still nothing :(
4
Topic: still nothing :( (Read 13246 times)
January 04, 2009, 01:49:08 pm
96jetta
still nothing :(
January 04, 2009, 01:49:08 pm »
ive got 300+ psi in all cylanders and all the timing marks line up. however she still doesnt even caugh
. is there something im over looking? or has some thing gone tarribly wrong?
January 04, 2009, 01:54:52 pm
mud and diesel
User+
still nothing :(
January 04, 2009, 01:54:52 pm »
glow plugs? Live to pump? pump primed? all of these would contribute to a no run situation! hope this helps
pete
January 04, 2009, 02:01:00 pm
96jetta
still nothing :(
January 04, 2009, 02:01:00 pm »
prim the pump??
January 04, 2009, 02:03:18 pm
mud and diesel
User+
still nothing :(
January 04, 2009, 02:03:18 pm »
Yup!, crack the nuts on the injectors and turn the motor over until diesel starts to seep out of each injector. a lift pump would would help here too.
January 04, 2009, 02:08:20 pm
Sierra94
Dieselsmoke in every stroke... M-Tdi Mazda!!
still nothing :(
January 04, 2009, 02:08:20 pm »
Try to pullstart it. Iīve had some troubles in my days with cranking and cranking even though I primed the pump and what not. And they still donīt start. And when pulled they always come to life. Sometimes the starter doesnīt manage to get the last air out of the system.
<-- My M-tdi Mazda B-1800 and
my other cars
January 04, 2009, 02:17:28 pm
vanagonturbo
still nothing :(
January 04, 2009, 02:17:28 pm »
glow plugs?
January 04, 2009, 03:11:18 pm
96jetta
still nothing :(
January 04, 2009, 03:11:18 pm »
oh ya ive done that and i got fuel in all the lines. but i cheacked the power to the glow plugs and i got a steady 0 DCV
. thats what i assume the problem currently lies
January 04, 2009, 03:13:29 pm
vanagonturbo
still nothing :(
January 04, 2009, 03:13:29 pm »
Check glow plug fuse.
check blue/white wire connection on temp sender for glow plug relay.
check glow plug relay.
if you really need to start it right now, run a jumper wire from the battery positive to the glow plug bus, count to 15, then disconnect the wire and run inside the car and crank it over.
probably the glow plug fuse though. Does the light come on?
January 04, 2009, 03:15:03 pm
still nothing :(
January 04, 2009, 03:15:03 pm »
does it have a block heater? plug that in for a good half hour or so and that should help. 300+ psi compression with glow plugs should start down to -5C without much trouble. maybe a lumpy idle, but thats it. when its cold things shrink, and fuel lines harden, so usually air leaks into the system, compounding the problem...
January 04, 2009, 03:17:46 pm
96jetta
still nothing :(
January 04, 2009, 03:17:46 pm »
ya the glow plug light still comes on. and i tryed pluggin in the block heater it caughed then died again
January 04, 2009, 03:22:04 pm
vanagonturbo
still nothing :(
January 04, 2009, 03:22:04 pm »
check the fuse.
Reply #11
January 04, 2009, 03:26:11 pm
96jetta
still nothing :(
Reply #11 on:
January 04, 2009, 03:26:11 pm »
its like #15 right? the pne for engin electronics?
cuz that one is good. but ive heard of a glow plug relay and m tryin to find where that is but no luck yet
Reply #12
January 04, 2009, 03:29:18 pm
vanagonturbo
still nothing :(
Reply #12 on:
January 04, 2009, 03:29:18 pm »
I know this is probably a stupid question, but what year is the car you are working on?
Reply #13
January 04, 2009, 03:31:35 pm
96jetta
still nothing :(
Reply #13 on:
January 04, 2009, 03:31:35 pm »
96 it was made in febuary if it makes a difference
Reply #14
January 04, 2009, 03:33:35 pm
still nothing :(
Reply #14 on:
January 04, 2009, 03:33:35 pm »
Just to avoid confusion... the yellow light on the dash has nothing to do with the glowplugs having power (unfortunately :wink:) and the engine management fuse (if equiped) is not the glow plug fuse.
The glowplug fuse is the big silvery strip in a small black plastic box bolted to the firewall to the left of the brake booster... has two big red wires coming out of it.
On the MK3s there is sometimes another glow plug fuse in a pink fuse holder at the top of the fuse panel on the drivers side under the dash.
The glow plug relay is also on the fuse panel... it's a tall rectangular box on MK2s and a fatter square box on MK3s.
Regardless of chassis the workaround from a troubleshooting perspective is to run a heavy wire from the positive terminal on the battery directly to the copper glowplug buss bar for 20-30 seconds and then try to start the car.... this bypasses both the relay and the fuse.
4
still nothing :(
