Author Topic: List of tools to R&R a 020 transmission?  (Read 4613 times)
August 10, 2011, 04:04:22 pm
erice1984
  • 263
« on: August 10, 2011, 04:04:22 pm »
I am looking for a list of tools, and pictures of these tools so I can R&R a 020 transmission.
Thanks
-Eric
1980 Rabbit 1.9TD
Reply #1August 10, 2011, 04:15:02 pm
Re: List of tools to R&R a 020 transmission?
« Reply #1 on: August 10, 2011, 04:15:02 pm »
http://www.brokevw.com/lucasags.html
Thant is my trans, but he has a list on his main page of a bunch of stuff.   www.brokevw.com
Reply #2August 10, 2011, 05:19:26 pm
rallydiesel
  • 1880
« Reply #2 on: August 10, 2011, 05:19:26 pm »
A simple shop press (~12 ton) is a must.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #3September 21, 2011, 10:50:27 pm
RadoTD
  • 513
    Stage WTF
« Reply #3 on: September 21, 2011, 10:50:27 pm »
Define R&R... are you swapping transmissions or rebuilding one?
enough boost is when you have 3 dimple marks in the hood from the valve cover nuts..  ;D
Reply #4September 22, 2011, 09:00:48 am
nathan_b
  • 361
« Reply #4 on: September 22, 2011, 09:00:48 am »
R&R is pretty universal as remove and replace...
81 caddy frankentd 02a, 99.9 tdi jetta, 00 golf
Reply #5September 22, 2011, 09:11:30 am
« Reply #5 on: September 22, 2011, 09:11:30 am »
it takes nothing more than simple hand tools to remove and replace a trans, but REBUILDING a trans, takes a press, and all that sorts of cool stuff..
Reply #6September 22, 2011, 01:12:35 pm
« Reply #6 on: September 22, 2011, 01:12:35 pm »
You'll need a 8mm 12pt triple square to get the axles off, and a scissor jack to push the engine ahead far enough depending on platform. A1,2 or3 or B? Also a 30mm socket.
Other then that it should already be in your tool box.
Reply #7September 22, 2011, 06:10:56 pm
RadoTD
  • 513
    Stage WTF
« Reply #7 on: September 22, 2011, 06:10:56 pm »
Yeah... both of the replies above me implied pulling the trans apart.
30mm socket is not needed, you don't have to pull the axle out on that end.
17mm sockets, shallow and deep, wobble extension or u joint and extension for whatever size your 17mm socket is.
13mm socket
8mm triple square
spare jack
Uhh, I think that's it  ???
Reply #8September 25, 2011, 07:57:42 am
« Reply #8 on: September 25, 2011, 07:57:42 am »
You have to take the drivers side axle out don't you? At any rate, I like the extra room it gives you.
Reply #9September 25, 2011, 09:30:52 am
RadoTD
  • 513
    Stage WTF
« Reply #9 on: September 25, 2011, 09:30:52 am »
Ok... I've never had to, that might make be easier though! I just avoid that 30mm nut as much as I can
Reply #10September 25, 2011, 09:39:10 am
« Reply #10 on: September 25, 2011, 09:39:10 am »
i dont touch either. i drop the ball joint bolt, and swing the hub and axle out of the way..
