Author Topic: Crank pulley 1.9 passat  (Read 8957 times)
Reply #15January 03, 2006, 07:08:20 pm
commuter boy
  • 277
« Reply #15 on: January 03, 2006, 07:08:20 pm »
Quote from: "soslow"
Only second tank of fuel since bought car ,but reading other posts saying 900 plus some say 1150. Was hoping for better
Well, I'm only getting 900 to a tank (hwy) with proper time and fresh injectors.  But I've got the pump without the boost aneroid on it, so that might be hurting it a bit.
Reply #16January 04, 2006, 04:39:00 am
soslow
  • 15
« Reply #16 on: January 04, 2006, 04:39:00 am »
Was done in car, but always ground the welder to the crank directly we used the old crank pulley bolt.
Reply #17January 04, 2006, 05:35:19 am
Jeff@TheQuadShop
  • 42
« Reply #17 on: January 04, 2006, 05:35:19 am »
How do you grind that flat spot on the crank perfectly straight and then turn the crank down where you filled in the slot with weld without putting it on a mill?
Reply #18January 04, 2006, 07:53:03 am
soslow
  • 15
« Reply #18 on: January 04, 2006, 07:53:03 am »
On mine the keyway was only a little sloppy,he built up a little ,then used a die grinder with various tips to fit new pulley
Reply #19January 04, 2006, 08:30:06 am
Jeff@TheQuadShop
  • 42
« Reply #19 on: January 04, 2006, 08:30:06 am »
So he hand ground the flat spot for the new pulley?
