Author Topic: Compound pics  (Read 148017 times)
Reply #165December 20, 2006, 06:00:40 pm
foxracer1
  • Authorized Vendor
  • 991
Compound pics
« Reply #165 on: December 20, 2006, 06:00:40 pm »
Sounds awesome keep it up man. Were gonna need some video of this monster.
91 S10 305 TPI T56
86 S10 2WD Prerunner project.
Reply #166December 21, 2006, 03:18:44 pm
andy2
Compound pics
« Reply #166 on: December 21, 2006, 03:18:44 pm »
Thanks,I just tried torquing my ARP head studs down to 120 ft lbs up from the 80 ft lbs using the moly lube as the lubricant.The 120 ft lbs torque in the insructions was only intended for use with motor oil.Anyhow I still have major issues so the head will come off and I'll see if the gasket had any issues and get the head checked out also.At least I'll be doing two jobs at once this time(turbo swap,head gasket) so it won't be a total loss :roll:
Reply #167December 28, 2006, 10:13:23 am
deezul ryan
  • 24
    • http://www.dieseldude.com
Compound pics
« Reply #167 on: December 28, 2006, 10:13:23 am »
what is the story on the 2 rods?
94 jeep YJ 2.4 TD (vw diesel powered)
81 vw pickup 2.0 16v dual carbs NOS soon to be TDI-M powered
80 vw pickup 1.5 TD
53 Studebaker M35 7.8 TD (23,030 GVWR)
Reply #168December 28, 2006, 01:34:45 pm
andy2
Compound pics
« Reply #168 on: December 28, 2006, 01:34:45 pm »
Bent connecting rods?The stock AAZ ones seem to handle about 145- 155hp on 35psi boost.
My repaired cylinder head was not repaired well enough as the weld is porous.Now I have coolant enter the intake port and then under load, boost in the coolant :x.Were starting fresh on a very good used head it will require some work for the larger pre cups and what not :twisted:.
I reassembled the k24/14 turbo today ready for the hx30 again.
Reply #169December 28, 2006, 02:29:36 pm
deezul ryan
  • 24
Compound pics
« Reply #169 on: December 28, 2006, 02:29:36 pm »
the last 2 pictures on your link on the first post.  2 different rods?  whats the story?  i am looking for better rods for a tdi.  i want it to stay together at 40 psi
80 vw pickup 1.5 TD
Reply #170December 28, 2006, 02:45:43 pm
andy2
Compound pics
« Reply #170 on: December 28, 2006, 02:45:43 pm »
That pic shows the AAZ rod and the TDI PD 100hp rod (BEW engine code) I believe.Which TDI engine are you hot rodding 1Z/AHU or ALH? I don't have to much hardcore TDI hotroding info as others on this forum,Prehaps others will chime with some info.
Reply #171December 28, 2006, 03:38:26 pm
deezul ryan
  • 24
Compound pics
« Reply #171 on: December 28, 2006, 03:38:26 pm »
1z I havent looked yet but i do have aa good used set of ALH rods
80 vw pickup 1.5 TD
Reply #172January 29, 2007, 03:50:42 pm
andy2
Compound pics
« Reply #172 on: January 29, 2007, 03:50:42 pm »
So we started from scratch with another cyl head and machined it to fit our custom pre cups and ported the head as well.I torqued the studs to 120 ft lbs using motor oil as the lubricant this time.I built up my k24/k14 combo this time and used the hx30 also.With a special "compound only" modded wastegate (QuickTD's idea) :twisted:  this time around it all works much better in terms of EGT's spool up and more importantly we have the compound effect working :wink:.Only one big problem though,After a couple of hardcore trips around the block the engine blows coolant out the overflow :x.On 29 psi boost and loads of power it looks like the headgasket has surpassed its useful limit.As I'm deaccelerating after the coolant blows out the engine stalls out as I want to down shift which I can only guess happens due to the loss of compression.Currently I'm thinking about what to do next,one thought was to moddifly a headgasket to add about .004 thou of additional crush around the gaskets sealing area "fire ring".Possibly moddifying the head as the cummins guys do may be an option??
http://www.dieseltruckresource.com/dev/showthread.php?t=132796&highlight=ring
Reply #173January 29, 2007, 04:03:19 pm
SMOKEYDUB
  • 630
Compound pics
« Reply #173 on: January 29, 2007, 04:03:19 pm »
Its great to hear that its working well. accept the coolant thing. God dammit i know how you feel its just so dam frustrating. I have also thought about oringing my engine because for some reason i just cant hold the top end down. I am running arp studs 1.9 gasket and both surfaces are freshly machined and still coolant problems. I AM ONLY RUNNING 27 PSI... i used to runn that in my bone stock 1.6 with factory headgasket..... Im staring to wonder how much boost before grenading this thing. Dr.diesel was running 35 psi and nitrous and his engine held togehter great with nothing done to the thing accept arp headstuds and giles pump... DAM!
i wonder were we could get this procedure performed.let me know if you find a place.
(sorry i got worked up)
Jeff
12mm PUMP 'O' DEATH on a 1.6L
(courtesy of GILES)
2000 NISSAN XTERRA (5 SPD)
1984 RABBIT TD 2dr (SOLD)
1.8t AEB soon around 550 whp
Reply #174January 29, 2007, 04:21:04 pm
Compound pics
« Reply #174 on: January 29, 2007, 04:21:04 pm »
andy i think its time for you to try a pure copper gasket...  i honestly cannot see a copper gasket failing you!  :twisted:
only one problem... $$$$$$$$$$$$$4
Reply #175January 29, 2007, 04:23:01 pm
SMOKEYDUB
  • 630
Compound pics
« Reply #175 on: January 29, 2007, 04:23:01 pm »
well how much? i dont car it would cost me less to by one of those then by 7 normal 1.9 ones and all the stress that comes with it.
(courtesy of GILES)
Reply #176January 29, 2007, 05:11:26 pm
  • 1156
    • Malone Tuning Ltd.
Compound pics
« Reply #176 on: January 29, 2007, 05:11:26 pm »
My 1.6/1.9TD engine had a few coolant tank blow-outs too when exceeding 30 or 35 PSI, albeit with a lower-flowing GT20 turbo. Had Raceware headstuds and a OEM 1.9 headgasket. The car still started & ran like a champ thousands of KMs after that though, it was probably a temporary head lift under full power.
During the engine build Passenger Performance mentioned getting o-rings and I thought it was a great idea, but we couldn't find some small enough for the 1.6 bores so we skipped it.
Next time I would try to get it o-ringed/fire ringed and probably a copper headgasket.
One source for copper headgaskets:
http://www.headgasket.com/products.html
About $85.00 USD per gasket.. if they haven't done a TD gasket before then there's a one-time CAD fee $75.00. I'll gladly donate some of my money for their CAD fee and order a gasket. mini groupbuy anyone? Disclaimer: I haven't really researched for other places that make custom copper headgaskets, so there may be better deals elsewhere. I'd like a AAZ-based gasket (for my 1.9 head on a 1.6 block probably with AAZ pistons).
andy2: That really $ucks it has to come apart again, but keep your head up. It isn't an impossible problem and we're all anticipating your results :)
http://www.tunezilla.com
93 Eurovan AHU TDI
97 Golf Variant Syncro 1.9L 1Z TDI - sold and missed
17 BMW 328d wagon - Sold
09 BMW 335d 3.0L
Reply #177January 29, 2007, 05:52:24 pm
andy2
Compound pics
« Reply #177 on: January 29, 2007, 05:52:24 pm »
I would say that it looks like 140-145 hp is about the max hp(reliably) that we can get out of these engines before having gasket problems.I'm sure that we can over come this issue and bend rods at 200+WHP :twisted:.
Reply #178January 29, 2007, 06:40:23 pm
Compound pics
« Reply #178 on: January 29, 2007, 06:40:23 pm »
i'll donate money to the copper head gasket 'fund'...  i would expect the copper to hold to around 60 psi easily with good strong head studs.
i trust copper... i learned pretty quickly working on cars that without the copper gasket, high pressure things will leak...  :oops:
Reply #179January 30, 2007, 07:01:44 am
SMOKEYDUB
  • 630
Compound pics
« Reply #179 on: January 30, 2007, 07:01:44 am »
im not sure what kind of power im running its pretty quick but i dont think 145 hp maybe its more i dont know i would love to dyno it. I think i would go for a couple copper gaskets and im sure dr.diesel would buy a few.
Jeff
(courtesy of GILES)
