wastegate vac can is seperated..
Topic: wastegate vac can is seperated.. (Read 2254 times)
June 20, 2009, 06:20:00 pm
sour diesel
Newbie
June 20, 2009, 06:20:00 pm »
the can that has lines running to it has come apart...? my question is what do i use as a replacement, & what can I use to up my boost pressur closer to 14-19psi. im totally stumped here..
June 21, 2009, 08:33:21 pm
rallydiesel
Re: wastegate vac can is seperated..
June 21, 2009, 08:33:21 pm »
If it's not a VNT then it's a boost "can". VNT's use the vacuum can. You could try putting it back together, assuming it came apart at the crimp. You'd need to seal it and put some type of external clamp to hold it together.
1991 Jetta TD - sold
2001 Golf TDI - Son's
June 22, 2009, 03:16:18 pm
sour diesel
Newbie
June 22, 2009, 03:16:18 pm »
Yes its the "boost" can. Im more interested in eliminating this altogether as it seems a bit hokey to begin with. Ive read & searched but im looking for another option that will allow me to raise & have adjustable boost, without replacing the turbo because the vehicle only has 100k miles...
June 22, 2009, 04:46:00 pm
rallydiesel
June 22, 2009, 04:46:00 pm »
If you want to adjust and control your boost you will need the can.
June 22, 2009, 07:48:20 pm
sour diesel
Newbie
June 22, 2009, 07:48:20 pm »
Quote from: rallydiesel on June 22, 2009, 04:46:00 pm
sooo, do i just rebuild the can with a stiffer spring? please elaborate..tia
