Author Topic: Need Help Putting Passenger Side CV Assembly Back In!! Please  (Read 4317 times)
January 17, 2012, 01:30:52 pm
mtnbob
  • 738
« on: January 17, 2012, 01:30:52 pm »
Maybe I've been on my back too long and the blood has all rushed too my head :o But I can't seem to get my new CV axle back on. I got all the old bolts out without a hitch and removed the old cv axle. For some reason I can't seem to get the new one in. The suspension arm or oil pan is in the way. Please don't laugh at me(too much) I'm sure I am overlooking something  ::)Does the wheel need to be off the ground or on it? Do I need to turn the steering one way or the other? My Bentley book shows pictures but doesn't mention procedure. I know I have done this before but I don't remember this much difficulty. Help please if you have the patience.
« Last Edit: January 17, 2012, 01:45:37 pm by mtnbob »
96 Subaru Outback Wagon
Reply #1January 17, 2012, 02:13:23 pm
mtnbob
  • 738
Re: Need Help Putting Passenger Side CV Assembly Back In!! Please
« Reply #1 on: January 17, 2012, 02:13:23 pm »
Nevermind, I took everything off and got it back on. There was probably an easier way, but I didn't see it.
Reply #2January 17, 2012, 08:14:50 pm
« Reply #2 on: January 17, 2012, 08:14:50 pm »
I don't know how you got it but the old trick is to use a floor jack to lift the engine/transmission assembly up about 1/2" which is just enough to get the end of the axle to clear the flange, without having to remove the suspension arm. Turning the wheel also helps.
Reply #3January 17, 2012, 09:07:25 pm
mtnbob
  • 738
« Reply #3 on: January 17, 2012, 09:07:25 pm »
Dang, i knew there had to be a trick to it!!! ;D
Reply #4January 18, 2012, 04:18:41 pm
« Reply #4 on: January 18, 2012, 04:18:41 pm »
The front control arm bolt. Remove that and the control arm will swing out allowing you to get the axle out with no issue.
Reply #5January 18, 2012, 08:27:48 pm
« Reply #5 on: January 18, 2012, 08:27:48 pm »
on my cars, i just un-do the ball joint bolts, and then swing the knuckle/strut out of the way..
passenger side axle has enough room to get it out without taking anything apart.
drivers side, knuckle needs to swing away a bit..
