Author Topic: TD Injection Pump 6000rpm capable $300USD  (Read 9852 times)
February 09, 2006, 01:25:12 pm
vw1303
  • 8
« on: February 09, 2006, 01:25:12 pm »
This pump has been modified to flow enough fuel to turn your 1.6 @ 6000rpm.
$300 USD
Erik 604.816.1491
Reply #1February 15, 2006, 07:38:36 pm
iggi
  • 33
« Reply #1 on: February 15, 2006, 07:38:36 pm »
Has it been rebuilt?
'97 Jetta GL TD
'87 Vanagon Westy
Reply #2February 15, 2006, 07:46:05 pm
DVST8R
  • 535
« Reply #2 on: February 15, 2006, 07:46:05 pm »
Who modified it, and what did they do to it?... Nevermind I just realised I modified it.
The Brett of the board...
The Dark Side of Beauty.[/i]
Reply #3February 15, 2006, 07:47:55 pm
DVST8R
  • 535
« Reply #3 on: February 15, 2006, 07:47:55 pm »
AND ISN'T THAT MY PUMP?????????  :shock:
Reply #4February 16, 2006, 06:34:39 am
addautomotive
« Reply #4 on: February 16, 2006, 06:34:39 am »
LOL, small world!
Reply #5February 20, 2006, 11:18:03 am
TDForNow
  • 131
« Reply #5 on: February 20, 2006, 11:18:03 am »
Quote from: "DVST8R"
 OK, what DID you do to it?
'85 Quantum 1.6TD
'04 Passat 2.0 8vTDI
Reply #6February 20, 2006, 11:20:08 am
TDForNow
  • 131
« Reply #6 on: February 20, 2006, 11:20:08 am »
DVST8R, where'd you get the accel "bump-up" linkage from for the cold start?
'85 Quantum 1.6TD
Reply #7March 05, 2006, 06:01:22 pm
mainer
  • 126
« Reply #7 on: March 05, 2006, 06:01:22 pm »
Still got it? What has been done to it? Just governer spring? Would you be willing to ship?
Thanks Cooper
_________________
Myositis Forum
01 Jetta
84 Jetta TD
08 Duramax
12 Sportwagen TDi
Reply #8March 05, 2006, 07:18:28 pm
DVST8R
  • 535
« Reply #8 on: March 05, 2006, 07:18:28 pm »
Quote from: "TDForNow"
It came like that...???
Reply #9March 05, 2006, 07:22:32 pm
DVST8R
  • 535
« Reply #9 on: March 05, 2006, 07:22:32 pm »
Quote from: "mainer"
Thanks Cooper
I dont know about the shipping as I am not selling it.
As far as the rest of the pump. As I recall, It has a custom cut fuel cone which has been modified for full travel, the starwheel as been adjusted, the main fuel scew is adjusted, govnor mod, and possibly more. That is all I can think of off the top of my head.  :wink:
Reply #10March 06, 2006, 05:08:52 am
mainer
  • 126
« Reply #10 on: March 06, 2006, 05:08:52 am »
Anything else I have to do to put it in? Do I have to do valve springs or anything? Or can I just Slap it in and run it? How many miles on it?
Thanks
_________________
Mercedes Benz W196
01 Jetta
84 Jetta TD
08 Duramax
12 Sportwagen TDi
Reply #11March 06, 2006, 05:59:33 pm
DVST8R
  • 535
« Reply #11 on: March 06, 2006, 05:59:33 pm »
Slap it in and run it, not like a dodge the valve springs will be just fine.  :wink:
I honestly have modified like 5 or 6 pumps since then and have no idea how many miles are on it. Mabey the seller will chime in, and answer.
Reply #12March 06, 2006, 06:25:10 pm
mainer
  • 126
« Reply #12 on: March 06, 2006, 06:25:10 pm »
I dont think that the seller will come back. He's only got 6 posts, but maybe he will. I'm planing on running a turbo and IC with this anything else you would sugest? Is it to much fuel to run without the added air from the turbo?
I guess I could call him if I wanted, maybe after I get my turbo in I'll want it more.
Coop
_________________
recession history us
01 Jetta
84 Jetta TD
08 Duramax
12 Sportwagen TDi
Reply #13March 07, 2006, 05:48:49 pm
DVST8R
  • 535
« Reply #13 on: March 07, 2006, 05:48:49 pm »
Without a turbo it won't add much fuel at all as it is controled by the LDA, the only other things I strongly sugest are: EGT Gauge, Boost Gauge, Aftermarket downpipe (either P.P or T.T) and a big open exhuast. That combo should give you enough to get you going.  :wink: If you still want more you are going to need gtd nozzles or bigger, and a giles pump.
Reply #14March 07, 2006, 06:53:07 pm
mainer
  • 126
« Reply #14 on: March 07, 2006, 06:53:07 pm »
These are just my plans for now. Not sure if it's gonna happen. I've gotta get the car going right first. I figured that I could Get the ideas going in the early stages of the project. I only paid 100 for the car. So far it has need a new block heater(leaking really bad), heater core(that was fun to change), Antifreeze pipe that went from heater core to bottom of the block. I think its gonna need a new raidator and clutch. I do all my own work, and should have around 1500 when I am totaly done with it Turbo, pump and all. I also would like to Grease it, Is this pump going to run fine on WVO?
Having the dodge, I know the basics of modding a diesel. Its gotta be able to breath. 2.5 stright pipe should take care of that, and a less restrictive intake. I've gotta be able to tell what my tems are running, EGT, Boost, maybe even oil temp. The new raidator, and an intercooler will keep it cool. I'm not sure about the clutch, Just gonna stick with the orignal till it goes. As it is now I set my foot on top and the pedal drops to the floor, I dont think it has much life left in it. This turbo kit, Its a friends. I havent' talked to him much about it, All I know is it an aftermarket kit for the 1.6. Its not an OEM kit, so it should be boosting more than a stock turbo. He wants 500 for it instaled I'm hopping he still has it when it comes time for me to get it instaled. I would put it in myself but 500 is just to good to be true.
Coop
_________________
og kush photos
01 Jetta
84 Jetta TD
08 Duramax
12 Sportwagen TDi
