Author Topic: Crank pulley 1.9 passat  (Read 8937 times)
November 23, 2005, 10:55:37 am
soslow
  • 15
« on: November 23, 2005, 10:55:37 am »
if the  crank pulley keyway is broke will the pulley woble like a bent crank?THANKS
Reply #1November 23, 2005, 11:55:35 am
QuickTD
  • 1156
« Reply #1 on: November 23, 2005, 11:55:35 am »
Yes, it will. But the serpentine pulley/harmonic balancer can also wobble if it's improperly assembled, lots of them come from the factory wobbling... Check the V-belt pulley, if it also wobbles chances are the crank pulley has come loose.
Reply #2November 23, 2005, 12:06:58 pm
soslow
  • 15
pulley
« Reply #2 on: November 23, 2005, 12:06:58 pm »
Looking under the car at the crank pulley while running it looks to be wobbling.The tensioner also appears to be wobbling, ordered new ones,along with timing belt .Hope this will cure smoke problem!Thanks
Reply #3November 24, 2005, 05:09:47 am
chrissev
  • 694
Re: pulley
« Reply #3 on: November 24, 2005, 05:09:47 am »
Quote from: "soslow"
you might have to modify the crank to take the newer style flat topped pulley.  I think that is the cure for the crank pulley keyway problem in those engines.
Reply #4November 24, 2005, 07:23:50 pm
commuter boy
  • 277
« Reply #4 on: November 24, 2005, 07:23:50 pm »
If it's already wobbling, I bet you've worn out the keyway in the crankshaft.  Be prepared to deal with an unpleasant surprise.
Hopefully it hasn't got too far yet.
Reply #5November 25, 2005, 06:20:12 am
soslow
  • 15
Pulley
« Reply #5 on: November 25, 2005, 06:20:12 am »
Is there a some what non painfull answer?And what is the bad news at worst?
Reply #6November 25, 2005, 04:28:44 pm
chrissev
  • 694
Re: Pulley
« Reply #6 on: November 25, 2005, 04:28:44 pm »
are you saying the alternator belt pulley on the crank wobbles?  That is pretty normal.  Never been able to get mine to run straight.  I think someone bent it.  Or are you saying the smaller geared pulley that the timing belt runs on wobbles?  If that wobbles, you might have a keyway problem.  The keyed crank pulley was designed badly and the keyway becomes expanded causing the key to move.  When this happens the pulley will wobble.  This causes the timing to be wrong and usually some valves will be bent.  So worst case scenario is you need to pull the crank to get it machined to fit the new style flat topped pulley and you need to pull the head to replace a couple of bent valves.  Thank VW for their stupid keyed pulley design
Reply #7November 26, 2005, 07:48:39 am
soslow
  • 15
pulley
« Reply #7 on: November 26, 2005, 07:48:39 am »
It looks like everything is wobbling .The car still runs but smokes like a champ when cold (blackish gray when cold blue when warm idling)Not much power alittle better when warm
Reply #8November 27, 2005, 03:14:46 pm
chrissev
  • 694
Re: pulley
« Reply #8 on: November 27, 2005, 03:14:46 pm »
well only one thing to do then.  Take the alternator belt pulley off the crank and have a look at the key in the crank pulley.  If it turns out that you have the keyway problem then you should not drive the car until you get it fixed as what usually happens is you get increasingly more and more movement in the key until you get piston valve collisions and the engine is destroyed.
Reply #9November 27, 2005, 03:34:34 pm
soslow
  • 15
pulley
« Reply #9 on: November 27, 2005, 03:34:34 pm »
In shop now will post results Thanks
Reply #10January 01, 2006, 06:50:25 pm
soslow
  • 15
crank pulley 1.9 td
« Reply #10 on: January 01, 2006, 06:50:25 pm »
Local tractor shop replaced crank pulley and welded keyway, reground to fit new pulley .NO MORE SMOKE ! Only 37 MPH maybe timing not right on?
Reply #11January 02, 2006, 06:53:18 pm
commuter boy
  • 277
« Reply #11 on: January 02, 2006, 06:53:18 pm »
Could be.  But Passat's never get the same mileage as a Golf of Jetta anyway.
What were you getting before?
Reply #12January 02, 2006, 07:27:41 pm
soslow
  • 15
« Reply #12 on: January 02, 2006, 07:27:41 pm »
Only second tank of fuel since bought car ,but reading other posts saying 900 plus some say 1150. Was hoping for better
Reply #13January 03, 2006, 07:37:24 am
zyewdall
  • 393
Re: crank pulley 1.9 td
« Reply #13 on: January 03, 2006, 07:37:24 am »
You mean 37mpg?  That sounds about right for what I've heard for Passat's.  If it really is 37mph, then I'd suspect something badly out of proper timing that is causing the lack of power.  The PO of my truck reported it had no power after having the engine rebuilt -- turns out the cam was one tooth off on the timing belt.  A clogged fuel filter will also severely limit top end power, though it may still idle fine.
'89 Subaru 4x4 touring wagon
1976 Ford Sasquatch pickup
Reply #14January 03, 2006, 06:26:15 pm
Jeff@TheQuadShop
  • 42
« Reply #14 on: January 03, 2006, 06:26:15 pm »
Can the crank be moded while its in the vehicle or does the crank need to be removed?
