W terminal output? PWM?
Topic: W terminal output? PWM? (Read 3535 times)
October 01, 2010, 12:10:39 am
Alcaid
October 01, 2010, 12:10:39 am »
Hi,
does anyone know what the output is on the W terminal on the alternator? Is it PWM with varying duty cycle? At what voltage?
'10 VW Passat 1.6TDI Highline
'83 VW Jetta 1.6TD, 11mm pump, H-beam rods, girdle, fully reworked AAZ head +++ Going Compound
October 01, 2010, 09:50:31 am
Re: W terminal output? PWM?
October 01, 2010, 09:50:31 am »
It's an alternating current source from one of the windings before the alternator diodes.
This allows you to determine the engine speed on a diesel engine based on the frequency of the current (with a tachometer designed for this). Even the cars that didn't have tachometers had some dashboard functions that required an input for engine speed.
October 01, 2010, 09:59:17 am
October 01, 2010, 09:59:17 am »
It's an 8 V RMS square wave... frequency dependent on RPM. There's a thread with oscilloscope pictures... I'll see if I can find it.
EDIT: here it is:
http://www.vwdiesel.net/forum/index.php?topic=13499.0
Last Edit: October 01, 2010, 10:12:19 am by Vincent Waldon
October 01, 2010, 10:01:30 am
Alcaid
October 01, 2010, 10:01:30 am »
That would be excellent! So duty cycle is constant then (50%?) and the frequency is the variable?
October 01, 2010, 10:12:34 am
October 01, 2010, 10:12:34 am »
Yup... it's really just one leg of the alternator's winding before rectification, so a square wave.
October 01, 2010, 01:57:40 pm
regcheeseman
October 01, 2010, 01:57:40 pm »
I don't know what you want it for but I'm getting a more accurate engine speed signal from he pressure switch mounted in the pump head.
It's a normally closed switch and triggers at twice crank speed so perfect to drive a gas tacho with no conditioning - just a 12v supply.
For my application I'm taking the 30 - 230Hz signal to a LM2917 F-V converter to give a 0-5 signal for an ADC to sample
October 01, 2010, 02:00:50 pm
Alcaid
October 01, 2010, 02:00:50 pm »
Actually, i have a plan to build a VNT controller to control a GTB2056VK turbo on a 1.6TD, so rpm input is needed.
