Anyone make an EGR block off plate?
Topic: Anyone make an EGR block off plate? (Read 2582 times)
October 02, 2008, 04:10:12 pm
allsierra123
October 02, 2008, 04:10:12 pm »
Or is it something I will need to come up with?
October 02, 2008, 04:17:27 pm
October 02, 2008, 04:17:27 pm »
you could check out kerma TDI.
it's not too hard to make though... just get a piece of steel and cut it then drill some holes, and bingo. you can use the egr line as a template even.
October 02, 2008, 04:25:01 pm
allsierra123
October 02, 2008, 04:25:01 pm »
Nice. Wastn sure if it had to be anything special or not.
October 02, 2008, 06:50:17 pm
blkboostedtruck
October 02, 2008, 06:50:17 pm »
i might have one? i bought an intake that had one but i welded up the hole because i needed more clearance but i still have the plate left!
Duane
injector rebuilds call 414-840-1395 for faster service not on line much!
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
3 jettas '82' '04 '14TDI
October 05, 2008, 03:19:27 pm
blunt
User+
October 05, 2008, 03:19:27 pm »
I used a bit of 5mm deep flat bar, cut it to match the shape of the flanges on the egr i removed, drilled it and bolted it straight on to place, piece of cake!
October 05, 2008, 11:40:57 pm
commuter boy
October 05, 2008, 11:40:57 pm »
Piece of sheet metal for me. Cut it with some tin snips, filed the edges, drilled a pair of holes and in it went.
