General Information
Troubleshooting
Need Help Putting Passenger Side CV Assembly Back In!! Please
Topic: Need Help Putting Passenger Side CV Assembly Back In!! Please (Read 4332 times)
January 17, 2012, 01:30:52 pm
mtnbob
January 17, 2012, 01:30:52 pm »
Maybe I've been on my back too long and the blood has all rushed too my head
But I can't seem to get my new CV axle back on. I got all the old bolts out without a hitch and removed the old cv axle. For some reason I can't seem to get the new one in. The suspension arm or oil pan is in the way. Please don't laugh at me(too much) I'm sure I am overlooking something ::)Does the wheel need to be off the ground or on it? Do I need to turn the steering one way or the other? My Bentley book shows pictures but doesn't mention procedure. I know I have done this before but I don't remember this much difficulty. Help please if you have the patience.
Last Edit: January 17, 2012, 01:45:37 pm by mtnbob
86 VW Golf 1.6 N/A 4-door (soon to be turboed!!!)
http://farm4.static.flickr.com/3248/2598033828_d3d19f9842.jpg?v=0
96 Subaru Outback Wagon
January 17, 2012, 02:13:23 pm
mtnbob
Re: Need Help Putting Passenger Side CV Assembly Back In!! Please
January 17, 2012, 02:13:23 pm »
Nevermind, I took everything off and got it back on. There was probably an easier way, but I didn't see it.
January 17, 2012, 08:14:50 pm
January 17, 2012, 08:14:50 pm »
I don't know how you got it but the old trick is to use a floor jack to lift the engine/transmission assembly up about 1/2" which is just enough to get the end of the axle to clear the flange, without having to remove the suspension arm. Turning the wheel also helps.
January 17, 2012, 09:07:25 pm
mtnbob
January 17, 2012, 09:07:25 pm »
Dang, i knew there had to be a trick to it!!!
January 18, 2012, 04:18:41 pm
January 18, 2012, 04:18:41 pm »
The front control arm bolt. Remove that and the control arm will swing out allowing you to get the axle out with no issue.
January 18, 2012, 08:27:48 pm
January 18, 2012, 08:27:48 pm »
on my cars, i just un-do the ball joint bolts, and then swing the knuckle/strut out of the way..
passenger side axle has enough room to get it out without taking anything apart.
drivers side, knuckle needs to swing away a bit..
General Information
Troubleshooting
