Author Topic: TD Injection Pump 6000rpm capable $300USD  (Read 9844 times)
Reply #15March 07, 2006, 07:35:36 pm
wyldman
  • 403
« Reply #15 on: March 07, 2006, 07:35:36 pm »
Without the piston cooling nozzles,your going to have to be careful with it.Keep the EGT's well on the safe side,as the pistons aren't oil cooled like a true TD motor.
What have your done to your Dodge ? I have a 97 12V that currently puts out 550 HP.More mods this year will get me well into the 600's,and hopefully into the mid 12's at the track.
(416)565-7282
Reply #16March 08, 2006, 07:17:02 am
mainer
  • 126
« Reply #16 on: March 08, 2006, 07:17:02 am »
As For now I' running a 3200 gov spring. Smoke screw tweaked, and full power screw tweaked. Soon I will have a smaller turbine housing, and Injectors. I'm thinking of water and meth injection. I've got the VE pump like in the VW's not the P pump that you have. Its not as easy to get power out of the ve.
Coop
_________________
debt management
01 Jetta
84 Jetta TD
08 Duramax
12 Sportwagen TDi
Reply #17March 08, 2006, 04:01:28 pm
935racer
« Reply #17 on: March 08, 2006, 04:01:28 pm »
I know this pump and who is selling it, its been left out in the rain, and its got a sketchy governor mod etc.
Reply #18March 08, 2006, 05:47:00 pm
mainer
  • 126
« Reply #18 on: March 08, 2006, 05:47:00 pm »
Hey thanks For the tip.
Coop
_________________
Title insurance Forum
01 Jetta
84 Jetta TD
08 Duramax
12 Sportwagen TDi
Reply #19March 08, 2006, 06:30:23 pm
wyldman
  • 403
« Reply #19 on: March 08, 2006, 06:30:23 pm »
Quote from: "mainer"
Coop
The POD injectors would be a nice addition,and then you may not need the smaller housing.It will spool better,and help keep EGT's in check.
Is your truck auto or stick ? A good convertor is like adding 100 HP with these trucks.Dodge uses a gas TC behind the Cummins,and it stalls too high,way above the torque peak,especially when you turn up the power.Adding a shift kit or valve body will help the trans hold the power too.
I have 370 injectors,a Piers stoopid race pump,a custom made cam plate,4 inch exhaust,and a BHAF.Timing bumped to 17 degrees.With the stock trans,I've run a best of 13.24,blowing right through the convertor and slipping the trans the whole way.I just built myself a DTT auto with custom ATS low stall convertor,and it really hooks now.I hope to break into the mid 12's this year,if I can keep the EGT's in check.Looks like twins will be my next project. :D
(416)565-7282
Reply #20March 09, 2006, 02:48:58 pm
mainer
  • 126
« Reply #20 on: March 09, 2006, 02:48:58 pm »
Ya, I've got the auto. Its only got 200k on it so it should be good for a little while. I will do a TC in a bit, but I'm happy with it where it is now. Once i start with the mods again the TC will be first on my list. I'd like to get the VW going, the mpgs in the dodge arnt that great.
Coop
_________________
howtorollajoint
01 Jetta
84 Jetta TD
08 Duramax
12 Sportwagen TDi
