still nothing :(
Pages:
4
Topic: still nothing :( (Read 13190 times)
Reply #15
January 04, 2009, 03:40:35 pm
96jetta
still nothing :(
Reply #15 on:
January 04, 2009, 03:40:35 pm »
there is no wires or box on the fire wall at all. is it hidden behin something or possibly some where else
Reply #16
January 04, 2009, 03:41:38 pm
vanagonturbo
still nothing :(
Reply #16 on:
January 04, 2009, 03:41:38 pm »
Correct that the glow plug light has nothing to do with glow plugs getting power. i was just making sure that the relay was trying to turn on the glow plugs
I think on all MKIIIs the glow plug fuse is above the fusebox. It will be a very large fuse (50A) which you can find a replacement at most car stereo shops.
i dont remember the part number of the relay off the top of my head but on the side of it is printed 'glühsteurgerat'.
Reply #17
January 04, 2009, 03:52:54 pm
96jetta
still nothing :(
Reply #17 on:
January 04, 2009, 03:52:54 pm »
its a normal straight glass fues?
Reply #18
January 04, 2009, 04:02:10 pm
ezekiel
still nothing :(
Reply #18 on:
January 04, 2009, 04:02:10 pm »
no, it's a flat blade of copper. big piece of flat copper.
Reply #19
January 04, 2009, 04:05:35 pm
vanagonturbo
still nothing :(
Reply #19 on:
January 04, 2009, 04:05:35 pm »
looks like the one on the left, but its orange or red.
edit: dont know right from left lol!
Reply #20
January 04, 2009, 04:08:05 pm
96jetta
still nothing :(
Reply #20 on:
January 04, 2009, 04:08:05 pm »
ya that one is good its not cracked or split. should i chang it anyway?
Reply #21
January 04, 2009, 04:13:05 pm
vanagonturbo
still nothing :(
Reply #21 on:
January 04, 2009, 04:13:05 pm »
do you have a multimeter? or a test light?
you are talking about the huge fuse above the fusebox right? the fuse in question is MUCH larger than the fuses 1-22 on the fusebox itself.
Is there a story here or did you just come out to the car and try to start it?
Reply #22
January 04, 2009, 04:17:08 pm
96jetta
still nothing :(
Reply #22 on:
January 04, 2009, 04:17:08 pm »
is there another set of fuses behind the 1-22?? and what do u mean story? lol
Reply #23
January 04, 2009, 04:22:27 pm
vanagonturbo
still nothing :(
Reply #23 on:
January 04, 2009, 04:22:27 pm »
Story. As in, did you do an engine swap? Did you just buy the car? Was it recently abducted by aliens and now it wont start? that kinda story
The fuse in question is on top of the fusebox and mounted horizontally, not vertically like the rest of the fuses (1-22). It is mounted with the other relays on top of the fusebox. its going to be kinda hard to see, so take a flashlight.
Reply #24
January 04, 2009, 04:30:19 pm
96jetta
still nothing :(
Reply #24 on:
January 04, 2009, 04:30:19 pm »
ya i found it blown appart lol. oh got ya. well i bought the car in the summer it had been sitting around in a lot for a while but ut ran good. so i added more boost (ran a good 20psi
). then i decided to c how fast it would go got up to 192kph and 4200rpm. it ran rough after that. then not at all
. so i started pulling it appart and i found lifter shards all across the top of the head. so i pulled the head off did the guasket cheacked the valves put it all back to gether with a new belt and tentioner. and it still doesnt wana start
Reply #25
January 04, 2009, 04:40:54 pm
vanagonturbo
still nothing :(
Reply #25 on:
January 04, 2009, 04:40:54 pm »
you found the fuse blown apart?
Reply #26
January 04, 2009, 04:51:40 pm
96jetta
still nothing :(
Reply #26 on:
January 04, 2009, 04:51:40 pm »
ya it blew it self apart like it normally would theres a crack in the middle of it. is this not normal?
Reply #27
January 04, 2009, 04:53:06 pm
vanagonturbo
still nothing :(
Reply #27 on:
January 04, 2009, 04:53:06 pm »
It is perfectly normal for a blown fuse :p go get a new one and you should be good to go!
Reply #28
January 04, 2009, 05:18:37 pm
96jetta
still nothing :(
Reply #28 on:
January 04, 2009, 05:18:37 pm »
lets hope
. thanks for all the help guys
Reply #29
January 04, 2009, 05:24:12 pm
vanagonturbo
still nothing :(
Reply #29 on:
January 04, 2009, 05:24:12 pm »
no prob. it was fun
Pages:
4
still nothing :(
