Author Topic: Power steering pump  (Read 4536 times)
May 19, 2010, 12:11:39 pm
Vohaul
  • 105
Power steering pump
« on: May 19, 2010, 12:11:39 pm »
Hey All, i think my power steering pump is fried..as the level is good..but i get a horrible squeal (more than belt squeal) and no power assistance....
first off, is a bad power steering pump the general consensus....and second are the power steering pumps frpm the gas cars interchangeable with the diesel cars?
Thanks
Paul
Reply #1May 19, 2010, 12:49:06 pm
Baron VonZeppelin
Re: Power steering pump
« Reply #1 on: May 19, 2010, 12:49:06 pm »
If the belt has good tension on it, but system not working - yeh probably the pump is cause.
If this is an mk2, those pumps will swap from gasser.
Mk1 will swap between gas and diesel.
And mk1-mk2 might swap with each other.
Any other models - i'm not familiar with
Reply #2May 19, 2010, 01:26:07 pm
Vohaul
  • 105
« Reply #2 on: May 19, 2010, 01:26:07 pm »
its an mkIII 1.9 aaz engine...sorry for not specifying that.....
Reply #3May 19, 2010, 06:52:00 pm
« Reply #3 on: May 19, 2010, 06:52:00 pm »
Open the power steering fluid reservoir with the car running and see if the fluid is circulating.
I'm pretty sure that the bentley has some specs for checking the pressures on the power steering pump.
Reply #4May 19, 2010, 07:25:50 pm
catlin_cava
  • 1954
« Reply #4 on: May 19, 2010, 07:25:50 pm »
Depending if you have AC or not all MK3 8V motors are interchangable,
Catlin
2010 VW Golf City 2.0L "Hers"
Reply #5May 19, 2010, 07:47:12 pm
79rabbit4dr
« Reply #5 on: May 19, 2010, 07:47:12 pm »
Thanks
Paul
when I'm not sure if it's one specific thing, I try these two steps just to double check (they're free so I always start here);
- if you dump water on a belt and it squeals it should be replaced, that's a free way to double check the belt.
- you can remove the belt and run the motor, that will just tell you if the component(s) driven by that belt is the only noise you're hearing or if there are multiple noises.
in your particular case I'd bet pump needs rebuilt/replaced being fluid remains but assist isn't there.
Reply #6May 19, 2010, 08:49:37 pm
« Reply #6 on: May 19, 2010, 08:49:37 pm »
I have a brand new Mk III pump in its box sitting by my desk... My car has a Mk II motor in it but I THOUGHT it had the Mk III pump.  :P  PM me if you need one...
