Author Topic: How do you survive in your mk1 rabbit/golf in the winter?  (Read 13616 times)
December 14, 2010, 06:51:23 pm
erice1984
  • 263
« on: December 14, 2010, 06:51:23 pm »
How does anyone survive in their mk1 Rabbit/Golf ?
I thought I could do this but the 1.5D doesn't heat up fast enough and the insulation inside the car sucks!
It is 0 degrees here and I have the defrost on so I can see out the windows, it doesn't heat the window up enough to melt the ice my scraper couldnt get to.
Help please!  I don't want to sell this car just to get another "headache"
1980 Rabbit 1.9TD
Reply #1December 14, 2010, 09:03:29 pm
  • 2931
Re: How do you survive in your mk1 rabbit/golf in the winter?
« Reply #1 on: December 14, 2010, 09:03:29 pm »
Cardboard in front of the radiator.
Bubblewrap under the door cards.
Does it have a temp gauge? Is it getting up to temp on the highway?
Under 18F in stop and go traffic, it's common to lose engine temp.
Reply #2December 14, 2010, 09:36:21 pm
maxfax
  • 2126
« Reply #2 on: December 14, 2010, 09:36:21 pm »
All of the above, a good thermostat and a block heater..  If I'm somewhere that I can;t plug that in I have one of those 12v window defroster things that plug into the cig lighter..  Not real fast, but it helps..
I was (I suppose) fortunate enough to need a new headliner so while that was down I added some extra insulation to the roof as well..
Unfortunately, I'd still advise having a good winter coat..  :-\
Reply #3December 14, 2010, 09:38:26 pm
AudiVWguy
« Reply #3 on: December 14, 2010, 09:38:26 pm »
What he said.
What degree thermostat do you have installed?
Check for small air leaks in the firewall.
Make sure the heater air controls are actually working.
Cheers,
-JB
Reply #4December 15, 2010, 02:08:05 pm
Wessty
  • 16
    Qunte area Ontario
« Reply #4 on: December 15, 2010, 02:08:05 pm »
My past experience with my 82 diesel pickup, have been good.   Good clean cooling system, reasonably few miles on a total engine rebuild.  I've used it at -35C and had no issues with adequate heat or windshield frosting.
82 LX Caddy 1.6 IDI 5 spd
84 Rabbit 1.6 IDI 4 spd  (not running)
Reply #5December 15, 2010, 02:34:23 pm
erice1984
  • 263
« Reply #5 on: December 15, 2010, 02:34:23 pm »
my thermostat is a Wahler 80*C from autohausaz.com 056121113A
I need a new door seal or a larger one on my driver door
Does anyone have problems with door seals fitting correctly ?  I noticed my door has a washer between the hinge and mount on the frame so the door closes and latches easier.  I suspect because of the chassis sagging or hinges bending over time...  In this case would it be worth it to get a new door seal or not bother because they are $50.  Although I can tell I lose a lot of heat because of the door seal.
Yeah I do have a few grommets that could be replaced on the firewall by my feet.
1980 Rabbit 1.9TD
Reply #6December 15, 2010, 07:04:55 pm
« Reply #6 on: December 15, 2010, 07:04:55 pm »
Get it sealed up. The GTI that came from was warm, but the fan and resistor was junk. Also X 10 on the cardboard in front of the rad, it helps a ton.
Reply #7December 15, 2010, 07:54:06 pm
erice1984
  • 263
« Reply #7 on: December 15, 2010, 07:54:06 pm »
Yeah, I should do the cardboard until I find enough stuff to order to get free shipping from autohausaz
how about this?  I never knew this existed but seems the piece I am missing on my door.
http://cgi.ebay.com/ebaymotors/Vw-Mk1-Rabbit-Jetta-Caddy-Upper-Door-Seals-NEW-_W0QQcmdZViewItemQQhashZitem3347adc128QQitemZ220245901608QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
1980 Rabbit 1.9TD
Reply #8December 15, 2010, 08:27:01 pm
« Reply #8 on: December 15, 2010, 08:27:01 pm »
not bad idea. I think the ones on the GTI were OK, not the best. I would send them to you for $5 plus shipping if you don't want new.
Reply #9December 15, 2010, 08:36:16 pm
erice1984
  • 263
« Reply #9 on: December 15, 2010, 08:36:16 pm »
Hrmm.
I think I am more convinced that I need both those seals, the main door one and the upper seal we already spoke of.
1980 Rabbit 1.9TD
Reply #10December 15, 2010, 11:00:31 pm
Rabbit79
  • 196
    Burns, Oregon,USA
« Reply #10 on: December 15, 2010, 11:00:31 pm »
I get alot of cold air coming through those fresh air vents on each end of the dash. I never have torn into them to look where the air is coming through cause I'm just a little too lazy sometimes. Most of the time it's not a bother, but when it gets really cold out I notice it. As a temporary expedient I just duct taped them. Not very pretty to be sure, but it did get the job done. Be thankful you're not air cooled, on my old 70 Bug I had when I was a teenager I carried a window scraper to scrape the inside of the windows while I was driving, and had to do that pretty much constantly.   :)
Oh and before anyone bashes on me, yes, I do have the handles in the closed position.
« Last Edit: December 15, 2010, 11:17:02 pm by Rabbit79 »
Current: 1979 Rabbit 4dr
            1984 F-250
            1999 Ford Ranger
Other v-dubs I've owned:
84 Rabbit
78 Rabbit (gasoline) flipped it end over end after driving all night and falling asleep at the wheel. RIP, it was a good little car.
70 Bug
Reply #11December 16, 2010, 05:24:50 am
« Reply #11 on: December 16, 2010, 05:24:50 am »
Also, I forgot one, on the GTI you got the parts from it had vents in the door cards. I think to help it close and not be airtight, maybe to just vent. Either way they would let tons of cold air in all at floor level. I took them out and duct taped them from the inside and reinstalled them.
Reply #12December 16, 2010, 11:37:55 am
erice1984
  • 263
« Reply #12 on: December 16, 2010, 11:37:55 am »
Yeah, mine didnt have any plastic sheeting behind the doors.  I got some 4mil or 6mil plastic from homedepot and put it on there.  I used butyl rubber glue stuff on one door and headliner spray adhesive on the other door.  I think the door with spray adhesive turned out better, and cleaner.  If I need to get behind there I don't have to fight the uber sticky mess of butyl rubber.
1980 Rabbit 1.9TD
Reply #13December 16, 2010, 11:52:17 am
« Reply #13 on: December 16, 2010, 11:52:17 am »
Yup, a hotter t-stat would be better. And X2 on the cardboard keeping air off the engine ;D
I have those upper door seals but having never driven without 'em I can't comment on if it actually helps.
At about -20F or colder I can't keep the side windows clear but the windshield isn't a problem.
I'd try the bubble wrap, I have an aux heater and the stock heater and after it's comfortable inside I can still feel cold air on my arm by the door.
Reply #14December 16, 2010, 12:06:45 pm
erice1984
  • 263
« Reply #14 on: December 16, 2010, 12:06:45 pm »
Yeah, I should have done the math from the get go on the tstat.  80C (176F) is definately on the colder side for ANY engine.  Every other tstat I have seen is 195F and 180 is the colder option, like say you use the vehicle to tow stuff frequently.
1980 Rabbit 1.9TD
