Author Topic: preparation ibiza tdi 100  (Read 352184 times)
Reply #840February 09, 2012, 03:32:07 pm
apocope1
Re: preparation ibiza tdi 100
« Reply #840 on: February 09, 2012, 03:32:07 pm »
radiateur eau/huile monté!!!
géometrie variable nettoyé!!!
place aux logs pour voir, si le probleme est resolu!!!
« Last Edit: February 09, 2012, 04:44:25 pm by apocope1 »
Reply #841February 10, 2012, 01:38:23 am
apocope1
« Reply #841 on: February 10, 2012, 01:38:23 am »
bon voici les logs, toujour pareil
je pense que je vais mettre le feu a cette voiture!!!!!
10.69   1365   1800   1236   19.9
11.09   1365   1812   1380   19.9
11.49   1386   1848   1500   21.5
11.89   1428   1896   1620   24.3
12.27   1449   1932   1716   35.1
12.67   1470   1968   1824   37.9
13.07   1512   2028   1920   41.8
13.45   1554   2076   2016   47.4
13.85   1596   2124   2088   52.2
14.25   1638   2184   2136   53.4
14.65   1680   2196   2160   49.8
15.05   1722   2196   2184   52.6
15.45   1764   2196   2208   53.8
15.85   1806   2196   2232   58.2
16.25   1848   2244   2256   56.2
16.64   1890   2280   2268   55.4
17.04   1953   2340   2292   57
17.44   1995   2388   2328   55
17.82   2058   2436   2364   53
18.22   2079   2460   2400   55.8
18.62   2142   2484   2436   57.8
19.02   2184   2532   2472   58.6
19.42   2226   2544   2508   59.4
19.8   2289   2556   2544   58.2
20.2   2331   2568   2568   61.8
20.6   2373   2592   2616   64.1
20.99   2436   2592   2640   67.3
21.39   2478   2592   2652   66.1
21.79   2541   2592   2652   67.7
22.19   2583   2592   2640   69.7
22.59   2625   2592   2628   70.9
22.99   2667   2592   2616   72.9
23.39   2730   2592   2604   71.7
23.79   2772   2592   2604   74.5
24.17   2814   2592   2604   75.3
24.57   2856   2592   2604   74.5
24.97   2898   2592   2604   75.7
25.36   2940   2592   2616   78.1
25.76   2982   2592   2616   77.7
26.16   3024   2592   2628   78.9
26.56   3066   2592   2652   80.9
26.95   3108   2592   2664   82.1
27.34   3150   2592   2664   84.1
27.74   3192   2592   2652   85.3
28.14   3213   2592   2640   84.9
28.52   3255   2592   2640   85.7
28.92   3297   2592   2664   88.9
29.32   3318   2592   2676   89.6
29.72   3360   2592   2688   92.8
30.12   3381   2592   2700   94.4
30.52   3423   2592   2700   94.4
30.92   3444   2592   2712   93.2
31.32   3486   2592   2712   93.6
31.71   3507   2592   2724   94.4
32.11   3528   2592   2724   94.4
32.51   3549   2592   2736   94
32.89   3591   2592   2736   94.4
33.29   3612   2592   2748   94.4
33.69   3633   2592   2760   94.4
34.09   3654   2580   2748   94
34.49   3675   2580   2760   94
34.87   3696   2580   2748   94.4
35.27   3717   2580   2748   94.4
35.67   3738   2580   2760   93.6
36.06   3759   2580   2760   94.4
36.46   3780   2580   2760   94.4
36.86   3801   2580   2760   94.4
37.26   3822   2580   2760   94.4
37.66   3843   2568   2772   94.4
38.06   3864   2568   2760   94.4
38.46   3885   2568   2772   94.4
38.86   3906   2556   2760   93.6
39.24   3927   2556   2760   94.4
39.64   3927   2556   2760   94
40.04   3948   2544   2760   94
40.42   3969   2544   2760   94.4
40.82   3990   2544   2760   94.4
41.22   3990   2532   2760   94
41.62   4011   2532   2748   94
42.02   4011   2532   2748   94.4
42.41   4032   2532   2748   94.4
42.81   4053   2532   2736   94.4
43.21   4074   2520   2736   94.4
43.59   4074   2520   2736   94.4
43.99   4095   2520   2736   94.4
44.39   4116   2520   2724   94.4
44.79   4116   2520   2724   94
45.19   4116   2520   2724   94.4
45.58   4137   2508   2724   94
45.98   4158   2508   2712   94.4
46.38   4158   2508   2712   94.4
46.76   4179   2508   2712   94.4
47.16   4200   2508   2700   94
47.56   4200   2508   2700   94.4
47.94   4221   2496   2700   94
48.34   4221   2496   2700   94.4
48.74   4221   2496   2700   94.4
49.14   4242   2496   2688   94.4
49.54   4242   2496   2688   94.4
49.93   4242   2496   2688   94
50.33   4263   2496   2688   94.4
50.73   4263   2496   2676   94.4
51.11   4263   2484   2676   93.6
51.51   4263   2496   2676   94
51.91   4242   1212   2604   94.4
Reply #842February 10, 2012, 03:54:26 am
« Reply #842 on: February 10, 2012, 03:54:26 am »
Oui, on dirait  :-\
T'as rallongé la tige avant de remonter ?
Reply #843February 10, 2012, 05:17:43 am
X@V
  • 1002
« Reply #843 on: February 10, 2012, 05:17:43 am »
Ouais, 2 tours de "pre-load", sinon ça marche pas bien...
Reply #844February 10, 2012, 11:09:27 am
apocope1
« Reply #844 on: February 10, 2012, 11:09:27 am »
oui c'est deja allongé! si j'allonge encore faudra que je fasse une force sur l'actuateur pour le refixer sur le turbo!
Reply #845February 10, 2012, 11:29:41 am
« Reply #845 on: February 10, 2012, 11:29:41 am »
Peut etre limer le dessus des ailettes pourra résoudre le problème.
Reply #846February 10, 2012, 11:35:58 am
apocope1
« Reply #846 on: February 10, 2012, 11:35:58 am »
je bouge la GV a la main sans aucun probleme, pas de point dur! bizarre!
est il possible de reglé se souci dans la carto.
Reply #847February 10, 2012, 12:12:52 pm
X@V
  • 1002
« Reply #847 on: February 10, 2012, 12:12:52 pm »
Justement, mon GT2052V est à 2 tours de pre-load (ça force quand je l'entre en place)
J'ai aussi limé le rebord des ailettes et ça va #1, rien à signaler.
Reply #848February 10, 2012, 04:47:19 pm
apocope1
« Reply #848 on: February 10, 2012, 04:47:19 pm »
as tu une photo de la partie a limé?
Reply #849February 10, 2012, 06:30:37 pm
« Reply #849 on: February 10, 2012, 06:30:37 pm »
C'est le dessus des ailettes.
Avec la gestion, on peut légèrement améliorer la chose en augmentant l'avance mais ça ne résoudra pas complètement le problème. Le plus gros à gagner est de nature mécanique.
Reply #850February 10, 2012, 06:58:44 pm
apocope1
« Reply #850 on: February 10, 2012, 06:58:44 pm »
ok je vais tester pour voir! cela de me coutera rien!
Reply #851February 11, 2012, 04:54:05 pm
apocope1
« Reply #851 on: February 11, 2012, 04:54:05 pm »
 si dans la carto, on baisse legerement la pression de la carto de demande. vu que je suis en surpression a haut regime. cela peut baisser la pression pour avoir une pression admissible par le turbo?
« Last Edit: February 12, 2012, 05:53:17 am by apocope1 »
Reply #852February 12, 2012, 10:49:10 am
X@V
  • 1002
« Reply #852 on: February 12, 2012, 10:49:10 am »
Pas vraiment, la N75 est au max...
Reply #853February 12, 2012, 01:54:48 pm
« Reply #853 on: February 12, 2012, 01:54:48 pm »
Non, si on baisse la pression turbo sans diminuer l'injection, la pression turbo restera la même à haut régime puisque comme le dit Xav, la N75 travaille déjà à fond et n'arrive pas à réguler.
Reply #854February 12, 2012, 03:10:01 pm
apocope1
« Reply #854 on: February 12, 2012, 03:10:01 pm »
ok!
