Author Topic: Wants to see pics of your diesel in all its beauty!  (Read 171043 times)
Reply #90September 14, 2005, 10:47:16 am
RAMMSTEIN
  • 331
« Reply #90 on: September 14, 2005, 10:47:16 am »
A little update: I finally went for an engine instead of a car.
I bought RR blue engine along with tranny, stock turbo, intake, exhaust and intake manifold from another member.
I went to TDIfest in Wisconsin and a guy I know gave me: 1 AAZ block, 1 TDI block (don't know from what though), a 3000 miles old drive shaft (long one from a B4 TDI) and a brand new 22mm master cylinder.
As for the body that all this stuff will go into, I'll go with the lightest VW made since 1975.
I'll let you guys guess what it is.
Hint: it's watercooled and not a dune buggy... :wink:
For now, no more money, so the body will wait. :cry:
Rammstein
In abscence of light, darkness prevails.
Reply #91September 14, 2005, 10:49:25 am
RAMMSTEIN
  • 331
« Reply #91 on: September 14, 2005, 10:49:25 am »
Thanks for the fast reply.
I thought the ECOdiesel was a US only engine?
Guess not.
Rammstein
Reply #92September 14, 2005, 11:01:03 am
BlackTieTD
  • 1512
« Reply #92 on: September 14, 2005, 11:01:03 am »
well the body has to be an early rabbit or scirocco.  :D
Reply #93September 14, 2005, 11:01:22 am
Alcaid
  • 549
« Reply #93 on: September 14, 2005, 11:01:22 am »
Quote from: "RAMMSTEIN"
Guess not.
It's also sold in Europe, but not under the ECOdiesel name.
'10 VW Passat 1.6TDI Highline
Reply #94September 14, 2005, 03:18:01 pm
RAMMSTEIN
  • 331
« Reply #94 on: September 14, 2005, 03:18:01 pm »
Quote from: "BlackTieTD"
You got it! :wink:
Rammstein
Reply #95September 15, 2005, 04:41:40 am
BlackTieTD
  • 1512
« Reply #95 on: September 15, 2005, 04:41:40 am »
i like the sounds of this one already  :)
Reply #96September 20, 2005, 07:08:27 am
BlackTieTD
  • 1512
« Reply #96 on: September 20, 2005, 07:08:27 am »
is it a rabbit then??  :lol:
you can't abuse a scirocco quite like this:
 :lol:
Reply #97October 04, 2005, 12:43:00 pm
Master ACiD
  • 328
« Reply #97 on: October 04, 2005, 12:43:00 pm »
heres a couple pictures showing me test fitting a air dam and wheel well skirts on  my 84 rabbit with only 66K original miles on it! it was originally equipped with a gasoline fuel injected motor coupled to a 3 speed automatic. i am in the process of converting to a 5 speed and a 1.6 diesel motor.  i have lots of goodies including air conditioning and 10.2lb ultralight 15x6.5 konig helium wheels with falken ziex 205/50-15 summer tyres.
this is a southern car so its nearly rust free.
Reply #98October 13, 2005, 08:44:36 am
RAMMSTEIN
  • 331
« Reply #98 on: October 13, 2005, 08:44:36 am »
I just bought a 1988 Jetta (4 doors) TD!!!!
She won't get the tdi (she's a beater), but I got her for peanuts!!!
90$
She needs some work: timing belt, head gasket.... :roll:
Rammstein
Reply #99October 13, 2005, 04:26:32 pm
BlackTieTD
  • 1512
« Reply #99 on: October 13, 2005, 04:26:32 pm »
..so lets see some pics of this '88 in all its beauty!  :wink:
Reply #100October 13, 2005, 07:39:24 pm
RAMMSTEIN
  • 331
« Reply #100 on: October 13, 2005, 07:39:24 pm »
I'm on 56k but I'll try to get some pics...
She's not a beauty...man oh man...you get what you pay for... :shock:
A little bit of spray pain should mask all the rust... :lol:
She cost me 85$, I found 5$ worth of money inside :!:
A few things later (new tires, oil and coolant) and I'm around 370 total...
I hope everything will cost me less than 500$. :?
Rammstein
Reply #101November 26, 2005, 05:37:24 pm
52 horses
« Reply #101 on: November 26, 2005, 05:37:24 pm »
here is mine... '82 jetta with only 129,000 klms on it...
Reply #102November 26, 2005, 08:33:27 pm
v8volvo
  • 71
    • http://www.cardomain.com/profile/v8volvo
« Reply #102 on: November 26, 2005, 08:33:27 pm »
Here's my '81 Rabbit. Yes, I am a little proud of that bright red paint job on the rebuilt 1.6NA (took about 4 coats, Chrysler Industrial Red hi-temp engine paint).
Reply #103November 27, 2005, 09:54:28 am
mainer
  • 126
« Reply #103 on: November 27, 2005, 09:54:28 am »
My new to me 84 jetta diesel. Picked it up the other day for 500 bucks. I didn't want to spend that much but did anyway. It needs alot of work but will be a fun winter project. The glow plug relay is bad and the glow plugs wouldn't come on, so to start I had to connect the jumper cable directly to the plug. It hadn't run in 2 years and after cranking for awile and spraying some wd-40 in the intake it started up. I drove it home 30miles with no plates and one tail light at night.
It needs some door trim, and some bigger wheels the 13's dont do well on it.
A new coat of shiny paint, 16inch wheels and maybe some window tint.
Ya, I know no turbo the thing is nut less compared to my old 91 eco. But it is a race car compared to my friends 91 non turbo, I cant figure that one out. Hopefully I'll have a trubo and intercooler on it this spring.
Coop
_________________
mortgage bailout
01 Jetta
84 Jetta TD
08 Duramax
12 Sportwagen TDi
Reply #104November 27, 2005, 09:51:39 pm
mortskeg
  • 95
    • http://www.vwcaddy.com
« Reply #104 on: November 27, 2005, 09:51:39 pm »
