Author Topic: picture of sliced aaz head  (Read 6135 times)
October 24, 2010, 12:03:56 pm
arnold
« on: October 24, 2010, 12:03:56 pm »
Anyone has a pic showing where the water jacket is in relation to the exhaust port (aaz)
ps:I've tried the search :P
Reply #1October 24, 2010, 12:46:44 pm
Re: picture of sliced aaz head
« Reply #1 on: October 24, 2010, 12:46:44 pm »
I know Vince Waldon had a pic of a head cut in half somewhere. I don't know which it was 1.6 or 1.9.
It may have even been on the other site vwdieselparts or something like that.
Reply #2October 24, 2010, 02:58:42 pm
« Reply #2 on: October 24, 2010, 02:58:42 pm »
This may be what you're thinking of... probably doesn't show the details the OP is after though:
If I could find someone local with a good bandsaw I've got a great donor head that was pressurizing the coolant due to a couple very small cracks between the valves and the prechamber... hmmmm.
Reply #3October 24, 2010, 03:19:47 pm
arnold
« Reply #3 on: October 24, 2010, 03:19:47 pm »
WOW Vince that's a nice pic ! (save,set as desktop image)  :P
How the hell did you cut that iconel precup in half,you have a source for alien laser technology ?
Sadly it doesn't shows the port enough,well there's a cracked head lying around here,i need it fast so i might attack it with my grinder and do the rest with the good old hand saw  ;D
Reply #4October 24, 2010, 03:32:59 pm
rallydiesel
  • 1880
« Reply #4 on: October 24, 2010, 03:32:59 pm »
I've never seen that one before. Very cool pic!
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #5October 24, 2010, 10:01:33 pm
Powered by Spearco
  • 1203
« Reply #5 on: October 24, 2010, 10:01:33 pm »
Did you knowtice the oil ring  ::). Looks more like a referance for injector, pre-cup and glow plug.
'78 Rabbit..Gas Weekend Racer
'13 Golf R:. Tuned
'98 Puch G320
Reply #6October 25, 2010, 07:22:43 am
smutts
  • 720
    ClackClackClackClackClack
« Reply #6 on: October 25, 2010, 07:22:43 am »
Did you knowtice the oil ring  Roll Eyes
She might have burnt a bit of oil, good compression though. ;D
Reply #7October 25, 2010, 10:08:54 am
« Reply #7 on: October 25, 2010, 10:08:54 am »
whats it got? 3 compression rings? and its not a VW piston either, cause the comp rings on a vw are spaced far apart from the scraper and oil rings.. and there in a steel ring land too.
Reply #8October 25, 2010, 10:37:28 pm
« Reply #8 on: October 25, 2010, 10:37:28 pm »
I bet it's a vw head on a different block. No hg either. The top of the piston looks rather strange too.
Reply #9October 26, 2010, 07:07:36 am
« Reply #9 on: October 26, 2010, 07:07:36 am »
yea, its definitely not on the right block. the deck should hold the pre cup in more than that.. it should cover almost half the pre cup.
Reply #10October 29, 2010, 12:17:49 pm
arnold
« Reply #10 on: October 29, 2010, 12:17:49 pm »
Here it is,this is cil nr1 exhaust.
As you can see the lower side is quite beefy,the side's after the bowl are THIN,where the oil drains are the wall is no more then 2mm  !
I have a lot more pic's at different angles so if you want something just ask
the red line shows the bump i removed
« Last Edit: October 29, 2010, 12:39:20 pm by arnold »
