Author Topic: Oil From Turbo Intake  (Read 4536 times)
January 13, 2012, 08:26:31 am
jaysen71581
  • 211
    Hagerstown, MD
« on: January 13, 2012, 08:26:31 am »
Ok so i fired up the rabbit TD this morning to take it to get my battery tray welded in when i go to pop the hood i saw oil spewing out of the turbo so i check my dipstick and i had no oil in there.  Im thinking blown seal, its a K04 turbo, in the mean time i have an NA setup i can put on to make due but what options for a turbo do i have?
Reply #1January 13, 2012, 08:51:11 am
Re: Oil From Turbo Intake
« Reply #1 on: January 13, 2012, 08:51:11 am »
Any vw 8v exhaust manifold with the turbo attached will physically bolt up to your motor.
This is a good opportunity to think of how you could change the motor for the better. Do you want better low end torque or top end power.. could step it down to a k03, or step up to a T3..
Reply #2January 13, 2012, 02:33:18 pm
jaysen71581
  • 211
    Hagerstown, MD
« Reply #2 on: January 13, 2012, 02:33:18 pm »
Well i built the car for MPG's, i wouldnt mind if it pulled alittle harder on acceleration, what T3 should i go with i see them on ebay from around $100-200
Reply #3January 13, 2012, 02:36:23 pm
« Reply #3 on: January 13, 2012, 02:36:23 pm »
From my readings, I have found that sustaining higher boost while cruising can actually be very beneficial for MPG.. I think you would have tons of fun stepping down to a k03. You will make boost pretty much right off idle, and have boost throughout your rpm range. Will you be taking the engine much over 4000rpms.. if not then you need not worry about high rpm flow capability.
Reply #4January 13, 2012, 02:43:12 pm
jaysen71581
  • 211
    Hagerstown, MD
« Reply #4 on: January 13, 2012, 02:43:12 pm »
not really its going to be a daily for my brother driving 60 miles to work and back..
Reply #5January 13, 2012, 02:46:20 pm
jaysen71581
  • 211
    Hagerstown, MD
« Reply #5 on: January 13, 2012, 02:46:20 pm »
Unfortunately im looking at the K03's and they mount differently to the manifold, i kinda want something that i can just bolt on and go.
Reply #6January 13, 2012, 02:48:20 pm
« Reply #6 on: January 13, 2012, 02:48:20 pm »
if you were to get one with a manifold it would be a bolt on and go type ordeal. But fully bolt on and go is better. I am unaware what mates up to a k04 manifold. sorry.
Reply #7January 13, 2012, 03:08:51 pm
jaysen71581
  • 211
    Hagerstown, MD
Reply #8January 13, 2012, 03:24:32 pm
Swartzvw
  • 53
84 VW Rabbit w/ VNT 17
87 VW Jetta GL
Reply #9January 13, 2012, 03:27:12 pm
jaysen71581
  • 211
    Hagerstown, MD
« Reply #9 on: January 13, 2012, 03:27:12 pm »
The car has a KKK turbo in it, i wonder how much it would be to rebuild....
Reply #10January 13, 2012, 04:45:54 pm
« Reply #10 on: January 13, 2012, 04:45:54 pm »
350.00 at the g pop shop, then they open it and it grows if you need hard parts. If everything is reusable 350. plus shipping from them.
Reply #11January 13, 2012, 08:01:55 pm
  • 2932
« Reply #11 on: January 13, 2012, 08:01:55 pm »
 How's your block pressure?
 Vacuum pump leaks filling the block with air?
 Block vent on the front of the block?
Reply #12January 14, 2012, 06:39:13 am
jaysen71581
  • 211
    Hagerstown, MD
« Reply #12 on: January 14, 2012, 06:39:13 am »
new vaccum hoses, i guess it was good because it operated the brakes and they stop well.. Only thing i can figure is the turbo is about 25 years old, as with my IP seals go bad over time, i think it was just cold enough and there was enough thermal shock on the seals in the turbo to have a blow out, the block is fine.  Once i get my garage cleaned out ill have the car inside converting it to NA till i decide on a turbo.
Reply #13January 14, 2012, 08:11:12 am
« Reply #13 on: January 14, 2012, 08:11:12 am »
Reply #14February 19, 2012, 11:02:51 am
jaysen71581
  • 211
    Hagerstown, MD
Re: Oil From Turbo Intake *Update*
« Reply #14 on: February 19, 2012, 11:02:51 am »
So i finally got around to pulling the turbo off the car and to my surprise the turbo that was on the car was a K24 triple K turbo, ive never heard of a k24 turbo, is it any good and is it worth rebuilding?
