Author Topic: prothe 155 BAR injectors  (Read 9747 times)
March 30, 2011, 09:52:03 am
dankcorey22
  • 379
    Cummins!
    • Anything that runs
« on: March 30, 2011, 09:52:03 am »
I ordered 4 injectors from http://www.hansdieselparts.com/16TDInjector.htm
The injectors i got, all 4 of them had one return nipple on them.
Then the nozzle looked like it wasnt even a real nozzle just a blank
Has anyone else ordered these and had this problem?
MY CARs-BLACK 99.5 Jetta TDI 5 speed 93,000- DC Stage 2 Clutch Kit 14Lb FW, Afe air intake box, 2.5" DP, 11mm IP, 2.5" stright piped, boost gauge, PP764, RC5 (WOW), 3-Bar, McNally EGT/Boost, 17/22, Race Pipe, EGR Cooler Delete, PD lift pump, R32 MAF housing,FMIC
1983 VW Jetta 1.6 turbo fuel mods
Reply #1March 30, 2011, 10:02:46 am
punkvideo81
  • 168
Re: prothe 155 BAR injectors
« Reply #1 on: March 30, 2011, 10:02:46 am »
Search prothe on the different vw forums and you will see he has a spotty record for quality from many customers. I used germanautoparts.com for my engine parts and had no issues. Good luck.
'81 Caddy 1.6 TD
Reply #2March 30, 2011, 10:09:23 am
Quantum TD
  • 1195
« Reply #2 on: March 30, 2011, 10:09:23 am »
That's effing awesome!
Reply #3March 30, 2011, 10:21:44 am
maxfax
  • 2126
« Reply #3 on: March 30, 2011, 10:21:44 am »
Good thing for that 2 year guarantee ???
Reply #4March 30, 2011, 11:12:36 am
dankcorey22
  • 379
    Cummins!
« Reply #4 on: March 30, 2011, 11:12:36 am »
Thats why i tried him cause his 2 year guarantee plus some people has had good luck with his injectors
Reply #5March 30, 2011, 11:27:46 am
« Reply #5 on: March 30, 2011, 11:27:46 am »
i guess install them and see how they run?
Reply #6March 30, 2011, 11:31:27 am
Baron VonZeppelin
« Reply #6 on: March 30, 2011, 11:31:27 am »
Holy crapola Corey ... those are really a bad joke.
Must be a fresh batch of rejects.
No one else has spoken of those characteristics before.
Bosch nozzles have gone up almost double and triple at most suppliers. They were $10 each for long time. I think one place still has them for $15. Can you pop test injectors at your tech school - and rebuild your old ones ?
You can make 130-135 injs into 155 with proper shims
You'd have to use some creative plumbing with a handful of T's to run those single spouts. But the nozzle looks like a solid piece with a nipple protrusion ... lmao
Reply #7March 30, 2011, 11:43:40 am
jseeley
  • 106
« Reply #7 on: March 30, 2011, 11:43:40 am »
return/exchange em... not sure how you can make it work with only one return. I have a set of the 135  bar versions with no issues.
*edit-> I guess you try some combination of "t" connectors and you could run em as Baron said, 1->2->4 ?
« Last Edit: March 30, 2011, 11:53:07 am by jseeley »
85 Golf Diesel 1.6 NA 240K miles? (odometer broken)
87 Cabriolet 1.8 Gasser 104K miles
05 Golf 2.0 Gasser 66k miles
03 Jetta Wagon TDI 112k Miles
Reply #8March 30, 2011, 05:10:43 pm
maxfax
  • 2126
« Reply #8 on: March 30, 2011, 05:10:43 pm »
Momma always says buying from Prothe is like a box of chocolates..
Reply #9March 30, 2011, 05:31:14 pm
dankcorey22
  • 379
    Cummins!
« Reply #9 on: March 30, 2011, 05:31:14 pm »
Haha some stuff from prothe is a joke lmao...  IDK! I think im going to return them and get the injector from somewhere else. The only reason i dont pop test them at my tech school is because i dont have the right shims to put in the injector. I have one 155 BAR the rest are 135 BAR.
Where is a well known high quality place to buy these 155 BAR injectors?
Thanks everyone for feedback
Reply #10March 30, 2011, 06:28:11 pm
Baron VonZeppelin
« Reply #10 on: March 30, 2011, 06:28:11 pm »
I don't think Bosch has started offering the 155's new again ... Yet.
They have brought the 130-135's back new, recently. (about 80-100 each)
Last check, AutohausAZ and Partsgeek offered reman'd Bosch 155's for around 40 each - plus a core charge.
A good Bosch authorized fuel shop can rebuild whatever you have into 155's with new Bosch nozzles for about 30-40 each. Depending what they charge for the nozzles now - might be higher. You might be better to supply them the nozzles basing on their price quotes ... its a gamble though i guess. Some rumors of hit/miss nozzles now being made in India for Bosch.
One thing about them doing them and supplying the nozzles too - less hassle if a nozzle has a bad spray pattern/defect. They just pull another one from stock and you don't have to bother with returns etc...
If you can pop test and spray test at tech school, reman'd Bosch from AhAZ or Pgeek is probly worth considering.
Reply #11March 30, 2011, 08:54:15 pm
dankcorey22
  • 379
    Cummins!
« Reply #11 on: March 30, 2011, 08:54:15 pm »
I think ill go the route of AutohausAZ ive bought alot from them and the quality is there for sure!
39 dollars isnt bad at all. http://www.autohausaz.com/search/product.aspx?sid=die1wj55tkcbilvhwkpecc45&makeid=800026@VW&modelid=1282700@JETTA%20DELUXE%20TDI&year=1983&cid=22@Fuel%20%26%20Air%20System&gid=11167@Diesel%20Injector
when i order them probably next week ill let every one know what the pop pressure and spray pattern are. Im sure they both will be on point.
Reply #12April 03, 2011, 10:38:13 am
ToddA1
  • 434
« Reply #12 on: April 03, 2011, 10:38:13 am »
I'm running injectors from thedieselstore.com.  No core unless you don't return your's and they also pay return shipping.
-Todd
Reply #13April 03, 2011, 12:51:39 pm
dankcorey22
  • 379
    Cummins!
« Reply #13 on: April 03, 2011, 12:51:39 pm »
Those injectors are NA injectors only 135 BAR
Thanks anyways man
Reply #14April 03, 2011, 02:16:34 pm
ToddA1
  • 434
« Reply #14 on: April 03, 2011, 02:16:34 pm »
They say they rebuild them inhouse, so maybe they'd be willing to recalibrate a set, to order.
-Todd
