Author Topic: which is better, K14 or T2?  (Read 8084 times)
December 06, 2009, 11:35:48 am
LoneWolf
« on: December 06, 2009, 11:35:48 am »
im building a replacement head for my AAZ, and ive got a choice of turbo units, so i was wondering which is the better unit, the KKK or the Garrett?
Reply #1December 06, 2009, 11:42:12 am
Re: which is better, K14 or T2?
« Reply #1 on: December 06, 2009, 11:42:12 am »
is the T2 water cooled? i would lean towards the K14.
Reply #2December 06, 2009, 12:11:28 pm
LoneWolf
« Reply #2 on: December 06, 2009, 12:11:28 pm »
it was a water cooled unit, but i never ran it water cooled
Reply #3December 06, 2009, 05:19:45 pm
blackdogvan
  • 574
« Reply #3 on: December 06, 2009, 05:19:45 pm »
According to some they are VERY similar.
1991 Vanagon 1.9 mTDI
Reply #4December 07, 2009, 04:32:32 pm
LoneWolf
« Reply #4 on: December 07, 2009, 04:32:32 pm »
How similar are we talking?
 i want it to be strong but be able to give me the 45psi im used to
Reply #5December 07, 2009, 06:22:14 pm
4wheeler
« Reply #5 on: December 07, 2009, 06:22:14 pm »
anything over 20psi on the K14 would be exceeding thermal efficiency of said turbo.
Might think of getting a VNT or K24
Reply #6December 08, 2009, 12:11:58 am
LoneWolf
« Reply #6 on: December 08, 2009, 12:11:58 am »
Reply #7December 08, 2009, 12:22:15 am
anto
« Reply #7 on: December 08, 2009, 12:22:15 am »
The peugeot 306 came with both those turbos.
On that application its been found that the t2 will spool quicker and is a more robust turbo than the k14.
K14 more easily adjusted however.
General consensus with 306 owners is that the t2 is better.
Im not sure if that helps you vw owners but i htought id give my 2cents.
Reply #8December 08, 2009, 12:35:37 am
anto
« Reply #8 on: December 08, 2009, 12:35:37 am »
I dont even know i could have even got my k14 to 30psi let alone 45psi!
26psi was the most i ever seen with wastegate wound in as far as possible....you could tell it didnt like it either....
Is it even possible to reach 45psi on a k14?????
Reply #9December 08, 2009, 01:04:08 am
LoneWolf
« Reply #9 on: December 08, 2009, 01:04:08 am »
the t2 i was running origonaly has expired, and the k14 was a steal, but you guys recon that itll die a death if i use it like a t2?
Reply #10December 08, 2009, 02:32:19 am
anto
« Reply #10 on: December 08, 2009, 02:32:19 am »
If the k14 was a steal then you may as well throw it on and hope for the best?
In the meantime while it is on you could search out a t2 should the unfortunate happen?
How did you manage 45psi out of a t2????
Reply #11December 08, 2009, 09:08:39 am
LoneWolf
« Reply #11 on: December 08, 2009, 09:08:39 am »
all boost reliefs eg BOV, wastegate etc blocked off tight, bit more fuel and alot of right foot
Reply #12December 08, 2009, 09:15:34 am
blackdogvan
  • 574
« Reply #12 on: December 08, 2009, 09:15:34 am »
You should be looking for a K24 or a T3 i'd say.
Reply #13December 08, 2009, 09:23:55 am
LoneWolf
« Reply #13 on: December 08, 2009, 09:23:55 am »
hold on 1 sec, is it 15psi to 1 barr or 7.5??
ffs, my heads up my arse again, 45psi is over 2 barr isnt it?
 my T2 made 1,5barr, so thats... 22.5 psi?
Reply #14December 08, 2009, 09:25:21 am
anto
« Reply #14 on: December 08, 2009, 09:25:21 am »
1bar is 14.7psi i think...
