Author Topic: still nothing :(  (Read 13151 times)
Reply #15January 04, 2009, 03:40:35 pm
96jetta
still nothing :(
« Reply #15 on: January 04, 2009, 03:40:35 pm »
there is no wires or box on the fire wall at all. is it hidden behin something or possibly some where else
Reply #16January 04, 2009, 03:41:38 pm
vanagonturbo
  • 639
    • Fine Tuning
still nothing :(
« Reply #16 on: January 04, 2009, 03:41:38 pm »
Correct that the glow plug light has nothing to do with glow plugs getting power. i was just making sure that the relay was trying to turn on the glow plugs ;)
I think on all MKIIIs the glow plug fuse is above the fusebox. It will be a very large fuse (50A) which you can find a replacement at most car stereo shops.
i dont remember the part number of the relay off the top of my head but on the side of it is printed 'glühsteurgerat'.
Reply #17January 04, 2009, 03:52:54 pm
96jetta
still nothing :(
« Reply #17 on: January 04, 2009, 03:52:54 pm »
its a normal straight glass fues?
Reply #18January 04, 2009, 04:02:10 pm
ezekiel
  • 147
still nothing :(
« Reply #18 on: January 04, 2009, 04:02:10 pm »
no, it's a flat blade of copper.  big piece of flat copper.
Reply #19January 04, 2009, 04:05:35 pm
vanagonturbo
  • 639
    • Fine Tuning
still nothing :(
« Reply #19 on: January 04, 2009, 04:05:35 pm »
looks like the one on the left, but its orange or red.
edit: dont know right from left lol!
Reply #20January 04, 2009, 04:08:05 pm
96jetta
still nothing :(
« Reply #20 on: January 04, 2009, 04:08:05 pm »
ya that one is good its not cracked or split. should i chang it anyway?
Reply #21January 04, 2009, 04:13:05 pm
vanagonturbo
  • 639
    • Fine Tuning
still nothing :(
« Reply #21 on: January 04, 2009, 04:13:05 pm »
do you have a multimeter? or a test light?
you are talking about the huge fuse above the fusebox right? the fuse in question is MUCH larger than the fuses 1-22 on the fusebox itself.
Is there a story here or did you just come out to the car and try to start it?
Reply #22January 04, 2009, 04:17:08 pm
96jetta
still nothing :(
« Reply #22 on: January 04, 2009, 04:17:08 pm »
is there another set of fuses behind the 1-22?? and what do u mean story? lol
Reply #23January 04, 2009, 04:22:27 pm
vanagonturbo
  • 639
    • Fine Tuning
still nothing :(
« Reply #23 on: January 04, 2009, 04:22:27 pm »
Story. As in, did you do an engine swap? Did you just buy the car? Was it recently abducted by aliens and now it wont start? that kinda story :)
The fuse in question is on top of the fusebox and mounted horizontally, not vertically like the rest of the fuses (1-22). It is mounted with the other relays on top of the fusebox. its going to be kinda hard to see, so take a flashlight.
Reply #24January 04, 2009, 04:30:19 pm
96jetta
still nothing :(
« Reply #24 on: January 04, 2009, 04:30:19 pm »
ya i found it blown appart lol. oh got ya. well i bought the car in the summer it had been sitting around in a lot for a while but ut ran good. so i added more boost (ran a good 20psi :D). then i decided to c how fast it would go got up to 192kph and 4200rpm. it ran rough after that. then not at all :(. so i started pulling it appart and i found lifter shards all across the top of the head. so i pulled the head off did the guasket cheacked the valves put it all back to gether with a new belt and tentioner. and it still doesnt wana start :(
Reply #25January 04, 2009, 04:40:54 pm
vanagonturbo
  • 639
    • Fine Tuning
still nothing :(
« Reply #25 on: January 04, 2009, 04:40:54 pm »
you found the fuse blown apart?
Reply #26January 04, 2009, 04:51:40 pm
96jetta
still nothing :(
« Reply #26 on: January 04, 2009, 04:51:40 pm »
ya it blew it self apart like it normally would theres a crack in the middle of it. is this not normal?
Reply #27January 04, 2009, 04:53:06 pm
vanagonturbo
  • 639
    • Fine Tuning
still nothing :(
« Reply #27 on: January 04, 2009, 04:53:06 pm »
It is perfectly normal for a blown fuse :p go get a new one and you should be good to go!
Reply #28January 04, 2009, 05:18:37 pm
96jetta
still nothing :(
« Reply #28 on: January 04, 2009, 05:18:37 pm »
lets hope :). thanks for all the help guys
Reply #29January 04, 2009, 05:24:12 pm
vanagonturbo
  • 639
    • Fine Tuning
still nothing :(
« Reply #29 on: January 04, 2009, 05:24:12 pm »
no prob. it was fun :)
