Author Topic: How do you survive in your mk1 rabbit/golf in the winter?  (Read 13632 times)
Reply #15December 16, 2010, 10:34:20 pm
  • 2931
Re: How do you survive in your mk1 rabbit/golf in the winter?
« Reply #15 on: December 16, 2010, 10:34:20 pm »
The air from the side vents in a Rabbit is always outside temp.
Unless you do the mod that makes them push out whatever the center vents are set at.
 Having warm air on my left leg when driving is great,
 because over by that door can get cold.
 It can also be aimed at the side window to help clear that.
Reply #16December 16, 2010, 11:08:20 pm
« Reply #16 on: December 16, 2010, 11:08:20 pm »
Also, I forgot one, on the GTI you got the parts from it had vents in the door cards. I think to help it close and not be airtight, maybe to just vent. Either way they would let tons of cold air in all at floor level. I took them out and duct taped them from the inside and reinstalled them.
should be a rubber flapper on the other side of the vent to make it a one way valve basically. to let air out, but not let cold air back in.
Reply #17December 17, 2010, 08:10:00 pm
« Reply #17 on: December 17, 2010, 08:10:00 pm »
i have only ever driven mk1 diesels, i always thought they warmed up pretty quickly and then eventually got too hot.
Reply #18December 17, 2010, 08:22:31 pm
« Reply #18 on: December 17, 2010, 08:22:31 pm »
I have driven mk1's as winter cars for the last 4 years (as I am only 20 ;)) it has been a gasser 1.7... But I have a 1.6D I drove last year (spring to fall) and its sitting in my driveway now.. I started it up last week in the 5F cold snap we had, and had the ice melting on the windshield with minutes of just idling! I think it possibly "warmed" up quicker than my 1.7 Gas did.. not producing HOT heat, but it was warmer than the 5F outside lol and enough to melt the ice layer the windshield had.
On just the mk1 basic of winter survival.. Being in Canada, I don't go anywhere in the winter without a GOOD coat on and boots.. shoes never touch my feet with snow on the ground (except at work obviously lol) as I have been stranded in a snow storm before.. the one time my mk1 lets me down! New years eve 930pm middle of NOWHERE! literally a 25min drive to any sort of civilization.
COAT BOOTS AND HAT ;)
Reply #19December 18, 2010, 10:51:39 am
« Reply #19 on: December 18, 2010, 10:51:39 am »
Just the other day I stood by the road while my leaky tire was pumping back up, I always look at the tires when it's cold out (they like to go flat then) and this one tire went flat three times in about two weeks shortly after getting on the road. Oh yeah, all week it's been -30 to -50 F, one day it hit -20 for a short time and then dropped again.
I wear my winter gear when it's this cold......except for my bunny boots, they don't really fit in the pedals very good.
Reply #20December 19, 2010, 05:52:43 pm
« Reply #20 on: December 19, 2010, 05:52:43 pm »
where do you live
Reply #21December 21, 2010, 10:07:06 am
Reply #22December 21, 2010, 12:36:39 pm
rallydiesel
  • 1880
« Reply #22 on: December 21, 2010, 12:36:39 pm »
Try this:
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #23December 21, 2010, 02:14:00 pm
erice1984
  • 263
« Reply #23 on: December 21, 2010, 02:14:00 pm »
lol..  thats a nice lookin' marshmallow suit there
1980 Rabbit 1.9TD
Reply #24December 21, 2010, 02:38:33 pm
GEE-BEE
  • 1604
« Reply #24 on: December 21, 2010, 02:38:33 pm »
I make the seals for them...
I just did 5000 ft of upper door seal, my original sample ( MK1 )
Adjust your door pin's for better fitment
use 3m 1300L cement
Email me for the family price
[email protected]
GB
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #25December 21, 2010, 04:44:02 pm
erice1984
  • 263
« Reply #25 on: December 21, 2010, 04:44:02 pm »
How do you adjust the doors?  I noticed there was a washer in between the mount on the body and the hinge. to get the door to come up and latch well.  Is there another way?  Like adjusting the strike pin?
1980 Rabbit 1.9TD
Reply #26December 22, 2010, 06:34:15 pm
« Reply #26 on: December 22, 2010, 06:34:15 pm »
Both are adjustments, I doubt the washers method is in the bentley though.
