Author Topic: POLL: Turbo or NA? Just out of Curiosity  (Read 3225 times)
September 10, 2009, 12:01:43 pm
camboscams
  • 324
« on: September 10, 2009, 12:01:43 pm »
Seems to be a good mix of all set-ups, just wanted to see some numbers
« Last Edit: September 10, 2009, 12:03:34 pm by camboscams »
81' White 1.6l Rabbit 4dr Holseted
72' Ford F-250 390cid
2014 JSW 2.0L TDI Stg 2, CP3 HPFP
Reply #1September 10, 2009, 02:34:47 pm
maxfax
  • 2126
Re: POLL: Turbo or NA? Just out of Curiosity
« Reply #1 on: September 10, 2009, 02:34:47 pm »
NA all the way!!!   I like not having extra stuff to go wrong or get in the way... And with my current driving record the inablity to seriosly speed is good..   If I need a power fix I'll drive one of my other toys...
Reply #2September 10, 2009, 04:40:55 pm
« Reply #2 on: September 10, 2009, 04:40:55 pm »
being able to pass cars, and spurt is very good though! unless you tweak your N/A pump, the car is usually quite a dog.  the K24 or T3 has a very good track record if you just run them at stock levels.
if i had a nice shop and the time, i'd probably fab up a permanent magnet bearing turbo. ohhh yea!  you N/A boys would be creaming your pants for one of those  ;D the spool time would be near zero, and the turbo would actually be able to power itself (using pulse motor technology, inductively charging itself) so not only is spool time reduced, but the turbo would actually be running at more than 100% efficiency.  next we'll talk about permanent magnet alternators, and how they consume about 1/2 the HP of a normal alternator.  8)
« Last Edit: September 10, 2009, 04:46:13 pm by jtanguay »
Reply #3September 10, 2009, 06:06:45 pm
maxfax
  • 2126
« Reply #3 on: September 10, 2009, 06:06:45 pm »
Well yeah, my pump is molested..  I'll handle most typical and necessary passing okay..  If I need a serious power fix though, I have the Crown Vic PI...
Yeah right!   ;D
I've read a bit about these..  Very interesting stuff...  I had to stop myself from going any further as I already have too much going on..
Reply #4September 10, 2009, 06:57:19 pm
« Reply #4 on: September 10, 2009, 06:57:19 pm »
NA all the way!!!
You said it! I love my 1.9 NA :)
Reply #5September 10, 2009, 07:33:31 pm
« Reply #5 on: September 10, 2009, 07:33:31 pm »
Yeah right!   ;D
its very interesting indeed. i wish someone would come out with a kit to convert bosch alternators (a permanent magnet rotor hint hint)
Reply #6September 10, 2009, 11:09:43 pm
maxfax
  • 2126
« Reply #6 on: September 10, 2009, 11:09:43 pm »
Agreed!!!
My time and tooling is tied up for a while with fitting a hall effect sensor in a slant six distributor, assembling some variety of engine management computer, and fabricating an exhaust manifold so that I can........finish my turbo slant six build.. :-[
OKay I better rephrase myself
NA ALL THE WAY, on my VW
Actually isn;t such a beast available in the Gm Delco variety..   The one's I'm thinking of were identical to the alternators that GM used in the late 70's to the Mid 80's..  I can verify that this style of alternator is an easy swap onto a non a/c mk1...
« Last Edit: September 10, 2009, 11:15:23 pm by maxfax »
Reply #7September 10, 2009, 11:33:59 pm
ByramTra
  • 9
« Reply #7 on: September 10, 2009, 11:33:59 pm »
NA 1.6, Not by choice. :( , only price. B-)
1982 VW Rabbit 1.6D
Reply #8September 11, 2009, 03:34:09 am
rs899
  • 647
« Reply #8 on: September 11, 2009, 03:34:09 am »
2 1.6 NAs.  Can't seem to find anything else anymore.....
Rick
Reply #9September 11, 2009, 05:34:51 am
Vanagoner
  • 219
« Reply #9 on: September 11, 2009, 05:34:51 am »
N/A by choice and economic neccessity. I have a turbo I could fab together but just want simplicity and reliability for now. I just finished a cold air intake box for a cone filter inside the left air scoop column.  Gave me an extra 10 mph over a long grade I drive all of the time, just with that improvement.  This weekend I pull the double downpipe exhaust off of a donor '74 audi, and I'll see what a 4-2-1 can do.
Sage
Reply #10September 11, 2009, 05:57:32 am
truckoSaurus08
  • 65
« Reply #10 on: September 11, 2009, 05:57:32 am »
So what would and ECO diesel count as? Id say both turbo and n/a. ;D
Also, I guess for me to be part of this poll I would have to have both my eco and n/a "running" ::)
Reply #11September 11, 2009, 08:29:23 am
camboscams
  • 324
« Reply #11 on: September 11, 2009, 08:29:23 am »
Tight race between NA's and TD!!!
Reply #12September 11, 2009, 08:41:44 am
zozie
  • 122
    • Rotoconcept Robotics
« Reply #12 on: September 11, 2009, 08:41:44 am »
N/A here as well. N/A cause thats what was sitting on the street close to home with the 4sale sign :)
Reply #13September 11, 2009, 08:43:21 am
camboscams
  • 324
« Reply #13 on: September 11, 2009, 08:43:21 am »
Nice 8)
Reply #14September 11, 2009, 09:07:57 am
« Reply #14 on: September 11, 2009, 09:07:57 am »
pfft, turbo all the way. there is no such thing as too much boost. i still get 35 mpg with a black stream behind me. and if i can have something to beat on, have a great time, and still get around 35mpg, im gonna stay with it.
