Author Topic: aaz problems  (Read 7976 times)
Reply #15October 29, 2008, 04:54:35 pm
aaz problems
« Reply #15 on: October 29, 2008, 04:54:35 pm »
Quote from: "beew"
haha alright..so no special tools or anything?
i think you might needs special 12 pt sockets, but i could be wrong... i've never taken a turbo apart b4, but can assume that some are a real pain to disassemble
Reply #16October 29, 2008, 05:00:37 pm
beew
  • 27
aaz problems
« Reply #16 on: October 29, 2008, 05:00:37 pm »
hmm ok i found this..pretty much everything i need to know i think
thanks
http://www.vwdiesel.net/phpBB/viewtopic.php?t=13357
where's a good place to get a rebuild kit? any turbo rebuilders in southern ontario?
94 Jetta GL diesel
Reply #17October 29, 2008, 06:01:20 pm
aaz problems
« Reply #17 on: October 29, 2008, 06:01:20 pm »
Quote from: "beew"
thanks
Giles actually  :wink:
http://www.performancediesel.ca/
Reply #18October 29, 2008, 06:30:50 pm
beew
  • 27
aaz problems
« Reply #18 on: October 29, 2008, 06:30:50 pm »
awesome thanks.. ill give him a call
94 Jetta GL diesel
Reply #19November 03, 2008, 02:28:58 pm
slorimer
  • 52
aaz problems
« Reply #19 on: November 03, 2008, 02:28:58 pm »
You mentioned
have a k14 turbo i think (has adjustment right on wastegate)..
which adjustment are you referring to, cause I have a K14 and there isn't an adjustement, just a metal tube.  Have any pictures?  Curious.
94 1.9TD
Reply #20November 03, 2008, 03:15:21 pm
beew
  • 27
aaz problems
« Reply #20 on: November 03, 2008, 03:15:21 pm »
Quote from: "slorimer"
You mentioned
http://vwdiesel.net/phpBB/viewtopic.php?t=15964&highlight=k14+wastegate
theres a picture in that link that shows where its supposed to be although its missing in that picture..on the end of the wastegate is a threaded rod with a lock nut on it..that is where you adjust it
if you take you turbo intake tube off you can see it pretty easily
94 Jetta GL diesel
Reply #21November 04, 2008, 10:10:02 am
aaz problems
« Reply #21 on: November 04, 2008, 10:10:02 am »
it looks like you can adjust the wastegate in that pic, but getting it apart might be another story... my best guess would be to put some washers under the nut on the wastegate valve shaft to put some pre-load on the spring, so it would be stiffer.
your best to just install a one of those restrictor valves for the air going to the wastegate... that way it won't open as early.
