Author Topic: prothe 155 BAR injectors  (Read 9689 times)
Reply #15April 04, 2011, 02:28:19 pm
  • 3468
    • McScrubbins Body Wash
Re: prothe 155 BAR injectors
« Reply #15 on: April 04, 2011, 02:28:19 pm »
I also got injectors from germanautoparts.com
they seem to be working well.
Those return nipples are brittle as all hell though.
Reply #16April 04, 2011, 09:17:42 pm
dankcorey22
  • 379
    Cummins!
    • Anything that runs
MY CARs-BLACK 99.5 Jetta TDI 5 speed 93,000- DC Stage 2 Clutch Kit 14Lb FW, Afe air intake box, 2.5" DP, 11mm IP, 2.5" stright piped, boost gauge, PP764, RC5 (WOW), 3-Bar, McNally EGT/Boost, 17/22, Race Pipe, EGR Cooler Delete, PD lift pump, R32 MAF housing,FMIC
1983 VW Jetta 1.6 turbo fuel mods
Reply #17April 05, 2011, 06:51:58 pm
Baron VonZeppelin
« Reply #17 on: April 05, 2011, 06:51:58 pm »
Prothe moves a lot of products.
Suppose there is no way he himself could inspect every incoming shipment of restock from china. Or quality control every outgoing sale of product.
But as fate kind of has it now, he missed a golden opportunity at a chance for some Good Publicity on these Injectors.
He might have a whole pallet crate full of these new rejects.
Ouch
Reply #18April 05, 2011, 09:12:09 pm
dankcorey22
  • 379
    Cummins!
« Reply #18 on: April 05, 2011, 09:12:09 pm »
He did tell me when i emailed him about those injectors, i asked him to check all of the ones he had.
He said all of the ones he had in stock were like that. Including the 155 TUNING ??? ones... whatever they are lol
Reply #19April 06, 2011, 04:47:22 am
Mark(The Miser)UK
  • 1557
« Reply #19 on: April 06, 2011, 04:47:22 am »
Are you saying they have no hole? The picture is too blurred.
I used to think that nozzles came with the torus/doughnut shape built in; but then I'd never seen a new one, something I've delayed for years on the basis of the quality issue after France stopped making them for Bosch.
All mine were rescues from breakers.
I recently imported some [4] new old stock ones from Canada, sealed in 'jelly'.
 Alas I managed to break one rear prong [never done that before] and one needle seems too slack in the holder.
So perhaps quality went down in France towards the end,  so I still have never had a brand new set in my Quantum
Turkey makes some apparently :o
Mark-The-Miser-UK
Reply #20April 06, 2011, 09:28:33 pm
dankcorey22
  • 379
    Cummins!
« Reply #20 on: April 06, 2011, 09:28:33 pm »
im saying that the nozzle part of the injector look as if there was no holes where the nipple sticks out. Im used to seeing even a little holes. I guess my vision is getting worse  8) lol
Im thinking there was a blank nozzle in there. so he would want customers to buy the nozzles separate but IDK i could be wrong. it doesnt matter anymore ive sent them back
Reply #21April 07, 2011, 01:30:50 am
Mark(The Miser)UK
  • 1557
« Reply #21 on: April 07, 2011, 01:30:50 am »
H'mm if there were no hole then the needle tip would be broken off too. ... Yeah my eyesight is starting to play up too, just as I'm building my library in my attic.
 Low energy light bulbs and comp screens doing my peepers in IMO :(
Mark-The-Miser-UK
Reply #22April 10, 2011, 05:30:01 pm
Digital K
  • 58
« Reply #22 on: April 10, 2011, 05:30:01 pm »
I think ill go the route of AutohausAZ ive bought alot from them and the quality is there for sure!
39 dollars isnt bad at all. http://www.autohausaz.com/search/product.aspx?sid=die1wj55tkcbilvhwkpecc45&makeid=800026@VW&modelid=1282700@JETTA%20DELUXE%20TDI&year=1983&cid=22@Fuel%20%26%20Air%20System&gid=11167@Diesel%20Injector
when i order them probably next week ill let every one know what the pop pressure and spray pattern are. Im sure they both will be on point.
bump from the dead kinda? do these work for my diesel? 1.9TD AAZ? Im having trouble finding specific information.
« Last Edit: April 10, 2011, 05:35:13 pm by Digital K »
Reply #23April 11, 2011, 12:25:33 am
Digital K
  • 58
« Reply #23 on: April 11, 2011, 12:25:33 am »
nobody?
Reply #24April 11, 2011, 05:07:47 am
« Reply #24 on: April 11, 2011, 05:07:47 am »
No they wont
Reply #25April 11, 2011, 10:07:54 am
Baron VonZeppelin
« Reply #25 on: April 11, 2011, 10:07:54 am »
The AAZ injectors were originally a dual stage.
I forgot why tho.
Not sure if you can even still get the dual stage ones now.
I'm gonna think you could use 1.6 TD injectors, but might not be completely optimal.
One thing to try - go on AutohausAZ website - plug in your car data - and see if they offer Reman'd Bosch injectors for it.
Another thing to try is to email or call Giles at Performance Diesel in Markham Ontario and get his wisdom/verdict about it. If you need his contact info it is listed in the vendor section of this forum.
You could also inquire the cost to have him rebuild your old ones.
« Last Edit: April 11, 2011, 10:09:58 am by Baron VonZeppelin »
Reply #26April 11, 2011, 10:22:31 am
« Reply #26 on: April 11, 2011, 10:22:31 am »
I forgot why tho.
the injection lines on an AAZ are for really tall injectors.. they wont fit on the 1.6 injectors..
Reply #27April 11, 2011, 10:32:29 am
Baron VonZeppelin
« Reply #27 on: April 11, 2011, 10:32:29 am »
Good info ROR.
Digi K, if you had a couple versions of 1.6 lines laying around - you "might" could find a version of bends that would allow the swap to 1.6 injectors. And thats just a wild shot in the dark.
Or maybe 1.9 NA lines.
idunno
Reply #28April 11, 2011, 10:59:53 am
Digital K
  • 58
« Reply #28 on: April 11, 2011, 10:59:53 am »
Good info ROR.
idunno
how do I get ahold of giles. his site is down.
Reply #29April 11, 2011, 11:37:19 am
« Reply #29 on: April 11, 2011, 11:37:19 am »
