Author Topic: I want my own 2.1AAZ.  (Read 4918 times)
December 05, 2009, 10:14:18 am
FuryriderX
  • 14
« on: December 05, 2009, 10:14:18 am »
I want to build my rabbit as my fun car.  And track it.  Since its already a diesel, i figured why not stay with it.
Hopefully in the next week i'm picking up a rebuilt (knurled pistons tho, ew) 1.6td and a junk (sheared crank keyway) 1.9.
The 1.9 is missing most of the accessories and the turbo/inj pump, but it still has the manifolds.
Don't know what it looks like inside, but the price is good.  I'd most likely giles-ize the pump and toss in the 1.6, get the exhaust and intercooler routing all sorted, then build up the 1.9/2.1 slowly.
Anyhow.  I read the thread that was linked a while back about the 2.1L aaz and decided to see if i could find those pistons.  Well, thanks to ebay, i did.
http://cgi.ebay.ca/ws/eBayISAPI.dll?ViewItem&item=120347361616&ssPageName=STRK:MEWAX:IT  It seems like these are 1mm oversize, so 84mm bore i suppose.
Apparently that price is for 4!  And if the picture is to be believed, they include rings.  I have no idea who the manufacturer is.  Maybe someone recognizes the logo on the box?
I have been highly unsuccessful in finding out the height and wrist pin size (to see what rod i'd need) - anyone have any ideas where i could look for this info?
How cool would a diesel track rabbit be??  I'm sure its been done loads of times before, but i'd just love to kick some ass with a td rabbit.
'84 rabbit L diesel
'01 golf tdi
Reply #1December 05, 2009, 10:18:14 am
rabbitman
  • 2788
Re: I want my own 2.1AAZ.
« Reply #1 on: December 05, 2009, 10:18:14 am »
It looked to me like that ebay link was for one piston.
Reply #2December 05, 2009, 10:34:44 am
« Reply #2 on: December 05, 2009, 10:34:44 am »
it clearly states that the price is for 4 pistons.
Reply #3December 05, 2009, 10:38:31 am
rabbitman
  • 2788
« Reply #3 on: December 05, 2009, 10:38:31 am »
My merstake, I didn't read it good enough.
Reply #4December 05, 2009, 10:41:09 am
« Reply #4 on: December 05, 2009, 10:41:09 am »
its alright, the only reason i looked again, was because i, like you, was skeptical on the price.
Reply #5December 05, 2009, 12:24:58 pm
  • 5104
« Reply #5 on: December 05, 2009, 12:24:58 pm »
i think theyd be 83.5mm stock bore is 82.5, im not sure tho
Reply #6December 05, 2009, 12:29:08 pm
  • 5104
« Reply #6 on: December 05, 2009, 12:29:08 pm »
basically a 2.2 liter either way
Reply #7December 05, 2009, 02:50:06 pm
55eta
« Reply #7 on: December 05, 2009, 02:50:06 pm »
the logo looks like they are MAHLE not 100% on that though if so they were o/e suplyers
Reply #8December 06, 2009, 04:46:33 pm
truckinwagen
  • 1895
« Reply #8 on: December 06, 2009, 04:46:33 pm »
how thin would that make the cylinder walls?
the general consensus is that a 1.6 block does not have enough meat in the cylinder walls to bore it out and use 1.9 pistons, I just wonder if the AAZ has enough to use the bigger pistons.
this also brings up the question, how much wall thickness is needed?
83 Opel Kadett Diesel
Reply #9December 06, 2009, 08:34:50 pm
FuryriderX
  • 14
« Reply #9 on: December 06, 2009, 08:34:50 pm »
well hopefully soon i'll have a 1.9 to look at, and if that is indeed the price for 4 pistons, i'll order a set and see what happens.  150 bucks shipped for a set of pistons is dirt cheap, i might as well check it out.  for everyone else's benefit at least.
'84 rabbit L diesel
'01 golf tdi
Reply #10December 07, 2009, 12:07:12 pm
55eta
« Reply #10 on: December 07, 2009, 12:07:12 pm »
I read the same thread and from what i can remember the photos showed very little left between cylinders and i think they were standard size pistons if that is the case those pistons would take 2mm from what little that engine had between cylinders think i would be taking another look at that thread? and check the liner thickness  plus they have 10 sets available there not going to sell them in a hurry as those engines are just about obsolete over here {£50 each for a complete engine }
Reply #11December 08, 2009, 06:47:35 am
FuryriderX
  • 14
« Reply #11 on: December 08, 2009, 06:47:35 am »
here's the picture again.
still looks like there's going to be a fair bit of meat between cylinders, but pictures can be deceiving.  i have my 1.9 block now, so i'll do some measurements and post up the results.
'84 rabbit L diesel
'01 golf tdi
Reply #12December 08, 2009, 10:10:55 am
55eta
« Reply #12 on: December 08, 2009, 10:10:55 am »
looks that way with a copper h/g could be doable, will be interested in measurements
Reply #13December 08, 2009, 10:15:00 am
truckinwagen
  • 1895
« Reply #13 on: December 08, 2009, 10:15:00 am »
the issue is not the amount of deck left between the cylinders, but the actual thickness of the cylinder walls.
Reply #14December 08, 2009, 10:24:43 am
55eta
« Reply #14 on: December 08, 2009, 10:24:43 am »
I agree that would be my concern ,any idea what the diameter of the stock aaz bores
