Author Topic: Ring & Pinion, Transmission Gear Sources.  (Read 3101 times)
March 19, 2011, 05:30:57 am
ein bora
  • 377
« on: March 19, 2011, 05:30:57 am »
I am going to want to change the gearing on my gas to diesel idi passat project, as it turns out that I am going to have to use the passat's transmission. Does any body know if transmission gears and or ring&pinion sets are available aftermarket for vw's??
Thanks.
If you can't take advice - then you can't be helped!
Reply #1March 19, 2011, 06:48:14 am
Re: Ring & Pinion, Transmission Gear Sources.
« Reply #1 on: March 19, 2011, 06:48:14 am »
I believe VW motorsport has some. Also if it is 020 brian at brokevw has many gear sets and will sell them.
Reply #2March 19, 2011, 07:16:56 am
ein bora
  • 377
« Reply #2 on: March 19, 2011, 07:16:56 am »
I believe it's a EZG. The motor is mounted longitudinally so it's not your typical transmission. I wonder though if any parts are interchangeable as the final drive ratio is - 3.70, on ours it's something like - 3.67. But we have a fifth gear ratio of 0.75 where as the passat has - 0.84. Not sure what the difference will be rpm wise with the idi installed, therein lies the dilemma.
Thanks.
Reply #3March 19, 2011, 03:53:01 pm
« Reply #3 on: March 19, 2011, 03:53:01 pm »
3.70 is a lower r/p than most other vw diesels ever got. Only a few got the 3.67 trans.. Most got the 3.89. So the 3.70 is all good in the hood.
Even the .84 fifth might be alright.. That gear on a normal size tire will net you 2800 rpms at 100 km/h. Still not too bad.
Reply #4March 19, 2011, 06:23:29 pm
GEE-BEE
  • 1604
« Reply #4 on: March 19, 2011, 06:23:29 pm »
paid 105.00 each for two new 3.67 R & P
Ebay
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #5March 19, 2011, 07:44:51 pm
ein bora
  • 377
« Reply #5 on: March 19, 2011, 07:44:51 pm »
Thanks for the info
Reply #6March 20, 2011, 12:54:56 pm
rallydiesel
  • 1880
« Reply #6 on: March 20, 2011, 12:54:56 pm »
I have never seen a source of new transmission internals, but that doesn't mean they don't exist. I have bought "hard" parts (gears, shafts, etc.) from Gary Zink. He often posts ads on The Samba. He was very good to deal with and good prices. He owns a transmission shop in Washington state and specializes in VW transaxles.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
