Author Topic: clutch slipping!! need sources for aftermarket upgraded clutches  (Read 15708 times)
September 12, 2011, 05:09:37 pm
bgbmxer
  • 107
« on: September 12, 2011, 05:09:37 pm »
i need a clutch to hold more power for my 84 rabbit. there seems to be plenty of stuff for the 1.8 gas motors of the same year. would they work on the diesel
Reply #1September 12, 2011, 07:53:09 pm
vanagonturbo
  • 639
    • Fine Tuning
Re: clutch slipping!! need sources for aftermarket upgraded clutches
« Reply #1 on: September 12, 2011, 07:53:09 pm »
What is this monster that you are needing such a powerful clutch? A stock clutch (210mm) should hold fine on a tweaked TD.
Reply #2September 12, 2011, 08:31:03 pm
nathan_b
  • 361
« Reply #2 on: September 12, 2011, 08:31:03 pm »
1st
do 16v pressure plate,
2nd,
south bend (or o2a conversion)
Reply #3September 12, 2011, 09:13:04 pm
  • 2932
« Reply #3 on: September 12, 2011, 09:13:04 pm »
 A gasser 210mm clutch should be a cheap upgrade,.. and I believe the 16V pressure plate applies more force.
Reply #4September 13, 2011, 01:11:13 am
bgbmxer
  • 107
« Reply #4 on: September 13, 2011, 01:11:13 am »
car is in the idi section if you want to check it out. went for a third gear pull and it spooled up and revs went up car didnt accelerate much. it was rather bad.
Reply #5September 13, 2011, 01:11:54 am
bgbmxer
  • 107
« Reply #5 on: September 13, 2011, 01:11:54 am »
1st
2nd,
02a conversion?
Reply #6September 13, 2011, 01:13:44 am
bgbmxer
  • 107
« Reply #6 on: September 13, 2011, 01:13:44 am »
i have heard the straps break. does this use the same flywheel? what year of vw does this said clutch i want come on? im new to these things
Reply #7September 13, 2011, 06:41:37 am
nathan_b
  • 361
« Reply #7 on: September 13, 2011, 06:41:37 am »
1st
2nd,
02a conversion?
gearbox vw used in mk3 vrs and tdis, and everything mk4+ stock clutches are known to hold 250-300hp stock. And they last forever (comparatively) unlike our 020s
Reply #8September 13, 2011, 10:25:09 am
vanagonturbo
  • 639
    • Fine Tuning
« Reply #8 on: September 13, 2011, 10:25:09 am »
I would suggest an ACT pressure plate and stock disk. If you have the means, an o2a swap would be ideal. It is not a bolt in affair though.
Reply #9September 13, 2011, 02:27:10 pm
« Reply #9 on: September 13, 2011, 02:27:10 pm »
i have a 16v pressure plate, and 210mm clutch.. it hooks up good!
idk why it wouldnt work for you.. the 16v pressure plate is the important part of the equation.. no stiffer clutch pedal, but you can tell the difference when launching..
Reply #10September 13, 2011, 05:34:43 pm
bgbmxer
  • 107
« Reply #10 on: September 13, 2011, 05:34:43 pm »
off what car and what flywheel are you using
Reply #11September 13, 2011, 06:03:12 pm
BigVWman
  • 332
« Reply #11 on: September 13, 2011, 06:03:12 pm »
I run a sachs 16v PP and 210 disc with my 1z in the cabriolet and it has no problem hooking up
The 16v originally came on sciroccos and some jettas/golfs of the 87/88/89 vintage the 210 disc came on rabbits,jettas,golfs everything but the diesel from about 84 on and flywheel you can do from any of the 16v or even 8v mk3 cars just make sure its marked for TDC before installing it as some only have advanced timing marks!
« Last Edit: September 13, 2011, 06:07:20 pm by BigVWman »
Tim
83 rabbit shell 92 cabby tdi conversion, 91 cabby aba conversion, 87 cabby,  87 gti,  01nb tdi new project,00 1.8t nb, 98 ranger,92 f150 flareside(its pink) 97 cabrio and a 00 cabrio!
Reply #12September 13, 2011, 06:08:09 pm
« Reply #12 on: September 13, 2011, 06:08:09 pm »
its off a 16v car, duh!
kidding aside tho, its off a 2.0 16v out of a german 92 Jetta GLI.
flywheel, i think its a stock weight gasser flywheel.
and the clutch is rebuilt stock VW/Audi 210mm.
Reply #13September 13, 2011, 06:17:17 pm
bgbmxer
  • 107
« Reply #13 on: September 13, 2011, 06:17:17 pm »
just stock stuff? no crazy disc?
Reply #14September 13, 2011, 06:22:11 pm
bgbmxer
  • 107
« Reply #14 on: September 13, 2011, 06:22:11 pm »
and another question the outside diameter of the flywheel is is the same? does the starter and such still work?
and the disc will fit the splines on my o20 trans?
« Last Edit: September 13, 2011, 06:26:07 pm by bgbmxer »
