Author Topic: throttle bushing AAZ  (Read 4837 times)
May 27, 2011, 03:02:42 pm
paolomarks
  • 146
« on: May 27, 2011, 03:02:42 pm »
I started my 1996 AAZ today after a complete rebuild and the Injection pump leaks from the throttle shaft bushing/ o ring.  Where can I find a throttle shaft bushing for an AAZ pump.? They're quite a bit taller than the 1.6 pump I understand.  Thanks, Paolo
also looking for a harmonic balancer for the same engine, mine's got quite a wobble.  Thanks.
Reply #1May 28, 2011, 03:43:01 am
macka
  • 957
Re: throttle bushing AAZ
« Reply #1 on: May 28, 2011, 03:43:01 am »
Giles at performance diesel will more then likely have the O ring. Check the Samba for the balancer.
Quote from: Vincent Walden
Reply #2May 28, 2011, 06:33:40 am
paolomarks
  • 146
« Reply #2 on: May 28, 2011, 06:33:40 am »
Thanks for the response.  I'd like to replace the throttle bushing as well as the o ring. Think Giles will have one of those as well. Paolo.
Reply #3May 28, 2011, 12:40:08 pm
Quantum TD
  • 1195
« Reply #3 on: May 28, 2011, 12:40:08 pm »
You can get a new balancer for about $70 new online. It's the same one used on the 1997-1998 TDIs. Might also be the same as the more-recent ALH motors too.
Keep an eye on that balancer. After you replace it, you may still have wobble. Be sure to change the alternator pulley to the clutched one if you haven't yet.
You may find that the wobble starts in the crank sprocket. Good luck with that.
Reply #4May 29, 2011, 04:34:39 pm
paolomarks
  • 146
Re: throttle bushing AAZ and harmonic balancer
« Reply #4 on: May 29, 2011, 04:34:39 pm »
Hello quantum TD  ,  I've looked around without luck for a new harmonic balancer.  Can you direct me to a site where I can get one and also a clutched alternator pulley.  The part no. on my old balancer is 028 105 243 r.  It's off a 96 golf AAZ.  Thanks in advance, Paolo
Reply #5May 31, 2011, 07:37:07 pm
paolomarks
  • 146
« Reply #5 on: May 31, 2011, 07:37:07 pm »
I found the harmonic balancer pulley and the alternator clutched pulley. Still looking for a throttle bushing for an AAZ Injection Pump.  Also, do I need special tools to put on the clutched alt pulley?  Thanks, Paolo
Reply #6June 02, 2011, 08:20:56 am
paolomarks
  • 146
« Reply #6 on: June 02, 2011, 08:20:56 am »
Any body? thanks, Paolo
Reply #7June 08, 2011, 03:45:27 pm
paolomarks
  • 146
« Reply #7 on: June 08, 2011, 03:45:27 pm »
I'm still looking for a throttle bushing for my 1996 aaz's injection pump.  Can you still get these. ? does anyone out there have a good spare I can buy?  Let me know soon, my pumps crying like a baby!  Thanks, Paolo
Reply #8June 08, 2011, 11:41:51 pm
  • 2932
« Reply #8 on: June 08, 2011, 11:41:51 pm »
 Call your local bosch service center and give them your pump part number.
There is a locator somewhere on the internet.
