #52October 03, 2012, 09:48:15 am
« Reply #52 on: October 03, 2012, 09:48:15 am »
then the valves are sticking.. turn the motor backwards to un-bind everything..
you will likely have to put a new timing belt on it..
Reply #53October 03, 2012, 10:28:49 am
bbob203
  • 1789
« Reply #53 on: October 03, 2012, 10:28:49 am »
yep pulled off lower belt cover crank is 90° OFF TDC. I cant sed how the *** that happened from leaving that pin in but it happened. how should I go about getting it right. is is possible I damaged anything?
03 Jetta wagon TDi
Reply #54October 03, 2012, 10:35:20 am
« Reply #54 on: October 03, 2012, 10:35:20 am »
100% possibility that you could have (and probably do have) bent valves..
get a new belt, re-time it, and see if it runs..
Reply #55October 03, 2012, 10:41:34 am
« Reply #55 on: October 03, 2012, 10:41:34 am »
Ooooh.. Dang. I had this exact thing happen to me.. The crank has the least amou t of teeth therefore the least hold on the belt. The belt cant hold the torque of the starter sp it shreds teeth. If the crank turned 90 and you right now cannot turn the motor by hand.. Im Gonna say it is more than likely she is fubard.
Reply #56October 03, 2012, 10:47:18 am
bbob203
  • 1789
« Reply #56 on: October 03, 2012, 10:47:18 am »
I loosened the cam bolt and pooped it of it instantly allowed the motor to spin free I got all the timing marks realigned. I see how that could've happenes jeremy. the tbelt has like 2k on it none of the teeth look buggered up.
03 Jetta wagon TDi
Reply #57October 03, 2012, 11:38:00 am
« Reply #57 on: October 03, 2012, 11:38:00 am »
If none of the teeth look buggered how did the crank spin 90* and nothing else moved with it??
After you get it retimed ( and as should be done everytime) you should turn the motor over by hand with a wrench.. To make sure there is no binding.
Reply #58October 03, 2012, 11:44:18 am
bbob203
  • 1789
« Reply #58 on: October 03, 2012, 11:44:18 am »
the whole situation is confusing the heck out of me haha. I can get a gates belts for 9.99 or a conti for 28.99. decisions.
03 Jetta wagon TDi
Reply #59October 03, 2012, 11:54:53 am
srgtlord
  • 797
« Reply #59 on: October 03, 2012, 11:54:53 am »
Why did you loosen the cam bolt?
