Author Topic: Audi Quattro Turbo Diesel Build - Now with video!  (Read 88989 times)
Reply #90July 04, 2011, 08:05:29 am
Re: Audi Quattro Turbo Diesel Build
« Reply #90 on: July 04, 2011, 08:05:29 am »
i want a 4kQ...
Me too.  ROR, that we be a good candidate for your 2.0TD.
thats kinda what i was thinking.. and 4ks are pretty LITTLE.. a 2.0 TD5 would be pimpin in a little quattro car..
Reply #91July 04, 2011, 07:19:59 pm
rabbid79
  • 684
« Reply #91 on: July 04, 2011, 07:19:59 pm »
ROR, what would it take to get your 5-cyl TD running?
'15 WRX
Reply #92July 05, 2011, 09:57:45 am
« Reply #92 on: July 05, 2011, 09:57:45 am »
it runs. well, it did last time i drove it. but it used about as much oil as it did fuel. someone did a single tank Vegi setup on it, MESSED EVERYTHING UP.. almost didnt make it home. when i did get home with the car, that next morning the car would not run. took the fuel filter off, and it was ALMOST COMPLETELY FULL of glycerine... so uh, dare i say, that this engine has overdosed on coke.. im positive it needs a bore job, probably all the way to 1mm O/S and it needs to have everything else gone over also. as long as ive owned this car, it takes a TINY shot of ether to make it run.. some say i probably destroyed it from ether, but usually, wouldnt your head gasket let go before you bent a rod, or blew a pre-chamber out, or cracked main caps? dunno why it would happen soo easy on a TD5..
so, i need a full gasket set, probably 5 right way industrial pistons, some machine work, some GOOD rings maybe total seal or something like that, i really like gapless rings.
this engine is either going in a 4kQ, or a 88 toyota 4runner..
Reply #93July 05, 2011, 05:30:03 pm
rabbid79
  • 684
« Reply #93 on: July 05, 2011, 05:30:03 pm »
Good to know the condition isn't too bad.  I thought it had a blown head gasket and water in it or something.  I would vote for the 4KQ swap.  You could probably have it done in a couple of weekends.  If there are any parts you need for your rebuild, let me know.  I have a couple of spares.
'15 WRX
Reply #94July 06, 2011, 06:34:18 am
baldone
« Reply #94 on: July 06, 2011, 06:34:18 am »
nice job :o
Reply #95July 06, 2011, 07:40:47 pm
« Reply #95 on: July 06, 2011, 07:40:47 pm »
now all i need to do is to find a 4kQ that someone doesnt want a premium for..
Reply #96July 06, 2011, 07:54:26 pm
rabbid79
  • 684
« Reply #96 on: July 06, 2011, 07:54:26 pm »
'15 WRX
Reply #97July 07, 2011, 10:26:29 am
« Reply #97 on: July 07, 2011, 10:26:29 am »
ROR, check this out...http://santafe.craigslist.org/cto/2462214698.html
i want an old one tho.. and thats about 2k miles too far away.. unless there is significant things better about the newer body style?
Reply #98July 07, 2011, 05:37:11 pm
rabbid79
  • 684
« Reply #98 on: July 07, 2011, 05:37:11 pm »
The only "problem" with the "old" ones is that they were only imported in '84.  There are just too few of them around.  Actually, I want an '84 too.  If you go with the newer body, you get 3 more year's worth to choose from.
'15 WRX
Reply #99July 07, 2011, 10:58:36 pm
« Reply #99 on: July 07, 2011, 10:58:36 pm »
i will see what i come up with. ive seen old 4000s around..
Reply #100July 08, 2011, 07:22:56 am
BillyWillicker
  • 111
« Reply #100 on: July 08, 2011, 07:22:56 am »
It really makes for a GREAT car!  A couple of years ago, I was grabbin' some grub at the local mokdoonald's with the woman and we saw 2 audi's pull in.  It grabbed my attention, as one was a CLEAN '86 4kq and the other a '95.5 S6 wagon.  Anyways, I chatted the guys up and they ended up picking up the 4000 in PA and in the back of the wagon was a 2.0TD I5!  They explained the swap they were planning and it sounded great!  Looked good too!
Reply #101July 09, 2011, 04:52:37 pm
rabbid79
  • 684
« Reply #101 on: July 09, 2011, 04:52:37 pm »
I would really like to see a nice 4KQTD with the 2.0 TD.  Sounds like something Audi should have done from the factory back in the 80's.  It would have been especially cool if they made a "GTD" version of it with a little hotter motor and some sporty BBS wheels.
Anyway, it's official:
Here's the oil check valve I've been looking for for about a year now.  Fortunately, there was a discussion about these valves on another forum that I happened to stumble across.
'15 WRX
Reply #102July 09, 2011, 10:02:00 pm
Powered by Spearco
  • 1203
« Reply #102 on: July 09, 2011, 10:02:00 pm »
I love the plate.
'78 Rabbit..Gas Weekend Racer
'13 Golf R:. Tuned
'98 Puch G320
Reply #103September 24, 2011, 10:33:58 pm
mystery3
  • 774
« Reply #103 on: September 24, 2011, 10:33:58 pm »
I know this has been asked before, possibly by me but all this talk of swaps in 4kq's has refreshed my interest in putting my 1.6 into a 4kq, is there any reasonable way to make the 4 cylinder engines and 5 cylinder transmissions work together? A reasonably hopped up 1.6td would net you similar horsepower figures to the stock 4kq's 115hp and more torque the issue becomes gearing and transmission options.
Reply #104September 25, 2011, 09:20:11 am
« Reply #104 on: September 25, 2011, 09:20:11 am »
4 cylinder and 5 cylinder bell housing patterns are WAY different. you would definitely need an adapter plate..
