Author Topic: .  (Read 7385 times)
November 05, 2011, 07:02:41 am
« on: November 05, 2011, 07:02:41 am »
« Last Edit: November 08, 2011, 03:45:53 pm by theman53 »
Reply #1November 05, 2011, 07:03:01 am
Re: Presale: 10 VNT turbo mounts for MK2
« Reply #1 on: November 05, 2011, 07:03:01 am »
« Last Edit: November 08, 2011, 03:46:04 pm by theman53 »
Reply #2November 05, 2011, 07:46:38 am
  • 1739
« Reply #2 on: November 05, 2011, 07:46:38 am »
phew, at first,it looked like you were trying to sell 2 sections of perforated steel angle for $75
Reply #3November 05, 2011, 11:44:33 am
wdkingery
  • 494
« Reply #3 on: November 05, 2011, 11:44:33 am »
Nah he's done all the legwork gettin the measurements all worked out and the fitting correct. $75 will get you a complete mount that's been designed to fit a vnt to a 1.6
Reply #4November 05, 2011, 11:53:07 am
Toby
  • 728
« Reply #4 on: November 05, 2011, 11:53:07 am »
Could you post a pic of just the mount? Is it triangulated somewhere or is it just the plate showing in the photos?
Reply #5November 05, 2011, 12:41:10 pm
« Reply #5 on: November 05, 2011, 12:41:10 pm »
oh, its triangulated alright.. he built 'em good!
Reply #6November 06, 2011, 01:16:13 pm
« Reply #6 on: November 06, 2011, 01:16:13 pm »
« Last Edit: November 08, 2011, 03:46:16 pm by theman53 »
Reply #7November 06, 2011, 09:37:22 pm
Toby
  • 728
« Reply #7 on: November 06, 2011, 09:37:22 pm »
You need to triangulate everything or it will fail in short order. You present design is a prescription for failure. The welds show little penetration and will also fail quickly unless ground out and rewelded. This stuff should be TIG welded since it is a HIGHLY stressed component. That mount is subjected to all of the torque that the engine produces plus lots of shock loading when you pop the clutch. Without proper gusseting and non faulty welds it will just fold up like so much cardboard. I would use a full length gusset in the spot where you have the tiny one.
The execution looks nice otherwise. I suspect you will sell a bunch of them.
Reply #8November 06, 2011, 09:57:48 pm
« Reply #8 on: November 06, 2011, 09:57:48 pm »
« Last Edit: November 08, 2011, 03:46:28 pm by theman53 »
Reply #9November 07, 2011, 09:44:30 am
Toby
  • 728
« Reply #9 on: November 07, 2011, 09:44:30 am »
No the welds are NOT fine. Show them to a welder and he will confirm why: Insufficient penetration among other things. I could break all of them with a hammer.
No you do not have nearly enough triangulation on the mount and it WILL fail in short order. It is vastly weaker than the stocker. You have this vast area from where it bolts to the block to where it bolts to the rubber mount that is unsupported. Your design will work fine IF the gusset runs from the BOTTOM of the area where it bolts to the block to the closest  point to the mount. Otherwise it will just flex until it cracks. To tell yourself otherwise is just magical thinking.
Reply #10November 07, 2011, 10:11:31 am
« Reply #10 on: November 07, 2011, 10:11:31 am »
it does need more triangulation. ALOT more.
i would have that mount broken in a few days..
Reply #11November 07, 2011, 01:34:36 pm
« Reply #11 on: November 07, 2011, 01:34:36 pm »
Nevermind.
« Last Edit: November 08, 2011, 03:46:51 pm by theman53 »
Reply #12November 07, 2011, 11:52:05 pm
Toby
  • 728
« Reply #12 on: November 07, 2011, 11:52:05 pm »
I don't mean to jam on you but every weld pictured is bad and we can see most of them. I can weld pretty well, but in critical applications I get a welder to do the work, because you and I and the vast majority of hobbyists are not capable to making EVERY weld what it should be. Cheap MIG welding equipment is not capable of doing strong welds on 1/4" plate even if the look OK. The stuff pictured is clearly not up to snuff. Have a pro do it.
Reply #13November 08, 2011, 05:08:48 am
« Reply #13 on: November 08, 2011, 05:08:48 am »
« Last Edit: November 08, 2011, 03:47:03 pm by theman53 »
Reply #14November 08, 2011, 05:46:04 am
BigVWman
  • 332
« Reply #14 on: November 08, 2011, 05:46:04 am »
How did all the commentary end up in a FS thread? Especially with none of us buying any?
You can adequately mig 1/4 plate and i really don't know how anyone can truely say the welds are insufficient without holding it in your hands and looking at it and even then its subjective. I doubt any of us, even your pro welders mentioned, follow the proper methods to the t, i bet half don't even own a rod oven.
Tim
83 rabbit shell 92 cabby tdi conversion, 91 cabby aba conversion, 87 cabby,  87 gti,  01nb tdi new project,00 1.8t nb, 98 ranger,92 f150 flareside(its pink) 97 cabrio and a 00 cabrio!
