Author Topic: Question  (Read 5013 times)
Reply #15October 27, 2009, 03:59:00 pm
Re: Question
« Reply #15 on: October 27, 2009, 03:59:00 pm »
so i can disable the intank pump, and the engine will still run?
With the diesel, yes, provided fuel can still flow through the pump.
Reply #16October 27, 2009, 04:00:14 pm
nickzom
  • 23
Re: Question
« Reply #16 on: October 27, 2009, 04:00:14 pm »
ok, it also looks like then engine i am going to get has no alternator, can I use my gas alternator?
Reply #17October 27, 2009, 07:13:23 pm
Re: Question
« Reply #17 on: October 27, 2009, 07:13:23 pm »
If it fit's than yes (unless someone who knows more says no ;)). If you are going to run the stock diesel tach then it needs a W terminal.
Reply #18October 27, 2009, 08:36:00 pm
Re: Question
« Reply #18 on: October 27, 2009, 08:36:00 pm »
what year is your car? if its 84 or older, it has no in tank pumps. if it has an in tank pump. its low pressure. use it for your lift pump, it will put out about 4 or 5 psi if i remember right. just be sure to take the high pressure external pump out of the fuel line.
Reply #19October 28, 2009, 03:48:53 am
nickzom
  • 23
Re: Question
« Reply #19 on: October 28, 2009, 03:48:53 am »
its a 1986. i wasn't sure if i needed the in tank pump, if i dont i will take it out.
for now i wont be running a tach.
Reply #20October 28, 2009, 09:26:54 am
Re: Question
« Reply #20 on: October 28, 2009, 09:26:54 am »
leave it there, it will be perfect for priming the system. and it will act as a lift pump. now you wont have to sit there and crank your engine for 5 minutes every time you lose your prime or run out of diesel.
Reply #21October 28, 2009, 09:35:12 am
nickzom
  • 23
Re: Question
« Reply #21 on: October 28, 2009, 09:35:12 am »
ok
Reply #22October 28, 2009, 09:36:47 am
Re: Question
« Reply #22 on: October 28, 2009, 09:36:47 am »
well, unless of course you feel the need to disconnect it. it might become a restriction if you un plug it. thats all im thinking. you want fuel to get to the IP as freely as possible. not my project, but i would leave it there hooked up.
Reply #23October 28, 2009, 10:09:46 am
nickzom
  • 23
Re: Question
« Reply #23 on: October 28, 2009, 10:09:46 am »
i will leave it hooked up.
