Author Topic: Custom Intercooler's ( Based on 675 MM Radiator )  (Read 8614 times)
November 07, 2010, 03:34:16 pm
GEE-BEE
  • 1604
« on: November 07, 2010, 03:34:16 pm »
I have some more info to share on the custom intercooler that cant bolt onthe front of the 675MM scirocco radiator.
Lower Hose for this is radiator fitment:
Scirocco 16 v a/c model 533121051A
Upper hose is the non a/c Diesel jetta hose:191121101Q
I make both now in Silicone..
Working psi 30 psi
It can be mfg' with outlets on the top, middle or bottom
Outlets on each side, ( 2') RH to LH flow
Sizes are:
18 x 6.4 x 2.25 thick , $ 553.00
22 x 6.4 x 2.25 thick, $$ 619.00
26 x 8.5 x 1.25 thick, $$$ 885.00 ( cover's most of the 675 mm )
They can be made to order with your size of outlet's
I will do the larger of course ....
I will install a MKIII Dual fan and add a remote fan swith to draw air in on command ( Jetta Dash )
Remember you get what you pay for, these are U.S. made Intercoolers and I would rather support a company here.
GB
Bellintercooler.com
« Last Edit: November 09, 2010, 07:48:26 am by GEE-BEE »
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #1November 07, 2010, 03:37:26 pm
Re: Custom Intercooler's ( Based on 675 MM Radiator )
« Reply #1 on: November 07, 2010, 03:37:26 pm »
at those prices, im sure you will be the only person owning one of those..
most of us get by with the under 100 dollar ebay units..
550 bucks for the cheapest one? WTF, do they hand make every single piece of the intercooler...
Reply #2November 07, 2010, 03:42:54 pm
GEE-BEE
  • 1604
« Reply #2 on: November 07, 2010, 03:42:54 pm »
Yes they are made to order, have you seen the size of the new MKV GTI intercooler on the 2.0 T
33 x 33 1.50 thickness with 2.25 outlet's
I have all my tubing done , last will be powdercoat satin black, all transitions red
There is another caddy owner out of TX who did the same, went with the smaller unit on his aaz
Stay Tuned...
GB
« Last Edit: November 07, 2010, 03:44:26 pm by GEE-BEE »
Giles Pump OHC
MK1 JETTA DASH
Reply #3November 07, 2010, 03:49:52 pm
Quantum TD
  • 1195
« Reply #3 on: November 07, 2010, 03:49:52 pm »
Stay Tuned...
GB
Seriously, how much money do you have in your truck? $20K, $30K? $40k?
At those prices, I'd rather be in a new TDI sporwagen or import an Amarok  ::)
Reply #4November 07, 2010, 04:44:23 pm
Syncroincity
  • 727
« Reply #4 on: November 07, 2010, 04:44:23 pm »
Well said, Andrew! Don't bring the guy down for making top quality stuff and charging appropriately, Guy puts together items with aircraft-level specs, which some of us appreciate. :-*
JC McCavitt
'86 Syncro GL Camper AAZ
'98 Jetta Wolfie
'04 Passat Variant GLS 4Mo 5MT
Reply #5November 07, 2010, 06:58:02 pm
« Reply #5 on: November 07, 2010, 06:58:02 pm »
Too spendy for me right now, but would love to see the pictures of the final result!
Reply #6November 07, 2010, 09:05:17 pm
Quantum TD
  • 1195
« Reply #6 on: November 07, 2010, 09:05:17 pm »
Criticizing someone for having excess money or spending it (or having anything you yourself would enjoy having...) is extremely strange, IMO.
My point, if there is one that anyone would care to hear it, is that there is a dramatic disconnect between the OP and about 99% of the users here. When the first reply to any newbie thread asking a ANY question about ANY aspect of IDI motors is to spend $300-1000 on the ideal (usually brand new and/or exotic) part and have it powdercoated, is not useful advice for people who probably only paid $300-1000 for the car in the first place, and whose main purpose in buying a diesel VW is for economical reasons.  It's all a bit gauche in my mind.
If you're selling something, become an advertiser and list items with prices for sale. If on the other hand, you're so proud of how much money you spent (and continue to spend) on your build, make a  build thread with prices on every goodie on your car, instead of constantly reminding us each time you post:
http://www.vwdiesel.net/forum/index.php?topic=25255.0
http://www.vwdiesel.net/forum/index.php?topic=26620.msg217642#msg217642
http://www.vwdiesel.net/forum/index.php?topic=27223.msg220646#msg220646
http://www.vwdiesel.net/forum/index.php?topic=27473.0
http://www.vwdiesel.net/forum/index.php?topic=27432.msg223067#msg223067
http://www.vwdiesel.net/forum/index.php?topic=27386.msg222703#msg222703
http://www.vwdiesel.net/forum/index.php?topic=26705.msg216162#msg216162
http://www.vwdiesel.net/forum/index.php?topic=26694.msg216161#msg216161
http://www.vwdiesel.net/forum/index.php?topic=26015.msg216332#msg216332
http://www.vwdiesel.net/forum/index.php?topic=26735.msg216695#msg216695
We've got it. You have a South African rad support and powdercoated everything, which is all made of unobtanium and was spanking new when your bought it from ebay.de.
While I applaud the OP for his initiative in fabricating parts that are either obsolete, prohibitively expensive, or difficult to fabricate or source, I'm having a bit of trouble believing that there is not an element of grandstanding to the "price-dropping" in every other post.  Is that against "the rules"? No. But it personally leaves a bad taste in my mouth, and I rarely see people exhorting us with what they paid for something, unless they got a helluva deal on it (usually whole cars, and usually under $1k). Even in the most obvious, spendy build thread (53 willys), I don't think there's a single mention of cost on anything, even though anyone can tell a chunk of change went into it. In my mind, that's tasteful. We can see the dedication and care that went into the car, without being reminded that we'll probably never attempt or afford to build it.
Maybe it's just me, or maybe I'm not the only one. But I'll be the a$$hole and throw myself on the sword by being the one to say it. Or, just be an a$$hole. You decide.
I don't know the OP, have never dealt with him, or even contacted him. I'm sure he's a wonderful person in his real life, and I can clearly see that he is a dedicated and fervent fan of VW diesels. I also appreciate all the great products that he makes for this community (even though, I have never personally bought any).
« Last Edit: November 08, 2010, 10:42:58 am by Quantum TD »
Reply #7November 07, 2010, 11:06:11 pm
truckinwagen
  • 1895
« Reply #7 on: November 07, 2010, 11:06:11 pm »
      well said, wish I could say things with such eloquence once in a while...
-Owen
83 Opel Kadett Diesel
Reply #8November 08, 2010, 05:36:53 am
« Reply #8 on: November 08, 2010, 05:36:53 am »
Yeah I am with libby on that. I have bought some stuff off of GB and it is all good.
I have passed on an intake tube because it was "too much"...now I have more in my fabbed one because of poor design than I would have buying the one of his. So AGAIN more money doesn't always mean cheaper in the long run. Even when I have half decent fab skills it still turned out bad since I had to redo it 3 times.
BTW maybe you could PM him next time and offer your suggestions and you may get a better response.
Reply #9November 08, 2010, 06:07:41 am
GEE-BEE
  • 1604
« Reply #9 on: November 08, 2010, 06:07:41 am »
Wow!!!
The vortex people ( scirocco 16V) owners just say thanx for making the obsolete item's
Samba people : Vanagon owners , Greaseworks are not complaining ?
There are several ways to do thing's , Iam just showing a option
If you dont like it move on, If you have a item that is NLA or you dont want a piece of china( meyle ) mfg rubber assy please let me know?
You have all been a big help with your idea's and comments...
Gee-Bee
Iam presently doing over fifty new production aircraft parts per month
next will be MKII snorkel's
« Last Edit: November 08, 2010, 06:57:44 am by GEE-BEE »
Giles Pump OHC
MK1 JETTA DASH
Reply #10November 08, 2010, 09:03:41 am
« Reply #10 on: November 08, 2010, 09:03:41 am »
im just speaking in terms of he is going to be a loner with his bell intercooler.. thats all. i know if i have enough to buy a bell intercooler, im gonna save up a couple hundred more dollars and buy a Giles pump. that is worth every penny..
not saying its bad. but i 100% agree with QuantumTD about what he posted. it just seems like GB is bragging half the time. not like i have a problem with it, im sure i would brag like that too if i had a $40,000 caddy with powder coated and extrude honed everything..
Reply #11November 08, 2010, 09:18:58 am
Mark(The Miser)UK
  • 1557
« Reply #11 on: November 08, 2010, 09:18:58 am »
Come on; if you want to vend then stick it in the vendors section.
 What's the point of the section otherwise?
Perhaps I can advertise my guaranteed to work heatshields:
 Personally tested by me, not once, not twice, but 8 times...
Can be seen working if required...
I know them so well, they have names; Tom, Dick, Harry... and Obama ;D
Mark-The-Miser-UK
Reply #12November 08, 2010, 12:47:02 pm
GEE-BEE
  • 1604
« Reply #12 on: November 08, 2010, 12:47:02 pm »
Around 15 K , It's a driver...
My 2008 997TT was 172k with 39K in Int  option's
Another 11K for Dymag's wheels
8K for Tubi exhaust and headers
3K for ECU flash
4K for Euro Suspension
I have been making seals and duct for the aircraft industry for over twenty years, I own the tooling for over 465 different model's of aircraft
1947 to present production
I like nice stuff, I enjoy my Ducati Desmosedici
Iam asked why would you spend 72K on a motorcycle and another 9k for a Ti exhaust for it, beacause I can...
It's what you do for other people....
Iam not asking for anyone here to buy anything , just information on product's and prices...
I have several auto mfg's that I mfg product's for MK1autohaus, TRD Racing
I dont harp on your life or what you do or dont do with it...
let's keep things positive here, isnt there enough negative *** already in the world ?
GB
Giles Pump OHC
MK1 JETTA DASH
Reply #13November 08, 2010, 04:07:47 pm
Powered by Spearco
  • 1203
« Reply #13 on: November 08, 2010, 04:07:47 pm »
So how about some pics of your cool rides and all the bling on them?
'78 Rabbit..Gas Weekend Racer
'13 Golf R:. Tuned
'98 Puch G320
Reply #14November 08, 2010, 07:21:45 pm
Thezorn
  • 381
« Reply #14 on: November 08, 2010, 07:21:45 pm »
Come on guys, you have to have respect for this guy. For all the different parts he has be manufacturing. Maybe some arent going to fit in everyones check books, but you dont need to hate him for that.
We need some pics or the intercoolers GEE BEE!!
Compounded 93 AAZ
