Author Topic: UPDATE na-td motor swap Timed correctly atf in now engine no crank  (Read 39397 times)
Reply #75October 04, 2012, 12:48:52 pm
bbob203
  • 1789
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #76October 04, 2012, 12:50:05 pm
bbob203
  • 1789
Re: UPDATE na-td motor swap Timed correctly atf in now engine no crank
« Reply #76 on: October 04, 2012, 12:50:05 pm »
someone on another forum recommended spin the pump with an electric drill and putting an in bolt on my output temporarily.
03 Jetta wagon TDi
Reply #77October 04, 2012, 01:27:18 pm
« Reply #77 on: October 04, 2012, 01:27:18 pm »
I have a facet low pressure pump from napa. It cost me $45 4 years ago so im guessing its about $60 in todays dollars. Go get one. I was one of Jeremy's first customers and noticed the pump took a little bit of help from the low pressure pump until it would pump anything from 2 of the 4 delivery valves. After that issue was squared away I noticed my car was close to impossible to start. I found out he accidentally flipped the orientation of the pump internals. I had to purchase an old style pump pulley from ebay to retime my pump by flipping the new pulley 180 degrees. Now I can bet dollars to doughnuts that because jeremy built this pump after mine that your pump is NOT 180 degrees out.
if his pump is 180* out, he did it, not Jeremy..
Reply #78October 04, 2012, 02:13:31 pm
« Reply #78 on: October 04, 2012, 02:13:31 pm »
UIf the lift pump doesn't do it, increase cranking speed via tow chain to get things moving...
Reply #79October 04, 2012, 04:36:34 pm
bbob203
  • 1789
« Reply #79 on: October 04, 2012, 04:36:34 pm »
tow chain?? ah you mean like hook it up to another vehicle?
03 Jetta wagon TDi
Reply #80October 04, 2012, 04:42:42 pm
« Reply #80 on: October 04, 2012, 04:42:42 pm »
Exactly that.  If your starter cranks at 400RPM engine, that's only 200 at the pump.
Behind a tow car, you can easily get 2-3000RPM engine speed in 2nd or 3rd.  That will greatly increase the vanes urge to sling  out into position, and overcome many a pumping deficiency.
If you don't want it to start, just leave the pipe to injector nuts loose.  You are winning when all injectors are wet with fuel.
Reply #81October 04, 2012, 05:32:31 pm
bbob203
  • 1789
« Reply #81 on: October 04, 2012, 05:32:31 pm »
how many turns in from fully removed is the fuel screw set from the factory?
03 Jetta wagon TDi
Reply #82October 06, 2012, 11:06:53 am
« Reply #82 on: October 06, 2012, 11:06:53 am »
its installed with it wound in clear against the stop collar..
Reply #83October 08, 2012, 12:10:54 pm
bbob203
  • 1789
« Reply #83 on: October 08, 2012, 12:10:54 pm »
I pulled off the t belt again and tried using a drill to spin the pump but it didn't have the balls to turn it. I used a ratchet to spin in as as as i could as i could see the fuel level in the line move so i guess the vanes are doing something. it wasn't pulling fuel in but it ws moving nothing is still coming from outbound line or delivery valves.. I think the problem is wit the delivery valves thats the only thing that has been changed on the pump. Im giving up and putting the eco pump back in i need a car.
03 Jetta wagon TDi
Reply #84October 08, 2012, 12:24:22 pm
bbob203
  • 1789
« Reply #84 on: October 08, 2012, 12:24:22 pm »
so I just started loosening injector lines to swap pumps and bottom 2 delivery valves had fuel dripping from them top 2 are still dry.
03 Jetta wagon TDi
Reply #85October 08, 2012, 12:32:35 pm
bbob203
  • 1789
« Reply #85 on: October 08, 2012, 12:32:35 pm »
spun the pump with WOT and saw fuel physically dribbling out of bottom two delivery valves for sure. might the tops be stuck?
03 Jetta wagon TDi
Reply #86October 08, 2012, 01:00:58 pm
« Reply #86 on: October 08, 2012, 01:00:58 pm »
Interesting.. If it has sat in ATF for this long it should be groovy in there.. but still 2 of them having fuel should have been enough to get some smoke from the tailpipe.
Reply #87October 08, 2012, 03:56:14 pm
bbob203
  • 1789
« Reply #87 on: October 08, 2012, 03:56:14 pm »
its making a choking duck noise when i crank it over..
03 Jetta wagon TDi
Reply #88October 08, 2012, 04:18:33 pm
« Reply #88 on: October 08, 2012, 04:18:33 pm »
And you are absolutely sure the valve timing is correct?
Reply #89October 08, 2012, 04:47:53 pm
bbob203
  • 1789
« Reply #89 on: October 08, 2012, 04:47:53 pm »
AS far as i can tell it is, Is the duck noise a bad sign?
03 Jetta wagon TDi
