Author Topic: Differences between cams  (Read 3190 times)
November 24, 2008, 11:33:32 am
ObscuredByClouds
  • 98
« on: November 24, 2008, 11:33:32 am »
Whats the difference between the all the diesel cams? NA vs TD they're the same, yes?
Also, how do you tell the difference between a hydro cam and a mechanical lifter cam?
Reply #1November 24, 2008, 02:41:09 pm
boosted_diesel_84
  • 216
« Reply #1 on: November 24, 2008, 02:41:09 pm »
N/A and TD cams are the same,
you can tell difference between solid and hydro, by the solid having 1 more cam cap, thus 1 more journal on the cam, also if you have both in front of you, you can deffenitly tell a difference in lobe size. hope this helps
.0020 over block,balanced,blueprinted,8lb flywheel,Stage 2 clutch,ported and ceramic coated head manifolds,turbo,pistons, SS valves, PP 2.5in DP,Intake, 3" ex.GTD nozzles, Built pump, windage tray,36mm pump,ARP Studs.etc.My build thread http://www.vwdiesel.net/forum/index.php?topic=15461.0
Reply #2November 25, 2008, 01:34:52 pm
gigaz2
  • 626
« Reply #2 on: November 25, 2008, 01:34:52 pm »
where is the search button??
oh wait! its right there, and it works too:
http://vwdiesel.net/phpBB/viewtopic.php?t=13962&highlight=cam+gasser
Reply #3November 25, 2008, 05:51:10 pm
cyrus #1
  • 360
« Reply #3 on: November 25, 2008, 05:51:10 pm »
Both solid and hydraulic diesel heads have 5 cam caps.  Only hydraulic gasser heads are missing # 4.  :)
Cody
2002 Jetta TDI
2000 Jetta TDI - R.I.P.
1990 Jetta 8v-Eventually to be 1.6TD
Reply #4November 26, 2008, 11:28:49 am
DCC
  • 184
« Reply #4 on: November 26, 2008, 11:28:49 am »
Quote from: "cyrus #1"
I'd say "Only mexican-made hydraulic gasser heads are missing #4".   :wink:
Reply #5November 26, 2008, 12:16:43 pm
MJF
  • 581
« Reply #5 on: November 26, 2008, 12:16:43 pm »
Quote from: "DCC"
No, almost all hyraulic gassers are missing.
'74 VW Scirocco TD
'86 Audi 80q 1,9TDic
'01 Audi A6q 2,5TDI
Reply #6November 26, 2008, 03:03:13 pm
  • 3255
    • My collection of HOWTOs
« Reply #6 on: November 26, 2008, 03:03:13 pm »
Quote from: "MJF"
Not to pound on this but only to be accurate, in case SEARCH leads someone here... tis true.  My 1992 last-of-the-German-Jettas gasser Jetta has no #4... really gave me pause the first time I had the lid off "oh no... I have a damaged casting."   :wink:
Reply #7November 26, 2008, 06:43:16 pm
boosted_diesel_84
  • 216
« Reply #7 on: November 26, 2008, 06:43:16 pm »
my bad, i have more experience with the gassers and assumed diesels were the same.
Reply #8November 26, 2008, 10:36:50 pm
DCC
  • 184
« Reply #8 on: November 26, 2008, 10:36:50 pm »
Quote from: "MJF"
Well, as far as I've seen, all hydraulic GTI's I've seen had the 5 of them. Only one of them had 4, and it was a german block and a mexican head (odd mix, I know).  :?
Maybe it's just the dx,pb and pg engines that have 5.
Reply #9November 26, 2008, 10:41:26 pm
cyrus #1
  • 360
« Reply #9 on: November 26, 2008, 10:41:26 pm »
that sounds more accurate.  I've seen PF, RV, MZ, etc and they all had 4 caps.
Cody
2002 Jetta TDI
