Fuel screw collar removal
Topic: Fuel screw collar removal (Read 3312 times)
August 28, 2009, 12:22:08 pm
ByramTra
Newbie
August 28, 2009, 12:22:08 pm »
I have tried to remove the collar on the IP fuel screw, to no avail. I have also done some searching and havn't found anything yet. I completely ground threw the collar on one side and it didn't come loose, I have one spare screw in a spare pump, so...
Any idias?
Thanks
Travis
1982 VW Rabbit 1.6D
August 28, 2009, 12:41:12 pm
92EcoDiesel Jetta
Re: Fuel screw collar removal
August 28, 2009, 12:41:12 pm »
Did you try loosening the lock nut, then turn the screw, leaving the collar alone?
August 28, 2009, 06:54:30 pm
ByramTra
Newbie
August 28, 2009, 06:54:30 pm »
Ya, got it to go in slightly, will have to try it on the other one.
1982 VW Rabbit 1.6D
August 28, 2009, 09:07:37 pm
rabbid79
August 28, 2009, 09:07:37 pm »
On my '79 the collar was spot welded to the screw in a couple of places. It took a lot of effort to get it off without messing up the screw. It still damaged a couple of threads though. I wonder if it would actually be better to drill the pump slightly so that the collar would turn in a little further.
'15 WRX
August 28, 2009, 09:26:20 pm
HumminCummins
User+
August 28, 2009, 09:26:20 pm »
I used a dremal tool to cut my lose. just take your time and be patient. A Little peice of metal is HOPEFULLY not smarter then you.
If its not blowin black.. Its not running right.
August 28, 2009, 09:45:18 pm
ByramTra
Newbie
August 28, 2009, 09:45:18 pm »
I did try cutting it but must not have gotten all the way threw, although I think i did start getting into the threads. if I did end up removing some of the threads it should still be fine though, when I get a chance I will try to work on it some more.
Travis
1982 VW Rabbit 1.6D
August 28, 2009, 10:10:20 pm
53 willys
August 28, 2009, 10:10:20 pm »
I cut mine with a small cutting wheels on an 1/4" angle air grinder...then I used a small chisel to break it loose and off the screw..
August 29, 2009, 10:19:37 am
rallydiesel
August 29, 2009, 10:19:37 am »
Wow, spot welded? Normally you can simply pry it off with a screwdriver blade.
1991 Jetta TD - sold
2001 Golf TDI - Son's
August 29, 2009, 12:52:20 pm
August 29, 2009, 12:52:20 pm »
mine was spot welded on the shaft, and crimped too. it was kinda a bastard to get off, but i did it.
August 29, 2009, 01:37:27 pm
ByramTra
Newbie
August 29, 2009, 01:37:27 pm »
I know mine is crimped on, and being in california I wouldn't be suprised if it is spot welded also, just havn't inspected it good enough.
Travis
1982 VW Rabbit 1.6D
August 29, 2009, 06:30:57 pm
vwjones
August 29, 2009, 06:30:57 pm »
dremel tool with a cutoff wheel. the fiber one that doesn't snap. cut through it and turn it half a turn out and cut through it again. if it is spot welded as mine was, cut it there. should practically fall off then.
Reply #11
August 29, 2009, 11:11:35 pm
Reply #11 on:
August 29, 2009, 11:11:35 pm »
chisel it off.
