Author Topic: K24 turbo  (Read 6276 times)
December 05, 2005, 12:10:16 am
jackbombay
  • 599
K24 turbo
« on: December 05, 2005, 12:10:16 am »
There is virtually no shaft play, but the shaft does have some drag on it, from what I don't know. PM ofers or reply here. It is from an Audi TD so it has a non trapezoidal flange.
Reply #1December 05, 2005, 04:54:36 pm
jackbombay
  • 599
K24 turbo
« Reply #1 on: December 05, 2005, 04:54:36 pm »
Is this fairly worthless as it is from an Audi? What about the gap between the compressor wheel and housing, is this toast anyway? Should I just put on the curb with my recycling?
Reply #2December 05, 2005, 05:18:54 pm
935racer
K24 turbo
« Reply #2 on: December 05, 2005, 05:18:54 pm »
The compressor wheel is toast and needs to replaced. The cost of the wheel and a proper rebuild make this item hardly worth anything. Sorry I am not trying to *** on your thread or anything, its just how it is.
Reply #3December 05, 2005, 05:21:01 pm
jackbombay
  • 599
K24 turbo
« Reply #3 on: December 05, 2005, 05:21:01 pm »
Quote from: "935racer"
  I appreciate the honesty, and though that was likely the case anyway.
Reply #4December 05, 2005, 06:33:00 pm
vwmike
  • 1158
K24 turbo
« Reply #4 on: December 05, 2005, 06:33:00 pm »
How does the oil drain connect to the engine? Does it thread onto a fitting in the pan like the 1.6TD? If so, I'm looking for that fitting so I can fab a different return line without cutting up the good one that's on my car.
Reply #5December 05, 2005, 08:05:00 pm
jackbombay
  • 599
K24 turbo
« Reply #5 on: December 05, 2005, 08:05:00 pm »
Quote from: "vwmike"
  No, it is a flat flange with 2 bolts to fasten it.
Reply #6December 06, 2005, 08:10:07 pm
mpg
  • 49
K24 turbo
« Reply #6 on: December 06, 2005, 08:10:07 pm »
i'll likely buy it, if you don't want much... i could use it for parts...
'90 Jetta AAZ T3 lifted
'81 Caddy project
'84 GLi 1.9 16V
'03 GLi 24V 6spd
Reply #7December 06, 2005, 10:14:10 pm
jackbombay
  • 599
K24 turbo
« Reply #7 on: December 06, 2005, 10:14:10 pm »
Quote from: "mpg"
  I haven't gotten any offers yet *hint hint*, and would rather not put it on the curb with the metal recycling when it comes time to move in 2 weeks...
