Author Topic: wastegate vac can is seperated..  (Read 2242 times)
June 20, 2009, 06:20:00 pm
sour diesel
  • 19
« on: June 20, 2009, 06:20:00 pm »
the can that has lines running to it has come apart...? my question is what do i use as a replacement, & what can I use to up my boost pressur closer to 14-19psi. im totally stumped here..
Reply #1June 21, 2009, 08:33:21 pm
rallydiesel
  • 1880
Re: wastegate vac can is seperated..
« Reply #1 on: June 21, 2009, 08:33:21 pm »
If it's not a VNT then it's a boost "can". VNT's use the vacuum can. You could try putting it back together, assuming it came apart at the crimp. You'd need to seal it and put some type of external clamp to hold it together.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #2June 22, 2009, 03:16:18 pm
sour diesel
  • 19
« Reply #2 on: June 22, 2009, 03:16:18 pm »
Yes its the "boost" can. Im more interested in eliminating this altogether as it seems a bit hokey to begin with. Ive read & searched but im looking for another option that will allow me to raise & have adjustable boost, without replacing the turbo because the vehicle only has 100k miles...
Reply #3June 22, 2009, 04:46:00 pm
rallydiesel
  • 1880
« Reply #3 on: June 22, 2009, 04:46:00 pm »
If you want to adjust and control your boost you will need the can.
Reply #4June 22, 2009, 07:48:20 pm
sour diesel
  • 19
« Reply #4 on: June 22, 2009, 07:48:20 pm »
sooo, do i just rebuild the can with a stiffer spring? please elaborate..tia
