Author Topic: mk2 GTD - loose wires and broken down...  (Read 4747 times)
March 16, 2011, 08:14:42 am
robst3
  • 4
« on: March 16, 2011, 08:14:42 am »
Hi everyone, i've recently purchased a mk2 Golf GTD (intercooled 1.6TD, engine code 'SB')
I've changed the timing belt and set the timing using this guide: http://vincewaldon.com/index.php?option=com_content&task=view&id=24&Itemid=28
Ran great, but then it suddenly cut out whilst I was doing 75mph on the motorway after covering about 190 miles.
I've found one of the 13mm bolts on the pump was loose so i'm guessing the pump moved causing timing to go out.
Also found this loose between the block and pump:
IMAG0082 by robst3, on Flickr
Have I put it back on right?:
IMAG0089 by robst3, on Flickr
These two wires also had one end loose, does anyone know where they are meant to go?
IMAG0083 by robst3, on Flickr
IMAG0091 by robst3, on Flickr
Finally my pump looks like its missing the black shock absorber type thingy that attaches to the red circled bits here:
image1 by robst3, on Flickr
Is it important? Cheers
« Last Edit: March 16, 2011, 08:16:25 am by robst3 »
Reply #1March 16, 2011, 01:00:19 pm
rabbitman
  • 2788
Re: mk2 GTD - loose wires and broken down...
« Reply #1 on: March 16, 2011, 01:00:19 pm »
Don't know about the shock absorber thingy.
That black wire should have 12v with the key in the *run* position and no power when it's off. It looks like that wire came apart which has the same affect as turning off the key.
Reply #2March 16, 2011, 01:13:10 pm
robst3
  • 4
« Reply #2 on: March 16, 2011, 01:13:10 pm »
Thanks. So those 2 wires should be joined together? Will test with a meter tomorrow to double check.
Found a few other wires that were brittle and had been bodged together so going to fix them too.
Reply #3March 16, 2011, 01:34:29 pm
  • 3255
    • My collection of HOWTOs
« Reply #3 on: March 16, 2011, 01:34:29 pm »
The shock absorber thingie is the linkage that gives you fast idle when you pull out the cold-start handle.
From the picture it looks like it's installed properly... the true test is:  does your idle increase when you pull out on the cold-start handle?!    ;)
You twist the top of it to adjust idle speed.
Reply #4March 16, 2011, 03:05:50 pm
robst3
  • 4
« Reply #4 on: March 16, 2011, 03:05:50 pm »
Thanks vincent, and thanks also for the great guide - made timing an engine for the first time a breeze!
This is what I meant by the shock absorber thingy:
IMG_1592 by robst3, on Flickr
(pic of someone else's engine)
Reply #5March 20, 2011, 12:53:44 am
Smokey Eddy
  • 3468
    • McScrubbins Body Wash
« Reply #5 on: March 20, 2011, 12:53:44 am »
I wouldn't worry about it.
Ed
Reply #6March 20, 2011, 01:02:13 am
  • 3255
« Reply #6 on: March 20, 2011, 01:02:13 am »
Ah... *that* shock-absorber thingie... yup, safely deleted.
Reply #7March 28, 2011, 02:02:07 am
smutts
  • 720
    ClackClackClackClackClack
« Reply #7 on: March 28, 2011, 02:02:07 am »
The black thingy, toss it into the box with the chocolate teapots, self adjusting clutch cable, windows ME disc, fuel magnets and whatnot. ;D
