Author Topic: non AC alternator and bracket.  (Read 9902 times)
February 12, 2010, 02:42:40 pm
truckinwagen
  • 1895
« on: February 12, 2010, 02:42:40 pm »
while yanking the idle switch off of it, I noticed that the local yard has a diesel jetta without AC.
it has the hard to find non AC alt and bracketry that puts the alternator downwards instead of up top.
if anyone needs/wants such a set of brackets/pulleys I could find out what they want for it.
-Owen
83 Opel Kadett Diesel
Reply #1February 12, 2010, 04:10:57 pm
GEE-BEE
  • 1604
Re: non AC alternator and bracket.
« Reply #1 on: February 12, 2010, 04:10:57 pm »
Sure why not ?
GB
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #2February 12, 2010, 10:16:21 pm
  • 2932
« Reply #2 on: February 12, 2010, 10:16:21 pm »
If it's a MK2;
 the main alternator bracket is the same,.. AC or not.
It's the alternator and lower adjuster bracket that are different.
 If it's non-power steering; the u-joint and boot off the steering go for quite a bit on the vortex.
Reply #3February 12, 2010, 10:30:26 pm
truckinwagen
  • 1895
« Reply #3 on: February 12, 2010, 10:30:26 pm »
its a mk1, so it should be a different bracket(might be a motor swap, but will have to look further to tell)
good point on the steering shaft, I might have to grab that next time I am out there.
Reply #4February 13, 2010, 08:21:14 pm
  • 2932
« Reply #4 on: February 13, 2010, 08:21:14 pm »
Manual steering on a MK1 is pretty common.
 The A2s with manual steering,.. that's a little harder to find.
That MK1 alternator,and bracket should sell fast.
Reply #5February 14, 2010, 09:45:19 am
GEE-BEE
  • 1604
« Reply #5 on: February 14, 2010, 09:45:19 am »
let me know...
[email protected]
Giles Pump OHC
MK1 JETTA DASH
Reply #6February 15, 2010, 12:42:22 pm
truckinwagen
  • 1895
« Reply #6 on: February 15, 2010, 12:42:22 pm »
I will give them a call tonight to see what they want for it, and I can head out and grab the parts on friday.
-Owen
Reply #7February 15, 2010, 07:49:33 pm
  • 2932
« Reply #7 on: February 15, 2010, 07:49:33 pm »
Make sure to include the small upper bracket and adjuster bar,.. and include all the bolts; some are different than the AC bolts.
 Might want to grab the waterpump and crank pullys too.
Reply #8February 15, 2010, 07:59:07 pm
truckinwagen
  • 1895
« Reply #8 on: February 15, 2010, 07:59:07 pm »
will def get the pulleys
this one has the tensioner bracket on the bottom, and it attaches to the alt bracket, not the head.
-Owen
Reply #9February 16, 2010, 11:25:36 am
fck
  • 70
« Reply #9 on: February 16, 2010, 11:25:36 am »
this is relevant to my interests, but i've got a mk2, and have no idea if it's what i need or not.
argh!
Reply #10February 16, 2010, 11:26:58 am
truckinwagen
  • 1895
« Reply #10 on: February 16, 2010, 11:26:58 am »
I think the motor was from a MK2, it has the fuel return standoff on the pump, and a vane style vac pump.
I will take pics of it on friday when I head out that direction so you all can tell if it is what you want.
Reply #11February 18, 2010, 05:07:30 pm
truckinwagen
  • 1895
« Reply #11 on: February 18, 2010, 05:07:30 pm »
well, just got ahold of the shop with the alt and bracket, they say $120-ish(depending on what all I grab)
and I think I can cram it in a flatrate box to ship it, so how does $170 shipped(includes finders fee and fuel do go and get it) sound?
-Owen
Reply #12February 18, 2010, 07:31:10 pm
fck
  • 70
« Reply #12 on: February 18, 2010, 07:31:10 pm »
ah jeeze,
i just screwed up my trans really badly,
i'm rebuilding another one right now,
and my a/c delete cash just became emergency parts grab cash.
thanks for your time dude, i'm sorry to waste it.  :-\
Reply #13February 18, 2010, 07:33:55 pm
truckinwagen
  • 1895
« Reply #13 on: February 18, 2010, 07:33:55 pm »
nah, no waste.
I will still be grabbing the alt and bracket, so if anyone wants it they can have it.
if I still have it when cash i easier to come by you can have it ;)
Reply #14February 19, 2010, 04:26:25 pm
truckinwagen
  • 1895
« Reply #14 on: February 19, 2010, 04:26:25 pm »
got the alt and bracket.
have the pulleys that go with it and the belt too!
$170 shipped anywhere in the US.
-Owen
